Projects 1917/1928/1938 American Lafrance Plymouth V12 Speedster
Discussion in 'The Hokey Ass Message Board' started by animal8324, Nov 17, 2020.
  1. animal8324
    animal8324
    from nj
    Got my u bolts today so I'm able to start on my spring mounts. 20201125_171755.jpg
  2. animal8324
    animal8324
    from nj
    REAR SPRING MOUNTS ARE FULLY MOCKED UP AND THE BEAST OF THE VALLEY IS SUPPORTING IT'S OWN WEIGHT FOR THE FIRST TIME EVER!!!!
    It's like seeing your child stand for the first time LOL.
    I also started on pedals!
  3. 62pan
    62pan
    For a speedster that's a lot of heavy iron. What do you think it will weigh when finished? Looks good, I can't even imagine the hours you have in this figuring out what for parts would work well together.
    41 GMC K-18, loudbang and Thor1 like this.
  4. animal8324
    animal8324
    from nj
    The engine/trans alone is 1200 lbs. I think it's gonna be right around 2500lbs
    The car has damn near built itself. I havnt really struggled to find parts they have found me lol. I'm wayyyyyy lucky on this build
  5. animal8324
    animal8324
    from nj
    Today I got the chain drive mount brackets hashed out.
  6. Drmalacarne
    Drmalacarne
    Hi!
    Great project!
    I liked the big V12 engine, the chain drive solution and the original front radiator!
    I’ll follow your construction board!
    Gui
    Enviado do meu iPhone usando H.A.M.B.
  7. animal8324
    animal8324
    from nj
  8. noboD
    noboD
    Have you picked out colors yet?
  9. animal8324
    animal8324
    from nj
    A bit browner version of red gold and cream.
  10. noboD
    noboD
    Cool, looks like an old color.
    loudbang and Stogy like this.
  11. animal8324
    animal8324
    from nj
    Yup. That's a color chart from the murphy coach building company for the 20's
  12. seb fontana
    seb fontana
    from ct
    You have the differential up side down?
  13. animal8324
    animal8324
    from nj
    I hope not. I'll double check tommorow
  14. animal8324
    animal8324
    from nj
    It appears as though it is. Thank you for pointing that out. I think center section can get flipped within the case so it should be an easy fix but i'm glad you caught it now. Thanks homie
  15. atch
    atch
    If you flip the innards and leave the case alone will there be a fill or drain plug in the wrong place?
  16. Stogy
    Stogy
    @animal8324 as a matter of concern those cinder blocks are worrisome as supports, even 6x6s, 4x4s or 2x4s solidly tied together with no hollow spots in approx 10"x 10" or more to eliminate tipping would be safer...adding the fact this is a weighty beast. I want you to enjoy the fruits of your craftsmanship which is like so many here...darned awesome...thanks for sharing your interesting journey in go fast...;)
    There is a very good Thread on homemade stands...I will see if I can find it and post a link...
    Update...I did a search and what I was thinking of is called cribbing which seems more a tires on support rather than a jack stand which is actually not what you require. You could still use them under the frame shimmed with additional added wood to suit but good robust jackstands may be the best answer...
    VANDENPLAS, lemondana, ski and 5 others like this.
  17. 64 DODGE 440
    64 DODGE 440
    from so cal
    Also before you get too locked in, the pinion is usually below center of the axle so that may need attention.
    41 GMC K-18, seb fontana and loudbang like this.
  18. animal8324
    animal8324
    from nj
    I could always just run it in reverse lol.
  19. 62pan
    62pan
    Well at least I'm not the only one with Oh **** moments. Looking good though.
  20. animal8324
    animal8324
    from nj
    If ya don't try ya dont **** up lol.
    Surprising this is the first real hiccup in this build that may require cutting something apart
  21. seb fontana
    seb fontana
    from ct
    Because its a Dodge:D
  22. RodStRace
    RodStRace
    Funny, a Chebby
    or Ferd
    would do that too!:D
    At least most anything that would handle a torque number from that engine.
  23. noboD
    noboD
    If that's the only OOPS you have it's no big deal. I am still impressed with your design.
    41 GMC K-18, loudbang, Thor1 and 2 others like this.
  24. animal8324
    animal8324
    from nj
    It wound up being a cut apart fix! No biggie though I can weld.
  25. 1-SHOT
    1-SHOT
    from Denton
    Good save
    41 GMC K-18 and loudbang like this.
  26. animal8324
    animal8324
    from nj
    Fixed lol
    Glad ya caught that Seb Fontana
    VANDENPLAS, cactus1, pwschuh and 12 others like this.
  27. ratrodrodder
    ratrodrodder
    from Boston
    Who can school me on what the giveaway was that the diff was topsy-turvy?
  28. seb fontana
    seb fontana
    from ct
    Ring gear facing the wrong way.
    48fordnut, ratrodrodder and loudbang like this.
  29. seb fontana
    seb fontana
    from ct
    No charge!!
  30. animal8324
    animal8324
    from nj
    Back to progress.
    Wheels are on.
    Seat bracket is coming together
