Technical Best Make Do Repair EVER
Discussion in 'The Hokey Ass Message Board' started by BJR, Nov 14, 2020.
  1. Mr48chev
    I'd just about bet that came off a 47/54 Chevy pickup with a small block in it that didn't get the steering moved over and inch and a half. Kind of glad that JD Fikes didn't think of that when he helped me put the 283 in my 48 in the 70's.
    VANDENPLAS likes this.
  2. Beanscoot
    Beanscoot
    I was just looking at this post at work, unfortunately when someone walked by and saw this. Well, what does it look like from ten feet away?
  3. Wanderlust
    Wanderlust
    Yup , just realized that . I can hear it now, what the f are you lookin at!
    Truck64 and VANDENPLAS like this.
  4. lippy
    lippy
    from Ks
    When a loaf of bread was five cents and you didn't have five cents you sure as hell wasn't gonna buy a new pipe. Lippy
    Truck64, VANDENPLAS and 61Cruiser like this.
  5. Wife had a coworker wreck an OT truck on the way to work.
    I bought it over the phone. It was parked in a restaurant parking lot where it was pushed after the wreck. The radiator was knocked back into the engine. I pulled the radiator support forward and removed the radiator. Me and a friend used pliers and pinched off all the damaged flues, then stood on it to straighten it.
    Put 100k on that radiator. Never leaked a drop.
  6. warhorseracing
    warhorseracing
    from cameron wv
    No Sir I do not just copied the picture and it may not have been here. I thought. WOW! Using square tube to reroute a free flowing exhaust and then to top it off 90 Degree bends in it.
  7. Beanscoot
    Beanscoot
    Just this last October I was bringing a load of junk / valuable treasures back from the Kootenays to the Coast when I lost one of the four cylinders due to a bad spark plug wire. Luckily I had some rusty steel wire amid the junk, and a bit of surplus vacuum hose from the engine to insulate it where it drooped over the air cleaner snorkel. The secondary carb barrel was gummed up tight so I couldn't even limp up the mountains on three cylinders:
    It worked fine, I'm still driving it around town procrastinating fixing it "properly".
  8. 1971BB427
    1971BB427
    from Oregon
    Actually that's not rope, it's called "mule tape" used by electricians to pull huge cables into conduits. The smallest size mule tape is rated 5,000 ft. lbs. tensile strength, and that big stuff is over 15,000 lbs. tensile strength. Used a ton of it as an electrician on large commercial jobs, and it got tossed at the end of the single use, so I took it home. I've pulled cars with it, and kept some in my trunk for emergency use.
    Probably a pretty solid temporary repair to move a car at low speeds, for short distances.
    davidvillajr likes this.
  9. jaracer
    jaracer
    I was out water skiing with a buddy and we hit something and broke the shear pin in the prop. We were a long, long way from the dock at the other end of the lake. I got in the water, removed the prop and what was left of the shear pin. I put the prop back on, pushed the shear pin all the way to one end so it was catching the prop and filled the rest of the hole with bubble gum. We idled back to the dock with no problem.
  10. 34 5W Paul
    34 5W Paul
    from Fresno CA
    My Dad did a "make do" fix about 30 years ago on my Uncle's OT rig. Uncle George showed up in our driveway with a terrible rod knock in the SBC. Dad pulled the offending rod cap off and used a mill ******* file on the cap to tighten it up about "that much". That and new bearing halves and bolts and Dad told him it'd be good enough to limp home ~ 100 miles. It did. Then survived for decades after that. True story.
    Truck64 and Lepus like this.
  11. I have a ball point pen spring still in a Rochester 1bbl from over 20 years ago.
    Installed it on the side of the road.
  12. Ebbsspeed
    Ebbsspeed
    I had a muffler fall off an old beater I used to drive, and couldn't stand listening to the rumble it made in the interior. I grabbed an old 4" downspout, slipped it over the broken off pipe, and wired it into place dumping out in front of the p***enger rear wheel. It was still loud as hell but at least the interior didn't have that annoying rumble inside. Ran it for a couple of weeks that way.
    Yeah, my thought too.
    No ****!
  13. HemiRambler
    HemiRambler
    Made a transmission dipstick tube out of an old lawn chair. Still working perfect 20 years later.
  14. blowby
    blowby
    from Nicasio Ca
    I'd like to wrap that thing up and give it to the old maid next door if you're done with it.
  15. BJR
    BJR
    40+ screws for your pleasure.
    blowby likes this.
  16. Have been caught to many times coming home from a race night with something falling off a wrecked race car or the trailer but the most memorable was coming into NY from PA, Johnny Law flashed us over. We had no tail lights so we were driving faster than everyone so they didn't need to see them. He didn't see the humor but allowed us to go to the truck stop to get lights. We bought 2 flash lights, put red plastic over the lenses duct taped them to the bumper and were back out in the hammer lane.
  17. ken bogren
    ken bogren
    I've had a pen spring in the carb on my 63 Falcon for a few years now, I forgot until I read your post.
  18. I remember my uncle Rudy, who was a child of the depression, had a Chrysler product car that had a bearing knock. About once a month he would jack the car up in his car port, pull the oil pan off, and install a piece of old leather belt in the bearing shell. It would last about a month until the next time.
  19. v8flat44
    v8flat44
    Back in the late 50s my dad said that his 1st car, a Model T developed a bad rod knock. Being low on $$$, he cut a piece of leather and made a "bearing" insert which lasted a long time.......he p***ed in 1998; i wonder how many other "make do" repairs he came up with that i never heard about.
    Truck64, loudbang and olscrounger like this.
  20. 41woodie
    41woodie
    My dad used to always talk about using pieces of Bacon Rind to wrap around worn out main bearing in Model A's and such.
  21. 56don
    56don
    Those main/rod bearing mods must have been a popular fix because my dad told me his uncle who was a mechanic back in the 1930s & 40s had done the same thing.
  22. brading
    brading
    I have heard of the leather strip fix before about 50 years ago but never heard of the Bacon Rind fix. It is surprising what can be done when necessity dictates.
    Truck64 and loudbang like this.
  23. deathrowdave
    deathrowdave
    from NKy
    Beer cut to shim a hammerin rod bearing to get you home. Did this to lawnmower and it lasted a season
  24. guthriesmith
    guthriesmith
    So...had to come back and find this thread when I found this on a Corvair I am working on...:confused:
  25. BJR
    BJR
    That's just funny.
    loudbang and guthriesmith like this.
  26. davidvillajr
    davidvillajr
    A hinged muffler. Well, we're getting even closer to the ever elusive muffler bearing. Keep searching, lads!
  27. guthriesmith
    guthriesmith
    Just in case the hinge on the muffler wasn’t enough entertainment, the brazed-on plumbers tape patching what must be a hole tops it off.
  28. Truck64
    Truck64
    from Ioway
    That poor ******* with the heart pacemaker still clutching his chest when you drive by, or did he finally expire? :D
    Tim_with_a_T likes this.
  29. Beanscoot
    Beanscoot
    I never thought of that... I hope I didn't cause any more medical distress than giving high blood pressure to other motorists whose radios went crazy.
    And I rebuilt the carb a week ago - the secondary throttle was stuck shut. Now I have twice the power!
  30. goldmountain
    goldmountain
    I have a ball point pen spring in my '40 Ford glovebox latch.
    anthony myrick likes this.
