Projects I'm 18 and building my first flathead 59AB+merc crank for my chopped 34 4 door sedan
Discussion in 'Traditional Hot Rods' started by Jesse Borba, Nov 20, 2020.
  1. Jesse Borba
    Jesse Borba
    I'll talk to my dad about it tonight I could probably make that work lol.
    winduptoy and Stogy like this.
  2. tubman
    tubman
    I'd p*** on the pumps.. If they're off a 221, they have to be the early ('37-'48) pumps which are inherently inferior to the 8BA pumps (remember, this guy has a later Merc) and there is an extra hole that has to be plugged and they require an oil p***age from the engine for lubrication. Unless of course, they are the real early pumps that bolt onto the heads (those were 221's too) in which case this is an absolute no go.
  3. Budget36
    Budget36
    Well, the pumps came off a 221 Pilot engine made in the late 40's, I pulled pumps from a late 30's FH for the 221..
    So what do you think the differences are?
    Impellers looked to be the same to me at the time, visually without measuring
    But, regardless if you order a water pump for a FH V8, do they specify for 221 v 239?
    If so, what the heck is the difference?
    BTW, these were the engines mount as well.
    chryslerfan55, Jesse Borba and Stogy like this.
  4. tubman
    tubman
    Well, the pumps will bolt on, and the impellers are about the same size. However, that is not the only difference. Here are the best pictures I can find in a hurry. Notice the gasket for the 8BA pumps :
    See the extra water p***age at the very top? Now look at the gasket for the earlier pumps; they are missing that water p***age.
    In addition, the earlier pumps have bushings that are lubricated by oil from the engine, while that later pumps have sealed bearings which are much better. The later blocks do not have the p***age to supply oil to the early pumps.
    Although they will bolt onto the engine (if you plug the extra p***age in the block) and function, I don't believe it's a good idea to use them for several reasons, a**** them, a poorer impellor design (unless they have been modified with improved impellors) and the lubrication problem.
    If you need water pumps with the engine mount, you can use '49-'53 truck pumps, or '49-'early '51 Mercury pumps with spacers. As to Pilot pumps, I am really not familiar with them, so they may be different, I don't think they are different, but really aren't relevant here for someone building an engine in California.
  5. Jesse Borba
    Jesse Borba
    Thank you that is super useful information.
    chryslerfan55 and winduptoy like this.
  6. nobby
    nobby
    did you get the crank shaft twin belt pulley
    the upper generator mount
    and the fan and hub
    plus have you got an 8ba half bell, starter plate and oil pan
    Jesse Borba likes this.
  7. 51504bat
    51504bat
    If you need water pumps with the engine mount, you can use '49-'53 truck pumps, or '49-'early '51 Mercury pumps with spacers. As to Pilot pumps, I am really not familiar with them, so they may be different, I don't think they are different, but really aren't relevant here for someone building an engine in California.[/QUOTE]
    FYI: Truck pumps are wide belt so you'll need a wide belt crank and generator pulley (or alternator)
  8. Budget36
    Budget36
    @tubman great info, damn. I can’t give this stuff away!
    redzula, winduptoy and Jesse Borba like this.
  9. tubman
    tubman
    Everybody would be better served if those pumps went on a proper early engine.
    I'm surprised you haven't received a request or two already.
  10. nobby
    nobby
  11. Budget36
    Budget36
    I’ve had 3 folks “coming by” to pick things up from the pay it forward thread. I still have it all;). Unloading the trailer today and going to load it for a s**** run.
    Darned shame to toss this stuff, but have no recourse
    chryslerfan55 and Jesse Borba like this.
  12. 48fordnut
    48fordnut
    It is. I had a o/p pick up a r/e for me so he could take the open drive off and send it to me. The o/p had it listed for several weeks.
  13. Jesse Borba
    Jesse Borba
    The crank did not have a pulley and I have no bell housing or anything. I have the oil pan, fan, and generator though
  14. Boden
    Boden
    Hey man,my name is Boden. I’m 15. I built a merc flatty just like yours. It’s in my 53 customline. I work at a machine shop in New York. It’s bored .040 and it’s got a old school dirt track cam, rare sharp bonneville heads, and a offy dual. Ported and relieved, adjustable Johnson’s. And it runs amazing. Here are a few pics. I got a [​IMG]set of high compression eab heads like stated earlier. If you’re interested then send me a pm. Got lots of parts for these motors so let me know. Happy to help any way I can. [​IMG]
  15. Jesse Borba
    Jesse Borba
    That's a good looking motor! Thank you for the offer I have a pair of Evan's heads that I picked up that have some damage from electrolysis that I'm going to eventually get repaired that I will probably run on it. I've been looking for an Evan's intake so it will match the heads. Once I get my motor completely apart I'm going to look into more parts for it so I'll keep you in mind.
    Sent from my SM-J727V using The H.A.M.B. mobile app
  16. Boden
    Boden
    Sounds great! Don’t hesitate to ask anyone here any question you have. Everyone here started somewhere and there’s a good chance they had ur same exact question at one point. If we didn’t want to answer ur question we wouldn’t be here in the first place!
  17. Jesse Borba
    Jesse Borba
    I finally got some time to continue working on my flathead now that I've finished finals for this semester. I just got the water pumps and the timing cover off. The timing cover was really stuck and after finally getting it off I see why. The water jackets look pretty good from other guides and pictures I've been seeing. 1609028022355.jpeg 1609028042170.jpeg 1609028055248.jpeg 1609028255420.jpeg
  18. sloppy jalopies
    sloppy jalopies
    the bottom pic shows the dist. with its pilot shaft going into the pilot bush...
    memory says that is '49 only...
    yes it could have been changed...
    but it looks as though that block has been together for a while...
  19. Jesse Borba
    Jesse Borba
    From what I've been told it seems like it is a 49 merc and it's never been taken apart
  20. sloppy jalopies
    sloppy jalopies
    was told if you hang the forged crank on end and tap it with a hammer it should ring like a bell...
    something about holes or lack of them in the counterbalance also screams stroker !
  21. clem
    clem
    no disrespect to anyone, but the above mentioned search function doesn’t always bring the required results.
    A better option is to do a google search and type in the word hamb first.
    re; water pumps; tubman obviously knows his stuff, everything he said is correct.
    - I also doubt whether Pilot motors had the sealed bearings in the water pumps, which is what is best, (the others had cinted bronze bushes needing constant oiling), but,
    fwiw - according to a flathead guru here, the Pilot engines apparently came with factory cast headers, although I have never seen any.
    ClarkH, chryslerfan55 and Jesse Borba like this.
  22. Jesse Borba
    Jesse Borba
    Ok thanks for the info
  23. warhorseracing
    warhorseracing
    from cameron wv
    Good to see you Jesse and I hope you did great on your finals. That front cover looks pretty corroded inside along with the cam and crank timing gears. Have you got any of the pistons out yet? As corroded as the front cover is the pistons may come out in pieces. That will be OK if they do just be very careful to not break or crack any of the cylinder walls while getting them out. If you crack one it can still be sleeved but you do not need that expense. Get your Dad to guide you as he most likely will have some experience so use it. You can do this just take your time and don't rush it.
  24. Jesse Borba
    Jesse Borba
    I haven't gotten any pistons out my dad and I have been talking about different ideas on how to remove the pistons with minimal stress on the block.
    warhorseracing and chryslerfan55 like this.
  25. Aaron D.
    Aaron D.
    From the look of the rust inside that engine, you have a challenge ahead of you. Flatheads that have been sitting for a long time are a challenge to take apart to begin with. Yours looks like water was able to flood the block. Take your time getting it apart and try not to get frustrated. Last flathead I took apart took me 3 days to get the valves out! Good luck.
    Jesse Borba and chryslerfan55 like this.
  26. Jesse Borba
    Jesse Borba
    Thank you for the tip patience definitely seems like the most important tool for taking this motor apart.
    chryslerfan55 and warhorseracing like this.
  27. warhorseracing
    warhorseracing
    from cameron wv
    Very definitely and good for you talking to your Dad and getting his advice. Ask here because there are alot of people here watching your progress. Give a couple of days in case some guys don't get on here all that often and they have knowledge.
  28. Rocky
    Rocky
    Classified Editor
    Last flathead I took apart took 3 months to get the pistons out. I soaked them in an ATF, diesel, acetone mix, tapped on the piston tops every time I walked past it, set it on fire all for nuthin! After 3 months of frustration I knocked holes in the piston tops from underneath and carefully tapped the remainder of the pistons out. Done in an hour.
    BTW, when I was 16 my dad and I built a 53 merc motor for my 50 ford. Your 34 is far cooler than my 14 year old 50 ford. Rockysfirstshubox1.jpg
  29. Jesse Borba
    Jesse Borba
    Your 50 ford is cool too I've always loved the lines on them.
  30. Budget36
    Budget36
    The exhaust was a bit more free-flowing by the looks of them. They came off in a few pieces tho. I think I sent them to someone in Canada who was going to attempt to get them welded together
