Hot Rods 1961 Falcon Fun Factory
Discussion in 'The Hokey Ass Message Board' started by fadingfastsd, Nov 24, 2020.
Tags:
  1. fadingfastsd
    fadingfastsd
    Any recommendations on cool steering wheels? Thinking a wood wheel from a Mustang maybe?
  2. fadingfastsd
    fadingfastsd
    Also, probably a stupid question. When you install an export brace, do you cut out the 2 factory cowl to shock tower braces? Or do you just put the new brace over them? I've seen it done both ways. Definitely don't like the look of having both in place, but is there any benefit to leaving the old braces there?
  3. deathrowdave
    deathrowdave
    from NKy
    I think you need is a Monte Carlo bar if I remember correctly . It goes from side to side at the shock towers . The braces you are speaking of bolt into the Mustang Ch***is , the are welded into the Falcon and Comets . I would not remove the welded in parts and replace with bolted in parts . The Mustang is a tad bit wider that the Falcon , be sure you are getting Falcon parts also .
  4. To tell the truth, with the Monte Carlo bar I wouldn't worry about the export brace.
    As to the steering wheel, when Ford made the change from generators to alternators in '65 they changed the steering column also, so a '65-up wheel won't work. You need a '60-64 wheel. A 64 1/2 Mustang wheel will work, but not a '65 one.
  5. fadingfastsd
    fadingfastsd
    Thanks dudes! I appreciate all the help. Ordered just the Monte Carlo bar for now. I'll look for a new wheel and find something cool soon.
    Got my Procar seat rails put on the seats, and started mounting the bases.
    Also got my new headliner in. These are ****py pictures using the flash on the camera, it's not wrinkled as bad as it looks here. I'm going to hit it with a steam iron and maybe heat gun tomorrow to shrink it a bit, should pull in a bit tighter.
    I put the headliner in without removing the front/rear gl***. It's definitely possible and works OK, but not as good as removing the gl***. May redo it in the future, but good enough for now, considering the new headliner was free. I used alot of DAP Weldwood contact cement, that stuff works great. I don't think I'll have any problems with it coming loose.
    Now gonna finish up my seats, and onto the next projects. More updates later.
    Accidentally picked up this killer 1971 Moto Guzzi Amb***ador with a Velorex sidecar yesterday, so that might take some time! haha
    goldmountain and mctim64 like this.
  6. gimpyshotrods
    gimpyshotrods
    You don't need to install an export brace. Your car has one built in, from the factory.
  7. DDDenny
    It doesn't have a fancy name, just a shock tower brace I made for my Nova.
  8. fadingfastsd
    fadingfastsd
    Not going to do that. Just going with the Monte Carlo bar.
  9. fadingfastsd
    fadingfastsd
    Nice looks killer!
  10. fadingfastsd
    fadingfastsd
    Haven't updated in a bit. Got my seats installed. They look great and are super comfortable, really happy with the Procars.
    Decided to put a stereo in the car as it will see a lot of daily driver service. Mounted a couple 6x9's in the package tray that fit well.
    Waiting on some new kick panels with speaker mounts should be here soon. Using a small amplifier mounted in the trunk to power them. I'm building a transmission hump mounted mini console that will mount in front of the shifter, under the dash. It will hold the head unit, my GPS speedo drive box, and the display for my EFI system screen.
    My Monte Carlo bar should be here later this week as well.
    I'm going to go with this steering wheel. I don't like the large 17" diameter stock wheel, it's just too large with the new seats.
    Going with a Grant 966. 15" wheel with walnut rim, 3 spokes in brushed stainless. I think it'll do the job.
    https://www.jegs.com/i/Grant/470/966-0/10002/-1
    More later this week after I get the console finished up.
    loudbang and brianf31 like this.
  11. fadingfastsd
    fadingfastsd
    Here was the pic of the Grant 966 wheel, meant to add that instead of the Jegs link.
  12. I'll be checking in here from time to time. Just bought a '61 myself and have similar ideas. Gonna be a fun car.
    131348479_10225082639000142_8468292505920997760_o.jpg 133580489_10225192897076525_8577193607163331289_o.jpg 133775894_10225192897036524_211244863927403804_o.jpg 132161824_10225151375198504_6136413291551720694_o.jpg 132826099_10225151375278506_6631536317906569082_o.jpg
  13. fadingfastsd
    fadingfastsd
    loudbang and mctim64 like this.
