Projects I'm 18 and building my first flathead 59AB+merc crank for my chopped 34 4 door sedan
Discussion in 'Traditional Hot Rods' started by Jesse Borba, Nov 20, 2020.
  1. Jesse Borba
    Jesse Borba
    Thank you, old stuff is so much cooler than new stuff and I'd hate to see interest in cl***ic cars die. I'm doing my best to keep old hotrods alive.
    redzula, brEad, Stogy and 4 others like this.
  2. warhorseracing
    warhorseracing
    from cameron wv
    You Sir have some style and cl***. Cl*** to hang out here.:D
    Stogy and Jesse Borba like this.
  3. BJR
    BJR
    Lets see some pictures of the car you were planing on putting it into.
    Stogy likes this.
  4. Jesse Borba
    Jesse Borba
    I'll post some tomorrow
    Stogy and chryslerfan55 like this.
  5. seb fontana
    seb fontana
    from ct
    Not to be discerning but the pics that come up for me are absolutely awful looking. Maybe some kind of resolution problem at my end?
    Stogy likes this.
  6. Jesse Borba
    Jesse Borba
    It may be my extremely ****py phone
    Stogy, winduptoy and chryslerfan55 like this.
  7. 1946caddy
    1946caddy
    from washington
    14 posts on your first day. Move over HRP, there's a new kid on the block. :)
    34 5W Paul, Hnstray, redzula and 4 others like this.
  8. Jesse Borba
    Jesse Borba
    Is that impressive? I'm obviously new here lol
  9. LOU WELLS
    LOU WELLS
    from IDAHO
    Best Of Luck To You And The Flatty Is A Great Place To Start... 58675142_2296989867291948_1348368565551497216_n.jpg
    kidcampbell71, Tim, Stogy and 2 others like this.
  10. jimvette59
    jimvette59
    5150 that is a car motor with narrow belts.
    dana barlow likes this.
  11. Automotive Stud
    Automotive Stud
    Does the motor turn over? I'd measure the stroke before you pull the crank and rods out. It's not uncommon to find a Mercury motor with a Ford crank in it. Almost all of these motors have been swapped/rebuilt at some point and it was common for parts to get mixed and matched. I've had two Mercury engines, one even came out of a mercury, with the shorter stroke Ford crank.
  12. warhorseracing
    warhorseracing
    from cameron wv
    Jesse, you are very young to be taking on a task like this so try and stay focused as you can be turned off if things go astray. A flat head engine is not the cheapest engine to take interest in at such an age. As I said previously, you have style and cl***. Life will take different turns and your interests may change as life gets in the way. There are alot of very willing and helpful people here and some that need to be taken not so seriously. Do not let other people affect your direction and go where your heart desires. I hope that you will succeed in your endeavors and get what you want which is at this point to; get this engine running and find a suitable vehicle to put it in.
    getow, harpo1313, LWEL9226 and 5 others like this.
  13. Jesse Borba
    Jesse Borba
    Thank you very much for the advice.
    chryslerfan55 and warhorseracing like this.
  14. Jesse Borba
    Jesse Borba
    The motor is frozen so I was planning to let it sit with something in each cylinder to help motivate it to free up
  15. warhorseracing
    warhorseracing
    from cameron wv
    Do not force it. Take it easy and let the penetrant work. Kroil or other home brew penetrants do not always work overnight and may take a week or two. Once you get the initial break soak it some more and take your time then eventually it will turn completely over and begin to really loosen up.
  16. Jesse Borba
    Jesse Borba
    Ok, I'll stay patient
  17. slowspoke
    slowspoke
    Congratulations on the acquisition Jesse! This is a great opportunity to build your tool collection, expand your critical thinking ability, and keep your hands busy turning wrenches! If I could make a suggestion it would be for you to pickup some literature on the ford flathead. There are some pretty great resources out there dedicated to this motor. I found 'How to Rebuild & Modify Ford Flathead V-8 Engines' by Mike Bishop & Vern Tardel as a great initial read. Cheers and good luck on the endeavor!
    Jesse Borba likes this.
  18. BJR
    BJR
    With a flathead some times the valves stick and keep them from turning. Try removing the cam gear and try turning it.
    Elcohaulic likes this.
  19. 61cad
    61cad
    To keep your mind off the engine as it soaks.. Grab a couple of old Stromberg 97s and break them down, clean and rebuild..
    Stogy, triumph 1 and Jesse Borba like this.
  20. wheeldog57
    wheeldog57
    Great to see a young'en playing with a flathead!
    As others have stated, these can get expensive pretty quick. I have limited experience (rebuilt one) but learning the differences between the many variations kept me from buying stuff that didn't work or fit. Jesse, ask many questions even if you think it's stupid. I kept mine on the cheap by ridge reaming top of cylinders, re-ringing pistons, and cleaned the **** out of everything myself. It can be fun. . . . Enjoy!
  21. Flathead Dave
    Flathead Dave
    from So. Cal.
    As you're tearing it down, remember not to FORCE anything. Soak the bolts if you need to and let them soak for awhile.
    Be careful with this motor. Don't rush it.
  22. Jesse Borba
    Jesse Borba
    This is the 34 ford 4 door sedan that was chopped in the 50s that might be what the motor ends up in. It's rough around the rear floor but it'll be cool. 16059862983782235443357683572812.jpg 16059863474327403006587132912320.jpg 16059863772955808927729627956553.jpg
    Drylake, ClarkH, Fordor Ron and 21 others like this.
  23. warhorseracing
    warhorseracing
    from cameron wv
    Looks like it is pretty much there. Can you knock the vegetation down around it to help it dry out? Is it on your property or somewhere that you have talked to the owner? It will need wood work or metal, whichever way you decide to go with the roof. So; mechanic work, wood working skills, metal fabrication and welding. You should be a well rounded hot rodder when you get it done. PATIENCE. Ask questions. Those are the key words is the with every stage of the learning experience. In the end it will be gratifying when you can drive it down the street.
    Stogy, chryslerfan55 and Jesse Borba like this.
  24. Jesse Borba
    Jesse Borba
    I got the oil pan off today, I'm guessing it's a good thing that there was oil in it? 1606004452517325295476165857936.jpg 16060044864286474622179977261196.jpg
  25. Doug Hines
    Doug Hines
    That '34 would be awesome to build! Best of luck to you getting with your new flathead project.
  26. Other than the fact that it would affect bearings, I think I'd be tempted to do an oven cleaner/pressure washer clean up, then soak it in citric acid for about a month before I turned any more wrenches. Might make life a whole lot easier and prevent a few broken parts.
  27. warhorseracing
    warhorseracing
    from cameron wv
    Citric acid may be better than mol***es but with the one exhaust manifold already broken it will not hurt it. Try to get the water pumps off then the solution will also get in and help clean the water jacket.
    48fordnut and Jesse Borba like this.
  28. Jesse Borba
    Jesse Borba
    What exactly is citric acid and do you have an idea where I could find it?
  29. Rickybop
    Rickybop
    Welcome, Jesse!
    Boy, did you come to the right place. Can you BELIEVE the knowledge these guys have? They always amaze me. And they're always willing to share... especially with a young guy like you with such an obvious and refreshing love for the old stuff, and a willingness to actually listen and express just a little appreciation for the help.
    You're awesome.
    You're proof that traditional hot rodding will be around for decades to come.
    Good luck!
    BTW... As a side note, I'm sure we'd all be interested if you shared with us...
    How did a young guy like you in this day in age get so interested in traditional hot rods?
  30. warhorseracing
    warhorseracing
    from cameron wv
    Google it and it will come up as a dry powder and can be found at hardware stores or ordered on line. It is not that expensive either. You can search it here and get the low down. Have you used the search function here yet?
