Projects 1925 Chev Roadster Build, 2 are better than 1...
Discussion in 'Traditional Hot Rods' started by Jimmy B, Nov 2, 2020.
  1. Tim
    Tim
    from KCMO
    Nice! Looking great so far
    loudbang and Jimmy B like this.
  2. Now to the crossmember I tried to get the radius rod mounts as close to the torque tube as possible, Chevs used a slip joint bell at the front. I had thoughts of making this like a ford torque tube but I think it won't be strong enough hence the way I have gone. With the wishbone rubber and slip joint there should be minimal bind.
    IMG_3961.JPG IMG_3962.JPG IMG_3965.JPEG IMG_3966.JPG IMG_3967.JPG IMG_3968.JPG IMG_3971.JPG IMG_3972.JPG IMG_3973.JPG IMG_3974.JPG IMG_3975.JPG IMG_3976.JPG IMG_3977.JPG IMG_3978.JPG IMG_3979.JPG IMG_3980.JPG IMG_3981.JPG IMG_3982.JPG IMG_3983.JPG IMG_3984.JPG
    That is all I could do with the crossmember without having a second pair of the wishbone mounts. Good news they will be ready next week so should have them in a couple weeks
    dwollam, Outback, 40two and 8 others like this.
  3. Next I bit the bullet and purchased a lathe, I tried to find a vintage lathe to no avail, so...... only option was chinese :mad::(
    I moved on to the shock mounts, I turned these pins to go thru the original spring mounts, with the space being limited the covered shocks I purchased won't work so will go with the non cover shocks.
    IMG_4034.JPG IMG_4037.JPG IMG_4038.JPG IMG_4044.JPEG IMG_4045.JPEG IMG_4046.JPEG IMG_4047.JPEG IMG_4048.JPEG IMG_4049.JPG IMG_4050.JPG IMG_4051.JPG IMG_4052.JPG IMG_4053.JPG IMG_4080.JPG IMG_4081.JPG
    dwollam, Outback, Okie Pete and 10 others like this.
  4. This is kind of where I am at, just waiting on a few parts and also need to take a few pics of some smaller jobs I have done.
    loudbang and Stogy like this.
  5. Tim
    Tim
    from KCMO
    Bet that lathe will prove to be a fantastic investment.
    Are the bracket side of the shock mounts Chevy spring hangers from the base ch***is?
    Jimmy B, loudbang and Stogy like this.
  6. The lathe has come in handy and have many more ideas to try out.
    Yes I removed them from the ch***is, these brackets are the rear hanger for the front end.
    brEad, loudbang, Stogy and 1 other person like this.
  7. Stogy
    Stogy
    When I purchased my Sport Coupe the rear tube shocks were upside down to clear the larger cover that was fouling against the crossmember...I managed a work around as I see you have...so many hurdles...​
    Outback, Jimmy B and loudbang like this.
  8. It is always a challenge trying to get things to work in confined spaces, as you say there are always work arounds, solutions. Part of the enjoyment in building these cars, I actually enjoy the challenges, it get frustrating at times but the effort in the end is worth it.
    Outback, loudbang and Stogy like this.
  9. So I thought I would do a quick post with some other projects I am collecting for. I picked up a '27 T RPU in September 2019, I am glad I was able to get it given how 2020 has turned out.
    Then in October of 2019 I purchased a lot of '29 parts to replace the parts I sold in 2010 to help fund my first US trip.
    While I was in the US in January I purchased a few panels for future projects '30 Model A cowl top and firewall and a '25 T cowl top. I now have a '25 T firewall, cowl top, L & R doors, door hinge & brace, windscreen posts, decklid and the front portion of the turtle deck. Next step will be to build a body buck for the T, I will start a thread for that once started.
    dwollam, Outback, Okie Pete and 9 others like this.
  10. grumpy gaby 2
    grumpy gaby 2
    Jimmy B It looks you're going to be a busy builder!!!!!
    Stogy, Jimmy B and loudbang like this.
  11. continentaljohn
    continentaljohn
    Sweet build and you sir are a craftsman
  12. Yeah got to keep occupied. Plus it always helps to think ahead to the cars I want to build as the delay in ordering parts ****s!
    Outback, Stogy and loudbang like this.
  13. Thank you John!
  14. Parts arrived yesterday so I may start the ‘25 T body buck soon.
    dwollam, Outback, Okie Pete and 6 others like this.
  15. Kume
    Kume
    what motor are you putting in the T roadster?
    Stogy likes this.
  16. '25 T will be v8-60 (Simca) or whatever flathead v8 I can find.
    '27 T RPU will be SBC.
    Outback, Okie Pete, Stogy and 3 others like this.
  17. I received the second set of wishbone mounts from Adam Tremellen. I purchased this set for the rear radius rod mounts. I am in the middle of a shed rearrangement so will get back to the ch***is sometime this week.
  18. Looks great.
    Stogy, loudbang and Jimmy B like this.
  19. 48fordnut
    48fordnut
    They look amazing. Good luck.
    Happy Thanksgiving.
  20. Jimmy B,
    I am LOVING your build: Real creativity and talent showing here!
    Those wishbone mount kits are Super Cool!
    Do you have the contact info for Adam Tremellen?
    I would like to get a kit.
    Thanks,
    Gregger
  21. Thanks!
    Thanks and Happy Thanksgiving to you too!
    @Gregger Rod & Custom
    Thank you Gregger! Are you on Facebook? If you are PM me and I will send a link to Adam's FB profile, I don't like putting contact info on a Public forum.
    Outback, Stogy, loudbang and 4 others like this.
  22. 39custom
    39custom
    Excellent work. :):)
  23. chev34ute
    chev34ute
    It’s interesting seeing all the panels you have gathered. I have been wanting a 27 T Roadster body for ages but don’t have the funds so I have done a deal. I am building a 28/29 Model A Coupe roof in exchange for some 27 Roadster panels for a mate near Sydney.
    Outback, Stogy, Jimmy B and 7 others like this.
  24. Okie Pete
    Okie Pete
    Amazing skills . Thank you for taking us along the path of your builds.
  25. Pete Eastwood
    Pete Eastwood
    from california
    Who makes these ?
    Outback, kidcampbell71 and loudbang like this.
  26. AmishMike
    AmishMike
    Nice wishbone mounts, looking forward to where on frame & how mounted
  27. Thank you!
    I like to collect early and time the build comes around I can start and make whatever I don't have. Good you have a way to trade for a T, nice work on the back roof panel! I would love to get a turtle deck, I have seen 2 Oz T roadsters for sale in last 12 months but too much and too far away. I traced a T quarter while I was in the US in Jan/Feb, I will work with that and the body to build a buck.
    Thank you! & I am happy people are enjoying the build.
    @Pete Eastwood Adam Tremellen makes them down in Victoria Australia. I will PM you a link to his FB.
    They are really nice. Hopefully I should have an update by this weekend.
    loudbang and Okie Pete like this.
  28. I recently purchased another 3-port, this one was modified in 30s or 40s. This will go on my current build. :D:D
    dwollam, Outback, Stogy and 3 others like this.
  29. Six Ball
    Six Ball
    from Nevada
    So how have I missed this? You are going to have two done before get my body together.
    I just went through all of this but I will do it again. Lots of great work.
  30. grumpy gaby 2
    grumpy gaby 2
    I see someone got the cooling holes in the back corner already! Really punched out the intake runners! (must be about max...) GOOD FIND!
