Projects And So It Begins
Discussion in 'Traditional Hot Rods' started by Piewagn, Jul 14, 2019.
  1. Big progress! Go man go!
    loudbang and Piewagn like this.
  2. Doug Hines
    Doug Hines
    That thing looks awesome! It is so exiting when it is staying together!
    Big mike 1968, loudbang and Piewagn like this.
  3. Piewagn
    Piewagn
    Psyched to say the least! Thanks for hangin" with me!
    Elcohaulic and loudbang like this.
  4. Piewagn
    Piewagn
    Thanks Bro! Can't wait to get back to work to work on it! Converting that subframe was a bear!!
  5. guitarguy
    guitarguy
    I'm liking it alot. Looks great!
  6. Piewagn
    Piewagn
    Thanks Chad!! I'm gettin' there!!
  7. Piewagn
    Piewagn
    I woke up one morning and my right hand didn’t work! It just flopped....couldn’t lift or twist it. It was so bad I had to splint it. It’s starting to come back now, but it’s REALLY effing with my welding!
    Anyway........
    More metal work......
    I gotta say, these quarter corners suck! I’ll get it though. Got the driver side to do and finish welding up the pass side. It’s progress.....
    Thanks for checkin’ in fellas! IMG_0444.JPG IMG_0445.JPG IMG_0448.JPG IMG_0449.JPG IMG_0450.JPG
  8. koolbeans
    koolbeans
    Wall art for the man cave....
    Sent from my XT1710-02 using The H.A.M.B. mobile app
  9. koolbeans
    koolbeans
    Can I rest there is no chop in the near term future ever......?
  10. Piewagn
    Piewagn
    I may do a mild 3".......well see......:D:D
  11. Piewagn
    Piewagn
    More progress! Got the quarter corners done .....for now. Im pretty sure I have a remedy for the gap issues floating around in my head; we’ll see when I get the deck lid hung....that’s all for now folks.....happy healthy holiday to all!!
  12. Piewagn
    Piewagn
    Well, got the rear panel gaps where I’m happy with them....panel isn’t even secured or bolted in yet, so I’m guessing they’ll improve even more! Took some measurements tonight and everything looks square! My body blocks came so I’m excited to get this mounted on the chassis.....still have a bunch to do first. Thanks for stoppin’ by fellas!! IMG_0456.JPG IMG_0469.JPG IMG_0470.JPG IMG_0475.JPG IMG_0474.JPG
  13. Piewagn
    Piewagn
  14. Piewagn
    Piewagn
    I think I can live with these gaps.....whaddya think? I made these braces to squeeze things together and add some rigidity......one set for inside the quarter and the other for the center panel.
    Another hurdle crossed!....wooo hooo!! Thanks fellas! IMG_0478.JPG IMG_0479.JPG IMG_0480.JPG IMG_0481.JPG IMG_0482.JPG IMG_0483.JPG IMG_0484.JPG
  15. Aaron D.
    Aaron D.
    Looks good. Have you tried the deck lid fit yet?
  16. Piewagn
    Piewagn
    That's next up Aaron.....I've got the skin here in my garage and I want to reskin it first......coming soon!
    Thanks Man!!
    Jeff34 and loudbang like this.
  17. Piewagn
    Piewagn
    The old triple panel trick! This thing is FUGLY? These people make things worse than they have to be....and there’s BRASS to boot! Moving along though, have to make a patch for the bottom corner, but relatively speaking, the inner structure is in great shape! I have a brandy new skin, so it should turn out nice! Thanks for checkin’ in fellas!! IMG_0488.JPG IMG_0489.JPG IMG_0491.JPG IMG_0492.JPG IMG_0490.JPG
  18. Aaron D.
    Aaron D.
    That inside does look good!
  19. Piewagn
    Piewagn
    Inner structure is nice.....only needs a small patch in the lower corner!
  20. loudbang
    Too late now but to take sections off doors etc. with layers like that we used to run a grinder along the edges of the doors or whatever and remove just enough so you can see all the layers. Then they would separate fairly easy then removing the strips with the spot welds was easy just grab one end in visegrips then roll along the edge rolling them up like spagetti the welds USUALLY just pop apart.
    rusty valley and brEad like this.
  21. Elcohaulic
    Elcohaulic
    [QUOTE="Piewagn, post: 13826984, member: 78402) Converting that subframe was a bear!![/QUOTE]
    But it will be so worth it!
  22. Piewagn
    Piewagn
    Didn’t quite get to the skin today, but I did manage to fix the inner structure.....It’s not gonna be a show stopper....just a nice driver that I can drive the wheels off of!! I also made an Inner fender brace. The small original section is all that was left on the right side.....I could only find them in pairs and I wasn’t spending that much money on a pair of new ones.....happy Friday everyone!!
    Happy Friday! IMG_0499.JPG 62881044230__E71080DB-9DBE-4CC8-BD48-CFD2ABAFBA26.JPG IMG_0501.JPG IMG_0495.JPG IMG_0496.JPG IMG_0497.JPG
    brEad, Vic Walter and loudbang like this.
  23. Piewagn
    Piewagn
    The issue was the screws and the brass OVER the screws.....where I could, I DID grind the edge off and popped the spot welds like you said.....that one edge was just too much of a mess! :D
    Thanks for the input LB!!
  24. Piewagn
    Piewagn
    But it will be so worth it![/QUOTE]
    Oh....it was in the end! Saved me a TON of dough....AND I got an education to boot!:D
  25. Mart
    Mart
    Nice repair work, Piewagn. Mart.
    Runnin shine and loudbang like this.
  26. Piewagn
    Piewagn
    Thanks Mart! Always nice seein' you around here!
    Mart and loudbang like this.
  27. Piewagn
    Piewagn
    Got the deck skin started then ran out of welding gas....it was going nice and smooth too....still have some spot welds to do and fold over and hammer and dolly the bottom edge....thanks for stoppin’ by fellas!!
  28. Piewagn
    Piewagn
    Deck skin came out nice...got the lower lip nice, just a swipe of filler and it’ll be good. Just have to knock down some of the spot welds. I haven’t decided on which hinges yet.... I got a set of chrome external hinges, think of using those, or the hidden conventional hinges.....OR, go with the rumble hinges. Whaddya think? Any input would be appreciated! Thanks fellas! IMG_0485.JPG IMG_0521.JPG IMG_0519.JPG IMG_0517.JPG IMG_0516.JPG IMG_0515.JPG
    loudbang, waxhead and brEad like this.
  29. I like the external hinges. Deck lid looks like it came out well.
    loudbang, Runnin shine and Piewagn like this.
  30. Piewagn
    Piewagn
    Thanks bread! I'm leaning toward the external hinges as well....I think it just adds a little "something"!
    loudbang and brEad like this.
