Hot Rods The 'General Mischief Coupe' Model A build
Discussion in 'The Hokey Ass Message Board' started by Jethro, Jan 3, 2020.
  1. 29Roadie
    29Roadie
    Looking really great! Nice job on the tunnel. You're making serious progress on that floor.
  2. Jethro
    Jethro
    That's why I made the drivers floor panel removable , in case the hole is too small I can make a new panel to replace it with a bigger hole for my fat hands
  3. Nice progress!
  4. OFT
    OFT
    Perhaps roll matching stiffening beads in it after making it larger? (I agree with @dumprat in that it needs to be larger).
  5. 29Roadie
    29Roadie
    Have you thought about welding a couple of little tabs to the master cylinder lid so you could lift it off easy. One for your thumb and one for your finger. You wouldn't need much. I'd like to keep the hole in the floor about that size if I could.
    I made a little cover for mine with a flange that hooks under the floor on one side then a screw holds it down on the other. There's not much to it. The edges of the cover are slightly rolled down around the edges that don't have the flange so it fits tightly down.
  6. Jethro
    Jethro
    At this point I'm not going to fret over it . I've tried removing the M/C cover and I can do it without trouble. When I do finish it , I can redo the drivers piece if needed.
    Right now I'm moving on. I started to replace the roof wood. I took out all the old wood and surprisingly most was not in too bad shape. The ends of the header are rotten and the tips of the side pieces have a little dry rot too. I could probably get away with the side pieces but the header needs love. About ten years ago I bought a roof wood kit at a swap meet. It looks like a homemade kit but it seemed to be fairly well done. Well I started to put it all together and it's not very good at all!. I've been sanding and chiselling and saying bad words. I am going to give it another try today but I may just end up getting a kit or at the very least a new header. It's all getting covered anyway so my poor woodworking won't be seen , but I need the header to be accurate or the rest won't fit worth ****.
  7. Jethro
    Jethro
    Now I know why Henry got into the charcoal business. What a pile of work making these pieces fit!
    I was able to keep and reuse most of the hardware except for those stupid square nuts! I replaced all the nuts with regular hex and I used those flanged looking locknuts on the 5/16 carriage bolts 'cause I had them. I am fortunate to have a big belt sander and bandsaw so reshaping the header went better than I anticipated. I used black polyurethane stain on all the pieces and painted the carriage bolt heads black. I POR 15'd the metal behind everything I even managed to POR15 my hair and back of my neck. Washing your head with gun wash is a special task I don't want to do again. I'm glad to get that out of the way , I have learned to hate woodworking. You'd never know that I used to enjoy it. 20201203_150932.jpg 20201203_151005.jpg 20201203_151010.jpg
  8. dumprat
    dumprat
    from b.c.
    Por 15 for hair dye is a trick I will have to try!
    Stogy, OFT and loudbang like this.
  9. LS1
    LS1
    from us
    Awesome build, gotta love those 30-31 coupes!
    Stogy and loudbang like this.
  10. Duke
    Duke
    Looking good, if it makes you feel any better I spent hours getting the wood kit I bought to fit!
    chryslerfan55, Stogy and loudbang like this.
  11. loudbang
    You are correct from what I read there was all those pieces of cutoffs and packing crates leftover and being thrifty (cheap) he looked for a way to make money off them. Teamed up with someone named King and that is why we have Kingsford charcoal today. :)
  12. Just catching up on this now Jethro, love the build. Your work is top notch!
  13. 363wcpe
    363wcpe
  14. Jethro
    Jethro
    Not a lot of progress I've been fitting the decklid and I made a trunk holder upper. I've had the decklid off and back on at least 20 times trying to get to fit right. Still fighting with it but its getting better. 20210104_125517.jpg
    chryslerfan55, -Brent-, brEad and 6 others like this.
  15. Duke
    Duke
    So what is the trick to get them to fit?
  16. Jethro
    Jethro
    Let me know when you find out
  17. Bugguts
    Bugguts
    Great job so far. You do a great job showing and explaining all that you’re doing. Thanks for giving me some inspiration on a cold winter night.
  18. Duke
    Duke
    A bigger hammer?
  19. Jethro
    Jethro
    So I started to work on the inside of the trunk. I made a framework out of some light wall 3/4 square tubing ( a backyard gazebo gave its life for it)and made a skin to go over it. I formed another piece to go at the back and mount the trunk latch striker. Once I get the battery mounted and all together I will have maybe enough room for a six pack and a light jacket and a tool roll, no room for my crybaby doll and drive in tray with plastic hamburgers.
    I made my flip top gas cap mount and cut the hole for it. 20210110_132056.jpg 20210110_132111.jpg 20210110_132320.jpg 20210110_132416.jpg
  20. Jethro
    Jethro
  21. Jethro
    Jethro
    I've had this gas tank for a while. I originally made it for the coupe back when I made the fuel injection setup for the 292 I was going to use. It was not quite right for what I'm doing , I had to relocate the filler and while I was at it I POR15'd the inside and gave it a coat of bedliner. I needed some straps to hold it in place....here's where I make a short story long.
    I needed some material to make up the straps. Nothing in my junk pile , chicken coop , my neighbours junk pile...nothing! I was getting ready to cut some strips from sheet metal s****s that I had laying around but none were long enough to work....UGH! OK , I'm done for the day , production stops right now. Go in the house and have a coffee then take a walk down to my well just to check if I have any suicidal mice taking a bath. Instead of going the most direct route my dog wanted to take me along the train tracks just to change things up . Sometimes I find odd s**** metal bits that I can use....spikes , plates, pins etc. Well I came across what was EXACTLY what I was looking for. It was 1-1/4 steel strapping that they used to bundle rail ties together. I rolled up a piece that was about 10 feet long and took it home. I think my dog knew what I needed and took me there.
    So , I cleaned it up , cut it to length , made bolts and drilled and folded the strap. I used my spot welder to hold it all together. I bought it for $139 at the Canadian Harbour Freight , Princess auto! LOVE IT!!!
    Anyway now I have a tank and straps , one more thing off the checklist. 20210117_114625.jpg 20210117_114646.jpg 20210117_114835.jpg 20210117_115328.jpg 20210117_115528.jpg 20210117_115649.jpg 20210117_115854.jpg 20210117_115953.jpg 20210117_120038.jpg
  22. Jethro
    Jethro
    Been working on the firewall and transition from the hump to firewall. I spent the better part of 2 days making the transition piece. I ruined a lot of cardboard and made a bunch of useable sheet metal too small to use. Moving on to the toe pieces soon. 20210123_151342.jpg 20210123_151327.jpg 20210123_151725.jpg
  23. Jethro
    Jethro
    Got the toe pieces finished and made the pedal holes thingy. I just need some pedal seals. I finished the removable trans hump and cut the hole for the throttle and mounted it. I think it's going to work fine. My feet can touch each pedal without touching each other. As long as I don't wear big gumboots I should be good. 20210131_114451.jpg 20210131_114415.jpg 20210131_114437.jpg 20210131_114510.jpg
  24. Jethro
    Jethro
    OK , today is the day I become a man.....again! Some are going to give me grief about it but I am chopping the roof 3 inches. I know East coast style , channel and no chop is a cool look but after a lot of soul searching I just need to chop this thing to be happy. I kind of think about poor old Frankenstein. He's not a bad looking guy , some better clothes , proper shoes and he would clean up pretty good. His biggest drawback is he has too much forehead. Lots of good looking guys rock flat top haircuts , poor ol Frank just needs his forehead lowered a bit. He'd look like a 60's movie star with a bit of a makeover.
    So , General Mischief is getting his forehead lowered today! 20210204_100443.jpg 20210204_100506.jpg 20210204_102853.jpg 20210204_102906.jpg 20210204_103201.jpg 20210204_103812.jpg 20210204_103826.jpg 20210204_120303.jpg 20210204_120324.jpg 20210204_143717.jpg 20210204_143732.jpg
  25. RMR&C
    RMR&C
    from NW Montana
    Go man go! Looking better already....
    oliver westlund, loudbang and Stogy like this.
  26. Duke
    Duke
    Excellent!!
    chryslerfan55, loudbang and Stogy like this.
  27. brady1929
    brady1929
    Cool hot rod.
  28. Blues4U
    Blues4U
    from So Cal
    Just fond this thread, wow, what an awesome build! Just fantastic fabrication and workmanship.
  29. 29Roadie
    29Roadie
    Nice going! I like it! You're making great progress too.
  30. Jethro
    Jethro
    Still finishing up the welds and grinding but I had to see how I'm going to fit. I took out the bracing and put in my seat ( speedway bomber style) With the bottom cushion in place I've got about 1 inch of clearance top of my head to rear wood crosspiece. Plenty of room! I am going to trim the seat cushion a bit just to maybe get another 1/2 - 3/4 for those hard bumps!
