Projects 1932 Ford Roadster Build- "The Template Roadster"
Discussion in 'Traditional Hot Rods' started by x77matt, Jan 4, 2018.
  1. And, in case you didn't notice, Matt's was reman'd in Canada. :)
  2. x77matt
    x77matt
    With the winter weather looming in Michigan, I decided to get the rest of the paint finished this weekend. Has a few setbacks but overall a good weekend. On the second coat of the gas tank, I discovered the hard way that the cap was cross threaded on the gun and I dumped paint on to the tank. Also discovered the hard way that the rag I used for wax/grease removal must have been contaminated as I had a few fisheyes pop through. On the positive side I figured out how to correct the m***ive orange peel problem I had with the body. This time I waited 20 minutes in between coats and it was a night and day difference as it laid out way more flat. I think I was rushing the coats before which led to the orange peel.
    90075EB7-57A1-4CD3-BD1D-430705BFC6ED.jpeg F9D70441-2510-470A-B69B-869B70457164.jpeg 5393662C-F5FB-4949-BEA5-B085E64631F9.jpeg
  3. nor6304
    nor6304
    from Indiana
    That laid down really nice Looks good
  4. loudbang
    Looks real FINE. :)
    brady1929 likes this.
  5. qzjrd5
    qzjrd5
    from Troy, MI
    Looking awesome bud!!
  6. brEad
    brEad
    Really nice! Great job.
  7. x77matt
    x77matt
    Progress report- dash was grained by Stuart Lyman and he did an awesome job. Had a chance to get some paint on the inside of the body and get a few things into place- like the gauges....
    A91D35AA-76E9-45EB-A04B-7DA0F16C2101.jpeg 96A89EA3-B7AC-4FFA-A09B-91B8425130B5.jpeg 603B4929-4537-409D-AB6D-F7E8F37ACEBD.jpeg 92B5CB3A-2A0B-4DE5-AD6A-39DC4BDC9599.jpeg 1FE8E444-10E9-4906-A75E-DCEBFA23C0C1.jpeg
  8. alchemy
    alchemy
    That dash is way too cl***y for a hot rod! ;)
    30tudor, Stogy, loudbang and 2 others like this.
  9. brEad
    brEad
    Dash is stunning! Love the rest of the build as well.
    Stogy, agshelby, fegsta and 2 others like this.
  10. x77matt
    x77matt
    Radiator arrived, insert and shell mounted. Just fighting the hood right now...
    D0E12A8F-D0D1-4432-9E7E-3479330647EE.jpeg 3905E216-AC71-47E3-A627-CE794169434F.jpeg 5DB74167-3FA9-4805-9406-C41B0ACD2110.jpeg 0B2E9E9B-A05D-4C56-8F2C-4D0715CE7D80.jpeg
    Outback, alfin32, Stogy and 9 others like this.
  11. loudbang
    I think your headlights might need a tad of adjustment. :rolleyes:
  12. This is an amazing build - every aspect is stunning .
    x77matt, fegsta and loudbang like this.
  13. x77matt
    x77matt
    Finally got the hood on and fitting pretty good. Still have to wet sand and polish it, but it’s starting to come around.
    3731A172-1207-4C18-AA7E-3408DD062E23.jpeg D2CD91D4-F2A6-4B8B-9ADF-81E9B079A9F4.jpeg F9E3C999-6306-46D5-8DFD-CD4FB4ADEA8C.jpeg
  14. loudbang
  15. Atwater Mike
    Atwater Mike
    Matt...You are now officially in the 'Amazing Business'. Just amazing.
    loudbang, x77matt and triumph 1 like this.
  16. I went back to page 1, just to refresh myself on what it looked like, and what you've accomplished to date. Wow!
    loudbang and x77matt like this.
  17. qzjrd5
    qzjrd5
    from Troy, MI
    He's got it running now, he owes the HAMB an update dammit!
    Outback and loudbang like this.
  18. x77matt
    x77matt
    Thanks guys! Mike is right- here we go:
    I was having a hell of a time with the ignition. Finally I pulled the pertronix back out (back to points and condenser) and byp***ed the MSD. It fired!! I spent a little time dialing it in and set the timing. Then I re-installed pertronix unit without moving the distributor and rechecked the timing. I had to rotate the dizzy about 20 degrees retarded to get back to the same timing I was at with points. Everything I read says they should drop right in with no adjustment- not here! Next step will be to add the MSD 6BTL back into the mix now that I have that sorted and see if I can get it to work.
    85A7CC87-A04F-49A3-AC50-4091E4C2C4CD.jpeg 83E3D94E-B713-4710-8E13-42D585BC091A.jpeg CAD409E8-BA89-4D9A-87A2-04618A717B33.jpeg
  19. x77matt
    x77matt
    Video after first start with points and MSD byp***ed. Timing is way advanced on this (before I set it with the light).
    3 5/16 x 3.75, relived, mild port work with oversized valves, Potvin 3/8 by @Pete1 , skip Haney water pumps, H&H blower, home made blower pulley with fan provision, polished SAE heads, original Stromberg, Mallory YC flat top conversion:
  20. x77matt
    x77matt
  21. x77matt
    x77matt
    Update from this weekend -first drive went well! Reverse was blocked out, but it turned out to be my shifter adjusted too tight. Also the rear spring was way too stiff so I pulled the top 3 leaves out last night. It’s snowing now so I gotta wait a bit to try it out....
    Darkhorse, lucky ink, X38 and 12 others like this.
  22. Aaron D.
    Aaron D.
    That's awesome, congratulations. I loved your build and think you did a great job your car. It's perfect!
  23. x77matt
    x77matt
    thanks Aaron!
  24. loudbang
    It WORKS !!!! :) Love the color. I know test drive and all but it's a bad habit to keep your foot on the clutch pedal all the time.
  25. What an awesome build.
    fegsta, x77matt and loudbang like this.
  26. fegsta
    fegsta
  27. brady1929
    brady1929
    Cool. Congratulations.
  28. neds29
    neds29
    Bridgeport and Kurt vice: doesn't get any better! Nice work.
  29. nor6304
    nor6304
    from Indiana
    Nice car Love the flathead & color Looks & sounds great
  30. Deucedreamer
    Deucedreamer
    from BC Canada
    Beautiful car and build!!! Where did you get your gauges rebuilt?
