Projects Nate’s 32 roadster build
Discussion in 'Traditional Hot Rods' started by heyitsnate, Nov 17, 2020.
  1. It sure looks like you had it well thought out.
    Stogy, john potter and heyitsnate like this.
  2. Fordors
    Fordors
    Nate, did you make that steering arm or modify it to get correct steering geometry?
  3. heyitsnate
    heyitsnate
    It was an old one . I ended up heating the taper insert out of it, and re-welding it back in, but yeah it’s estimated at this point
    Stogy and loudbang like this.
  4. Looking great Nate. I like all the small details
  5. Great build thread with a lot of details. Keep the updates coming.
    Stogy, loudbang and heyitsnate like this.
  6. AHotRod
    AHotRod
    I love a real Hot Rod, enjoy the journey Nate
  7. heyitsnate
    heyitsnate
    Now I can do motor mounts. Pretty self explanatory here. This mount was a ton of work! 20E6C911-6B09-4C10-870B-2E3EC2DCF659.jpeg 40AEEB74-FB8B-464E-A0AC-F49A8B0F0D6F.jpeg 74AEAFCC-A957-43AC-A0F8-9FE534EFF7C8.jpeg F575B202-AE1C-4EBF-ACD4-90B094DBEA66.jpeg 6379256B-C82C-4C54-B9E7-1056D82CE81D.jpeg B72085FC-9270-44A0-8147-4F6175598E18.jpeg F19088EE-7FB7-4F7F-B348-E669BCDC1E4F.jpeg 1D209439-3793-48CA-B61C-D81492CBCF6F.jpeg 0A68E967-10AA-4D2B-AF9B-6AD6994E397F.jpeg
  8. heyitsnate
    heyitsnate
    Now it’s time to start t******* the v8-60 mounts and adding some pieces to the sides . I just beat some pieces in a bench vise to match the contours, beveled the edges then built up the welds. I made some solid shims that match the height of the biscuits , then checked everything with a starett level and a laser 1CBBA9E0-567C-4066-9F02-DCB9E5B92303.jpeg 4DB0FC29-0AB7-445C-ACF0-0BE911480F44.jpeg 86124115-FA76-4672-B25B-26E5033605CF.jpeg 47332F37-8E65-49EF-A006-7D5392429D90.jpeg 2D6F30E8-A90D-4C1C-8A1D-CC228B4F383E.jpeg 5DA0CF7A-8865-4A5A-A91B-04FD04BE256E.jpeg 80F7D2A3-FCEC-491C-B4F1-9793FDBA96A5.jpeg 7F64AC0D-AE19-4344-B53A-2BB65695C3FE.jpeg 98DEB257-97DC-463D-9B3A-F1CABB8F4869.jpeg 763D00A8-65E9-4778-A98B-70A4148E0BEC.jpeg 519350AA-4938-4936-AD69-3233D94AE15D.jpeg
  9. heyitsnate
    heyitsnate
    Now tacked, checked, then welded. Also welded a simple spring clamp 6A529E47-3722-4905-A8DD-F6B0F4DCDAE2.jpeg 168DB57F-D51F-4132-A751-F30F855D36EA.jpeg 5592CDC0-E078-4606-99E1-919747EBF362.jpeg 211A334F-E899-4A56-882C-6F4BE214F941.jpeg 948238C8-0C5B-4711-9DBB-3DEB3AB32E50.jpeg 87563F98-1910-4211-8CFE-C705A3CE702E.jpeg
  10. heyitsnate
    heyitsnate
    Next up I mounted some Armstrong shocks in the back, then back to the front where I welded in some rivets in the stock locations. The body is fake too so why the hell not FB136831-4071-479E-A552-6D1CA219333B.jpeg
    09AD86B2-6513-497C-879B-340A9D39626C.jpeg F03DE43B-6C43-402F-B586-BA441B14193B.jpeg BF5FD163-4636-44E7-BCDA-0E00565C557B.jpeg 7EE64CAD-D945-4022-8E53-A3249766B08D.jpeg
  11. heyitsnate
    heyitsnate
    With the help of my lil bud we hit a big milestone. Pretty close to seeing a full roller! Shackles and hardware are temporary. I really hate the oem shackles but that’s what I’ll do in final. 1362EA03-D7A8-44AD-99F7-3DDC80B9449A.jpeg 658BEB33-A13F-4E56-B6CB-9EBEDE33C726.jpeg C7D078E5-AF4A-4DCC-A7B1-5FE521AFAEA8.jpeg E403D248-8E04-4B9C-B80B-19EFCE53EE45.jpeg 3124B8A7-EF78-4848-A692-6B5817C63AE5.jpeg 7E566F62-3D75-4C0D-895F-F3EDC0906379.jpeg C0074CD6-E899-4CEA-9E21-8A697811169B.jpeg
  12. Cyclone Kevin
    Cyclone Kevin
    Alliance Vendor
    Very inspirational!!!!!! Great Job!!!!!!
  13. heyitsnate
    heyitsnate
    Thanks Kevin! Do you still have that purple 34 I love so much?
    Stogy, loudbang and Cyclone Kevin like this.
  14. Cyclone Kevin
    Cyclone Kevin
    Alliance Vendor
    Not attempting to highjack the thread/post;). 69CBF24E-A720-4DAB-82E9-24FEF11246C0.jpeg A60183D0-F717-4404-9A9C-426B0B84D7AA.jpeg 78A29B9A-FC46-4887-8455-3F953FB04E75.jpeg
    Thanks for digging it, I recall speaking with Jake (P&J’s) about different styles in Hot Rods. We were @ “The Hat” it’s a pastrami-burger joint. He had a bunch of PPC-Archived pix of 32 roadsters as he was looking for inspiration in coming up with ideas for a 32 Roadster build, He was inspired by the Walker Morrison 32. That’s an Iconic Roadster.
    He asked me what inspired anything that I’d build, I recall my 1st response was budget, My 2nd was actually more of a flattery towards him and his former company as I indicated that if some of these parts that they made hadn’t been built, I’d have a whole different inspiration.
    Thom Taylor did a really cool pencil drawing of side profiles of roadsters for “The Roadster Shop” one of them being a 34, Those became their ads. I really liked the side view of the 34 Highboy and said I want my side to appear like.
    We get inspiration from many different sources another being a SRM feature on the “Flying Flathead” roadster. I really liked its hue. Another was a Deuce roadster in a Don Montgomery book that was in the back ground of a PRC action shot.
    I locked in those tires and I saw that roadster a very cool deep purple in my head.
    Thx again.
  15. heyitsnate
    heyitsnate
    Now that that’s mostly done I was in a hurry to see the body on. I will say it’s not as simple as it looks. Each time the body goes on it must be shimmed and it’s an ordeal , things don’t magically line up! 94763967-119F-4E02-8630-BF384E436730.jpeg AA249990-40CD-446F-8D66-E69B2C39BD7C.jpeg 55892218-C02D-470C-A60D-8A008074EDB5.jpeg 4D554E7A-E56A-4FEA-B7D9-5E02F2024445.jpeg
  16. heyitsnate
    heyitsnate
    The next major step is the driveshaft . at this point I took a ch***is break. I was looking forward to doing the dash so I started on that. I’m still in the middle of all that, which I will cover in future installments. It’s a lot . Besides the dash I needed to drill my doors for outside door handles. I’ve never had a roadster with such luxuries so here we go. I sanded down and sleeved an air fitting for the job. D5761EDA-0AB2-4DB4-9F6C-2CBB34BF2A4C.jpeg A888228D-139E-4E8B-BD9C-77BB7CC17377.jpeg 1BF932E7-62F2-425E-9E98-EAD6E1B978FA.jpeg 630FCB82-2D80-49CC-AD42-07D28EC3B46A.jpeg 37798A5E-0B6E-4CAF-8972-8FB144B9DFAA.jpeg 90AA3859-D763-4114-B4A1-2ABADFD903D9.jpeg
  17. heyitsnate
    heyitsnate
    Well now we are pretty much current with the build. There’s lots I glossed over like rebuilding the spindles, spring packs , locating the steering box, making floor templates, lining up the pedals and things like that. Many hours in on that stuff. The next update will hopefully be soon as I drop the motor and trans in, do the driveshaft and get some floors and seat foams in. Also on the to-do list is the drag link and some adjustments to the body .
  18. El Hueso
    El Hueso
    Beautiful.
  19. rob-redm
    rob-redm
    Looks great Nate... Really liked reading thru the whole thread.. Keep at... Going to be bad *** ! @heyitsnate
    Stogy, heyitsnate and loudbang like this.
  20. heyitsnate
    heyitsnate
    I did not have the mind bending array of photos I thought I did, but this part was pretty straightforward. The body located the running board brackets, transfer to frame, and I had the rear fender frame holes done, so I bolted up the rear of the fender, the front of the fender, then used clecos and some lightly applied tie down straps to locate the fenders, from there I marked, drilled and spot welded the cage nuts in. I like to use a roper Whitney handheld 17E56839-AD36-4A4C-BFCE-212304F494A8.jpeg E756FD52-3F10-42C0-8632-9FADF35FCDC6.jpeg E27CAA35-0380-4F23-AE77-724E0DF0E701.jpeg hole punch to make the holes on the cage nut tabs. If you are planning to get into sheet metal often it’s a worthwhile investment.
  21. heyitsnate
    heyitsnate
    I spent thanksgiving morning cutting my wood floors. Earlier in the build I made some Luan templates, so I set about making them in birch plywood. Wood is not my strong suit, but I struggled through it. The small upper column piece I made 4 times. My 4th one totally delaminated at the end so I decided it best to glue it. I thought about doing another but that one could do the same thing later , do I’ll head it off at the p***. also didn’t hurt I was happy with the fit. 0C182400-7795-4CCA-8538-1778E558D0DA.jpeg E93BDF5A-F2BB-4DE9-BC87-3B82C3E12A3B.jpeg E24263F9-3387-40C3-AFAD-F47667EF202C.jpeg
  22. brEad
    brEad
    Glad you shared this with us. I enjoyed following your ‘36 and I’m subscribed to this one now, too.
  23. x77matt
    x77matt
    Really loving this one- great fabrication, especially the wishbone detail! Great job so far!
  24. heyitsnate
    heyitsnate
    I was saving the dash stuff til I was done, but I’m bored and maybe you you will think it’s neat .
    idk. my interior I want one thing. Decadence. I’m not doing anything subtle or understated in the cabin. Hollywood seemed the obvious choice so I tried different layouts
    C5586E57-ABCD-427C-98C9-3C35E14410B3.jpeg 827A0F4E-92C7-4AF9-859B-C8842487BFE5.jpeg AA2C9ABA-1419-4AB4-B3A4-C6B90B5573E0.jpeg 3BD27677-7165-416A-AB1F-CF26BF80B309.jpeg
  25. heyitsnate
    heyitsnate
    The 3w is my favorite 32 interior. Who doesn’t love gloveboxes ? I managed to get a really early Hollywood panel from pat swanson that’s a little smaller than the more common one. I made some patterns and then set about making a hammer form. Next I bead rolled some insets and hammered the edges over them. Thankfully this bit worked.
    1F49B11A-8FFF-4C42-B4E5-DAE26FF07AAD.jpeg 7D2E7939-CF64-49DF-A7A1-144FCD4BBA9C.jpeg E5772E26-9D79-4714-A75A-3CDD7131C0FC.jpeg 2ED07854-A076-45A2-8183-B19527015F63.jpeg 7C00603A-E9A0-4F12-8F58-9C4CB66209D1.jpeg 2D623D22-A3D4-4BCB-A49D-E26582C3AA0A.jpeg
  26. heyitsnate
    heyitsnate
    I figured if I could just get one glovebox hole done on one side, the other side would follow, so I made a box hole, then drilled center in the dash and made an aluminum fixture I could flip over and use for the other side. Once I marked the aluminum I cut the hole out and hand filed it to size . It took about 3 hours of filing to get it all where I wanted it. Long hard day .
    1DACED0C-AB91-4884-9BF0-C9934CF87503.jpeg 2160CCC6-909A-4D99-A0B8-BDC2C8D43B0F.jpeg A4A26EAA-0324-4118-A143-1640E09DCA43.jpeg 7419EB40-5A30-4A01-A7FE-5948E84E3ABE.jpeg 55694608-4016-44BE-82E3-288E6B5DF966.jpeg 2F792317-311E-46A1-B954-D24BF9333FC8.jpeg 0BC3159F-F0D8-494F-934E-3ECE8DA5857E.jpeg 1B767C45-A599-4B2B-9710-FCD3947E89FF.jpeg
    Once I had it I used it to cut the other side
  27. heyitsnate
    heyitsnate
    Now that that is done , I formed the edges using the aluminum as a hammer form. I was originally going to mount the door overlapping the dash, but a flush fit would be much fancy pantsier. I then made a hinge from flat stock, a couple of roll pins and some 1/8 rod. I ended up having to notch the flange and make an aluminum riser so the door would open enough.
    4E464855-9BE8-47E8-9138-36C91AD8802B.jpeg 53552672-FC1E-4C39-965F-33538B72A368.jpeg 41CD753A-5BB6-4C27-873E-A06747527D19.jpeg 6A97994C-A87B-4673-861A-05D477CF4782.jpeg 681FBBF4-A16E-46CA-891E-C788D79467EC.jpeg F105B52E-4304-4BD0-BEB9-D9756976C077.jpeg 792D6A19-ADC4-49FA-98DD-ED6043947BFD.jpeg 42FFC2A3-0A4B-49F1-B84B-82057E76CE53.jpeg 74DB4653-A88B-4BBA-949E-10C0FE7A8B8A.jpeg 32ECAF0B-F8D3-4678-9E31-CC3777AE821F.jpeg B508AFE6-C794-4176-B608-A6A17548EB4B.jpeg DD409FF0-C061-4A42-A8BD-81C01AAB4EA1.jpeg
  28. heyitsnate
    heyitsnate
    I didn’t want 2 so I made a cap for the other side and welded it in. With my kid in zoom cl***es I brought some sheet metal home and worked it around a pipe until it resembled a glovebox.
    2B18CA64-26BF-41C7-B4F1-BE9D5209D301.jpeg 750033B1-448C-447A-B327-191DF5E0686B.jpeg 808AC821-06C0-46FD-8493-E350B9F41317.jpeg B2FAA9D5-EAE8-4092-9226-8071FB0C9172.jpeg
  29. heyitsnate
    heyitsnate
    Next I needed mounts so I welded tabs on the flange. Then I fitted a piece of spring steel to the bottom , setting up the next little bit.
    5E48B59D-86A8-43E6-BAE9-EE7371C479F2.jpeg CADD6A09-3906-4848-AC1E-D4B69149C093.jpeg 00C8CFF6-D17C-4352-8BE0-666969672A4A.jpeg
  30. heyitsnate
    heyitsnate
    This would be the next bit. I made a wire hoop on the inside of the door, and modified an elbow latch with a choke cable . Later I will put my dash knob of choice on there and mount it somewhere on the dash. It works, the door pops open. I just need to know how to post video.
