Technical Tire Size for 1932 Rolling Bones Roadster
Discussion in 'Traditional Hot Rods' started by ruppi1932, Nov 25, 2020.
  1. ruppi1932
    ruppi1932
    from Germany
    Hello everybody.
    The ***embly of my 1932 roadster is slowly starting. I will present the project in a separate thread. I would like to order tires but I am still unsure which size I should drive on the front axle. The car gets a Rolling Bones front end. I want to install 7.50x16 Excelsior on the rear axle - at the front I fluctuate between 5.50x15 and 6.00x16.
    What do you think looks better?
    greetings
    Matthias
  2. adam401
    adam401
    I like 6.00 16 on the front. Looks better proportioned to me. Also thats the stock size tire for a 1940 Ford from the factory so I always liked the idea that back in the day if you junk yarded a pair of front wheels and tires thats what youd find. Thats my thought process anyway I'm too young to have been there.
    lothiandon1940 likes this.
  3. Budget36
    Budget36
    I think it depends on your build and what you’re looking for, just lowered or a rubber rake?
    I’m sure there’s a thread or two on ‘32s with tons of pics to give you ideas
  4. curbspeed
    curbspeed
    I have 7.00 x 18 on the rear of my coupe and the small 5.50x 16 on the front. Excelsior's. I like the exaggerated cartoon look a bit. Mine fill up the wheel well nicely but it is a 34. Mitzi-Valenzuela-DPP_246878-scaled.jpg
    CrazyDaddy, AHotRod, adam401 and 4 others like this.
  5. Almostdone
    Almostdone
    Here’s a look at a ‘31 A with 7.50 x 16 rear, 5.50 x 16 front.
    C1FCD22C-31DE-40BA-ACEE-5AE1A0C7E9C5.jpeg 5D8D3268-9BD5-4E38-B8D2-125F28B55C19.jpeg
  6. Aspenridge roadster
    Aspenridge roadster
    I have 820x17 and 5.00x16 tire combo on my "The Spit 32" roadster
    Tjompen, AHotRod, deucemac and 2 others like this.
  7. alfin32
    alfin32
    from Essex, Ma.
  8. alchemy
    alchemy
    Seems to me the Rolling Bones guys never use oversize (6.00) rubber on the front. They usually use small, like 4.50 or 5.00 x 16.
    Happydaze, X38 and Just Gary like this.
  9. sloppy jalopies
    sloppy jalopies
    6.70-15" fronts and 7.60-15" rears ...bias ply... the frame is Zeed 5" in front and 7.5" in the rear...
    AHotRod and adam401 like this.
  10. krylon32
    krylon32
    from Nebraska
    I've got 2 open wheel deuces and have 500/16 front and 750/16 rear Excelsior's on both of them.
    CrazyDaddy and X38 like this.
  11. JWL115C
    JWL115C
    I went with Diamondback Auburn tubeless radial blackballs with 750R 16 rear and 560R 15 front on my 32 3-window fenderless coupe. Most pleased with the rake and look of the tires.
  12. 65standard
    65standard
    I’ve only seen one rolling bones built coupe. It had 7.50x16 rear and 4.50x16 front.
  13. ct1932ford
    ct1932ford
    Are they 16” ? Nice
  14. ssffnomad
    ssffnomad
    I was there last week But I am not a Spy
  15. rob-redm
    rob-redm
    thats a good look.. .. 18" rear tires look stupid on Coupes and Roadster. to big... ( JIMO) 16" solids or wire rims ? Good luck..
  16. ruppi1932
    ruppi1932
    from Germany
    Ok- thank you all !!! I order the 5.50x16 "and 7.50x16" tires.
    Regards Matthias
    rob-redm likes this.
  17. krylon32
    krylon32
    from Nebraska
    I'd go with the 500's rather than the 550's. Just personal preference?
    alchemy likes this.
  18. rob-redm
    rob-redm
    to late ! he's already ordered them .. lol:D
