Technical Make your own steelies? Can’t be this easy.
Discussion in 'The Hokey Ass Message Board' started by hotrodA, Nov 18, 2020.
  1. mink
    mink
    from CT
    I bought one of these hoops that you speak of but was unsure about how safe it would be to skim off 1/8” of the outer dia of the wheel center. The center lip is 1/8 to begin with. Skimming it on the lathe would leave 1/16. Some said that I need to press fit the parts.
    I was wandering what wheelkid did, wandering if he had wheel hoops specially made for center to slip into
    Would be nice to know, most of the rims I find are pitted on the inside
    Outback likes this.
  2. BTTT
    Just Gary likes this.
  3. glrbird
    glrbird
    Roundly - Roundy racers have made their wheels that way for years. Bolt them on the front and use a dial indicator to true them up
    Outback likes this.
  4. rusty rocket
    rusty rocket
    I built these for my sons Rambler. Took the center out of the stock rambler wheel so we could use a rambler hub cap and then used a junkyard white spoke hoop. No need for a dial indicator I made a steel pointer clamped the the c10 truck arm that we used for locating the rear end. Rotated the wheel until the hoop touched the pointer all the way around. Easy peesy 5F2C1F0D-8EAC-416F-BE34-4495CEE91028.jpeg 546F1AC6-73EA-477A-ADDD-D659853B1F35.jpeg 27560950-7613-4966-83E6-95602C290338.jpeg
    Tman, Tim, AHotRod and 1 other person like this.
  5. Dedsoto
    Dedsoto
    from Australia
    Tman, RMR&C and fauj like this.
  6. tnich123
    tnich123
  7. RMR&C
    RMR&C
    from NW Montana
    The hoops were used aftermarket 8 lug white spoke 16" wheels I cut the centers out of. Don't know the mfg. I welded the centers in after truing them as shown above
    Tman likes this.
  8. Magfiend
    Magfiend
    I need 18" hoops with a center diameter of 16.75"...
  9. The place I had my '56 wheels done used a FWD hub/bearing, a chunk of a tape measure and a bent welding rod as a pointer. He had a head of a 2-3lb sledge hammer to tap the hoop around, measured the offset, spun it to check runout, welded it and rechecked runout. The key was to have a snug fit between the hoop and center so it would stay tight on it's own.
    I went to the wrecking yard to find stock used wheels that where close to the i.d of the stock wheels I had.
    I'm thinking something like this. Buy a cheap aftermarket hub (or pull a good used one from a junkyard), mount it to a small table (banjo bell, grinder stand...), drill and tap the center and knock out the studs. Screw in a piece of all thread into the center and use a large flat washer with a wing nut to hold the wheel center in place. Use a stand, old floor light or something taller to hold the welding rod or runout gauge. The biggest expense will be a hub.
    I still have another pair to do for the '28, I don't know if I'll make my own setup or have him do them. At $45 a wheel labor (a few years ago) to bust apart 2 wheels and make one, it might be worth it for me to pay.......unless I plan to do more :).
    Budget36 likes this.
  10. Budget36
    Budget36
    We have similar hubs thought out the warehouse that have fallen out of packaging (no, I can’t take one) but considering 90% of the stuff that comes through the place is of Chinese origin, I’d bet the expense isn’t like going to a dealer parts counter;)
    1oldtimer likes this.
  11. '29 Gizmo
    '29 Gizmo
    from UK
    Making steel wheels without "modern" equipment. (I was looking for the wheel vintiques logo)
    Tman and reagen like this.
  12. Flatheadjohn47
    Flatheadjohn47
    from Lewes, DE
    I used early Ford 15 in centers that have the inner nubs for the small ford caps and mated them to unknown 7 in Chevy outer s with 5 in backspacing to fit under the fenders of my 36 five window using a 1966 ford f100 rear end. Worked out well—the 5 in backspace tends to narrow the overall tread width, but still uses a moderate 7 in width. Put them on a brake drum and kept moving them around until I had almost .010-.020 runout—welded backside and ran them. Flatheads Forever!! CC3CAAD9-3310-4AAC-9E3E-45BC565FA94B.jpeg EA242A20-5730-4FD6-80B5-D334F3FBDDC3.jpeg 376124A3-F5E9-42DC-B624-FB385C6D9DD8.jpeg 3F075563-9A1D-4856-893A-4B5188C87DC3.jpeg 36707A4F-D452-43B5-9102-89D514B1346B.jpeg
    reagen likes this.
