Projects 1917/1928/1938 American Lafrance Plymouth V12 Speedster
Discussion in 'The Hokey Ass Message Board' started by animal8324, Nov 17, 2020.
  1. animal8324
    animal8324
    from nj
    Screenshot_2019-09-26-11-48-08-1.jpg ford-999-1963-1.jpg d5-760x506.jpg 05-Premier-DV-16-Indy-001.jpg 20191215_202503.jpg 20191226_210728.jpg 20200318_155943.jpg 20200319_173027.jpg 20200318_181047.jpg Here's my 1938 American Lafrance V12 Speedster project.
    A big engine Speedster has been a long time dream of mine but I thought it would be a project I wouldnt be able to get to untill much later in life, but last November that all changed. A 1938 V12 and Trans popped up for sale at a price I could afford not far from me and it was owned by a friends father and stored at my friends.
    When I went to check it out at my buddies he also had wheels, a front axle, rear diff, and a steering box off of a 1928 Plymouth which in my mind had great proportions for what I wanted to build so I picked those up too.
    When I got it all home I shoved the parts in a corner and finished the projects I had going on. While finishing these other projects I chewed over the design in my head. I decided I was going to build a super stripped down, chain drive, br*** era looking speedster like what would have been seen in Indianapolis, or on ice covered lakes making Land speed runs, or the Vanderbilt Cup Races at the turn of the century. The Ford 999, 1905 Premier, and Durrauq's, were huge insperations for this project.
    December 14 2019 was the oficial start of this build.
    I started by using wood to figure out what size Frame rails I wanted. I went with 2"X8"X.125" box tubing.
    Next I set the engine in place making sure the intake was level in all directions using cinder blocks and wood as cribbing.
    I then did the same with the frame rails.
    Next I set crossmembers and built engine mounts.
    Soon after mounting the engine I decided to test fire it which I originally said I wouldn't do untill I was done because if something was wrong with it my motivation would be destroyed. But it ran awesome and gave me even more motivation.
    And to make a long long story short i'll forget about chronological order and just list everything else i've done since then.
    Procured a 1917 ALF Radiator, wheels, tires, modern trailer hubs and spindles that have correct bolt pattern for wheels, rear axle which is actually a front axle off an 80's international, and purchased custom springs from Alcon Spring,
    Shortened the rear diff so it could be used as a transaxle for chain drive and set it in place
    Welded trailer axle spindles into the 80's international axle
    Fabbed radiator mount, steering box mount, front frame horns, and spring mounts,
    Machined adapter for transmission output to read diff input, spacers to allow the modern hubs to be used on the 28 Plymouth front spindles.
    Right now I'm finishing up the front hubs and getting ready to make spring hangers for the rear axle.
    I'm sure there's alot I'm missing but whatever it's time for pics! Screenshot_2019-09-26-11-48-08-1.jpg ford-999-1963-1.jpg
  2. animal8324
    animal8324
    from nj
  3. animal8324
    animal8324
    from nj
    I'll get shots of the build as is today
  4. Ebbsspeed
    Ebbsspeed
    BEAST! A 6-headed monster of an engine! What is the cylinder angle of that V12? Can you post a straight photo of the front or rear of the engine?
    EDIT: Never mind, I found one on the interwebs.
  5. 64 DODGE 440
    64 DODGE 440
    from so cal
    I'm subscribed, this looks like a fun project.
  6. Boneyard51
    Boneyard51
    Awesome!
    Bones
    Tow Truck Tom and loudbang like this.
  7. Stooge
    Stooge
    Oh Yeah! big brute teens and '20s / brooklands era speedsters/ cycle cars really tick all of the boxes for me! Definitely subscribed, cant wait to see this come together!
  8. Nice progress- looking forward to seeing where this goes!!!
    animal, where are you located in Jersey?
  9. Ya man I’m hooked and ready for more !!
  10. animal8324
    animal8324
    from nj
    20201117_134356.jpg 20201117_134349.jpg 20201117_142301.jpg Here is how she currently sits. I'll have u bolts later today and can start on the rear spring mounts.
    I'm no longer in Jersey. I moved to Spring Valley, Mn 5 years ago 20201117_134356.jpg 20201117_134356.jpg
  11. Squablow
    Squablow
    Curious to know what the advantage of the IH front axle is, won't it turn backwards, or are you able to flip it upside down? Interesting for sure. Love the project overall. What's the CI and HP rating on the engine?
    Thor1 and chryslerfan55 like this.
  12. This is just a guess, but I ***ume the young lady is your project supervisor?
  13. animal8324
    animal8324
    from nj
    The IH axle is just a dead axle. No gears. Hubs will be chain driven. The rear differential from a 28 plymouth will be connected directly to the trans and speockets will be mounted on the axles which will be connected to the rear wheels via chains
  14. Squablow
    Squablow
    OK I get it. That's wild, looking forward to seeing more!
    VANDENPLAS and loudbang like this.
  15. noboD
    noboD
    You got my attention when you said Premier, I am waiting for more progress. Looks great so far.
  16. warhorseracing
    warhorseracing
    from cameron wv
    It had better be or his wife might be mad.:D
  17. tubman
    tubman
    "Google" says 527 ci and 215 HP.
  18. animal8324
    animal8324
    from nj
    Yup. Big number back in the day lol
    chryslerfan55, SS327 and loudbang like this.
  19. 51504bat
    51504bat
    Too bad Gui (@Drmalacarne) is in Brazil and you're in NJ. It would great to see both of these V-12 monsters side by side when both are done.
  20. animal8324
    animal8324
    from nj
    Since this is going to be a chain Drive Rig the trans output can be connected directly to the Input on the Diff.
    So I made a mount plate that locates itself on the trans output and spun the old 28 plymounth diff input yoke so that it fit inside the mounting plate.
    After checking that everything was nice and centered I TIG'd them together with alittle 309. 20201120_183948.jpg 20201120_183959.jpg 20201120_184941.jpg
  21. tubman
    tubman
    I agree. As they say in England, "Bring back Brooklands!".
  22. AHotRod
    AHotRod
    Very cool project
    41 GMC K-18 and loudbang like this.
  23. animal8324
    animal8324
    from nj
    I had a productive day in the shop. My buddy came over to learn a bit of machining so while he made spacers for the front hubs I got onto the seats, which i've been fantasizing about for months.
    I started with my CAD design software and moved on to steel at the end of the night.
  24. shivasdad
    shivasdad
    from Texas
    I'm watching. Hope to join the club someday, but I have a straight eight that may not be salvageable. Cool start, really like the chain drive idea.
  25. studebakerjoe
    studebakerjoe
    Very cool build. What are your plans for attaching sprockets to the rear drums?
  26. Tim
    Tim
    from KCMO
  27. animal8324
    animal8324
    from nj
    The 28 plymouth brakes will remain of the rear diff/chain drive diff
    On the rear axle I'll be attaching the rear sprockets directly to the rear hubs and create an external rear e brake at the same time
  28. v8flat44
    v8flat44
    If that ain't gonna be cool, then Frosty ain't a snow man.....look out Levethian, there's gonna be a "new kid in town".....i'm watch'n.
  29. animal8324
    animal8324
    from nj
    Seat 1 is done...untill I have another set of hands to help me run a few beads in 20201124_120414.jpg it
  30. animal8324
    animal8324
    from nj
