Technical What did you do with your car today? * NEW*
Discussion in 'The Hokey Ass Message Board' started by j hansen, May 3, 2020.
  1. brokedownbiker
    brokedownbiker
    Spent all day welding patches into my inner fender pieces, trying to make two ugly sets become one usable set
  2. gimpyshotrods
    gimpyshotrods
    A lathe big enough to swing a wheel would be too big for my shop. This is for a bench top fixture, that can go on a shelf when not in use.
  3. jimmy six
    jimmy six
    Christmas lights.... and no photos...OK hard to see in the 47’ Ford hub cap. CE5560A8-8062-4FF2-BA6A-F2E799E43867.jpeg
  4. RICH B
    RICH B
    Made a sheet metal nut for the weird threads on the Lincoln trunk poppers and mounted them in the holes in y '47 that Henry provided just in case someone shaved the trunk. Screwed some pads inside the lid and after about 20 or so revisions and cell phone in trunk videos got them working. Decide the front inner radiator panel needed to look nicer and shrunk out some wrinkles; supposed to do that before epoxy; but you know how that works.
    250 trunk popper (Medium).jpg 251 trunk popper (Medium).jpg 249 valance (Medium).jpg
  5. RICH B
    RICH B
    Did some more work on a homebrew luggage rack we're making for my friend's '33.
    IMG_20201123_104020 (Medium).jpg IMG_20201123_124622_1 (Medium).jpg IMG_20201123_124632_2 (Medium).jpg IMG_20201123_155919_1.jpg
  6. TA DAD
    TA DAD
    from NC
    studebaker build 004.JPG studebaker build 003.JPG studebaker build 001.JPG I have the front tilting
  7. TA DAD
    TA DAD
    from NC
    So when you go to O'reilly's and tell them you need a lower hose for a 47 Studebaker M15 with a small block Chevy and a Mustang radiator , this is what it takes to make it happen. oh yeah plus a piece of roll bar tubing.
  8. David Gersic
    David Gersic
    from DeKalb, IL
    Can’t tell from the pictures, but Dayco C71593 from AutoZone might work for you here. Cut down to length, it worked for my ‘37 with SBC and Brassworks radiator. Less distance to cover than you have there, but the outlets look like they’re in about the same relationship.
  9. gimpyshotrods
    gimpyshotrods
    Took delivery of a Haas UMC 500 machining center for the shop.
    Found a weak spot in the pad, and now I have a concrete project for the weekend! It's always something....
    mad mikey and chryslerfan55 like this.
  10. Well, I ate turkey, of course. Then I painted the driverside jamb on the Elco.gonna try to hang the door this weekend. 20201126_225859.jpg 20201126_225929.jpg
  11. fastcar1953
    fastcar1953
    Started welding hood back together after it got punched full of holes. IMG_20201108_210906.jpg
  12. junkyardjeff
    junkyardjeff
    Got the trans in the Sunliner tonight,its not getting any easier doing it on the floor so time for a lift. This will be my one and only convertible since that big X in the frame makes it a pain to change trans.
    Atwater Mike, j hansen and Lil32 like this.
  13. Pulled the trans and rearend from the parts car. Trying to save every usable part before it heads to the old junkyard in the sky.
  14. junkyardjeff
    junkyardjeff
    Took the Sunliner on a road test and I think I got a good used trans.
    mad mikey, Lil32 and RICH B like this.
  15. WTF really
    WTF really
    Got the seat mounts welded in. 20201127_145852.jpg 20201127_145856.jpg 20201127_145900.jpg
  16. squirrel
    got the new gas pedal in and working. And started on the plug wires.
  17. e1956v
    e1956v
    Alliance Vendor
    I took Friday off but stuff still needs to get done so Sunday it is.
    Tach tear down and inspected. Remove the magnet so I can replace the oil-lite
    Installed the new bushing in the frame, reamed it to fit the magnet shaft and re-installed the magnet in the frame with the magnet flaring tool. IMG_0828.JPG
    Put the tach back together and checked north south polarization so it could be recharged on the old magneto magnet charger. The compass is a WWII paratroopers wrist compass that was given to my father by a good friend of his. IMG_0832.JPG IMG_0831.JPG
    Once the magnet is overcharged we move to the test bench where while the tach is spinning it is de- magnetized to get the proper calibration. I use a pulse generator hooked up to our Stewart Warner old 890 series speed analyzer so I have both analog and digital to fine tune calibration. IMG_0833.JPG IMG_0835.JPG
    Then put back in the can for final calibration check. IMG_0829.JPG IMG_0838.JPG IMG_0840.JPG
    Pretty much the same procedure on the speedo IMG_0821.JPG IMG_0823.JPG IMG_0841.JPG
    Sent from my iPhone
    www.speedoservice.com
    Should I rush your rush job or the rush job I was rushing when you rushed in?
  18. junkyardjeff
    junkyardjeff
    Got a better test drive in and the new used trans is not any better then the one I took out.
  19. Zax
    Zax
    Got the vacuum wipers working on my ‘53 Ford. First I had no vacuum at fitting on the motor. Replaced the hose and that was fixed. Then found my stock unit had a hard spot about 1/3 of the way into the sweep. I took it apart and worked on it with emery cloth but could never really get that spot to stop binding. Remembered there were a couple units in the boxes of parts I got with my ‘40. They looked identical to my stock unit and one of them seemed to be in good working order. Lubed it up and bolted it in, works pretty well. Moves the full sweep, should be good for a light rain.
    Then I started the tear down to get my heater and defrost working. Got everything apart and test fitted my Ranchero heater core. Should be good with a little elongating of the holes for the fittings in the housing. Just need to find some replacement defrost ducts and I can start cleaning it up and putting it all back together.
  20. seb fontana
    seb fontana
    from ct
    Since day way mellow I played musical chairs with equipment for winter and took a few minutes to get the karts outside for engine fitment measurements. Blue one [Rupp I think] will probably get a 10hp out of go power and the red [Yamaha] will get a 15hp Lifan w/5spd trans.
  21. RICH B
    RICH B
    Drilled the homebrew rack for the bars we made and had plated along with a little V/8 emblem. Buddy is taking the mounts, links, and hardware to the plater tomorrow. Little more work and it will be ready for paint.
  22. jimmy six
    jimmy six
    My 60’s Rupp Chaparral is almost ready for the road. New rear axle and repaired turbine wheels. Outer rims picked up from the chrome platers and mounted the tires. Juan’s Auto Upholstery in Garden Grove replicated the original seat. B & S Raptor for power; will paint the steering column cover Argent tomorrow and add belville washers from McMaster-Carr under the rear wheel axle nuts and take it for a ride.... 3F13FA4D-01F0-429E-BC28-CC684161D5C1.jpeg 67034956-C7BB-4326-8DFD-93A9A2149A52.jpeg
  23. I helped my dad move three motorcycles as a favor to a friend. Also set my eyeballs on this little gem. IMG_1044.JPG
  24. gimpyshotrods
    gimpyshotrods
    Fired my electrician, and started running conduit for the new shop myself.
  25. jimmy six
    jimmy six
    That’s what I always liked.. but I’ve been retired for 5 years and SF is a little to far to commute. Running conduit and pulling wire was fun. Good luck.
    61Cruiser likes this.
  26. NWRustyJunk
    NWRustyJunk
    Started replacing the 880 Sedan's trunk floor. IMG_20201201_172306890.jpg IMG_20201202_165416983.jpg IMG_20201202_170803330.jpg
  27. Unique Rustorations
    Unique Rustorations
    Unload and move my freshly restored circa 1955 Snapon tool box into my office in the shop. Kudos to my friend Steve that got it done before Christmas! Randy
  28. Poverty cap
    Poverty cap
    I stripped a couple coats of paint off and fixed a few dings on a set of valve covers I’m putting on my 62 Belair. 62E2C11A-F276-4CF1-AF49-5B5AE555FA48.jpeg C447347F-6B2E-4D35-82E4-9AFB5DAE6AE3.jpeg
  29. gimpyshotrods
    gimpyshotrods
    I ran all of the conduit for in my new shop, solo.
    It took 7-hours, but it is all in.
    Tomorrow I hope to start pulling wire.
  30. Marty Strode
    Marty Strode
    X38 likes this.
