Technical What did you do with your car today? * NEW*
Discussion in 'The Hokey Ass Message Board' started by j hansen, May 3, 2020.
  1. Paul
    Paul
    Editor
    '60's Dodge isn't it?
  2. gimpyshotrods
    gimpyshotrods
    '62-'64.
    Paul likes this.
  3. j hansen
    j hansen
    mad mikey and LAROKE like this.
  4. vtwhead
    vtwhead
    Putting the final touches on the full Buick brake set up on the '31. Still a bit of machining left to get everything lined up. Missing some parts in my brake kit, not surprising at all
    Lil32, mad mikey, LAROKE and 2 others like this.
  5. NWRustyJunk
    NWRustyJunk
    They're a Dodge Full-sized produced from 1962 to 65. Was replaced by the Monaco.
  6. Elcohaulic
    Elcohaulic
    Going out for a drive. They will be salting the roads soon... Once the salt comes out my car goes in.. I saw what the salt/calcium to my car cruise buddy's car. It got under the chrome and ate holes in those fenders like you wouldn't believe. The car was from Texas and never experienced salt. I'm guessing there was a lot of exposed steel under that chrome and that gave corrosion a big fat welcome sign..
    I also spray the inner fenders, rockers, frame. with spray grease.. I use laniolin base grease where rubber bushings are. The grease will also eat rubber..
    61Cruiser and Lil32 like this.
  7. 65pacecar
    65pacecar
    from KY, AZ
    David Gersic, Oilguy, Lil32 and 7 others like this.
  8. impala4speed
    impala4speed
    Lil32 and 65pacecar like this.
  9. j hansen
    j hansen
    Bought my first part cleaner,,,it is time for some serious cleaning:) IMG_9324.jpeg
    40two, Lil32, mad mikey and 3 others like this.
  10. blowby
    blowby
    from Nicasio Ca
    Bought this at the Dollar Tree. Just a gift bag/box but has appropriate décor. 20201204_131600_resized.jpg
  11. jimmy six
    jimmy six
    8425384E-B75C-41EB-AAA8-979AA672A8EF.jpeg 01BCB86F-65C0-4526-A128-DCEE5DC12D27.jpeg [/QUOTE]
    The Rupp Chaparral is done as far as I’m concerned now I just need some great grandchildren to run around on it. Probably need to by gasoline at the pharmacy to use. Even with my 6’1” frame and 190 pounds I can still run it wide open breaking the speed limit in front of my house.
  12. Poverty cap
    Poverty cap
    I cleaned up my valve covers a little more today and sealed them with PPG epoxy primer, I used the heat lamp on them for a couple hours, sanded the nubs out of them with 600 grit. I let them sit for a while longer then sprayed them with black base coat and clear coated them. FE05AEF4-9E7C-4719-8C1F-C01D8A950A67.jpeg 1889C053-AC27-4744-9514-10482F41F16F.jpeg BBCD075B-CE5D-4FEC-9BF5-B86E13DAEFAD.jpeg
  13. impala4speed
    impala4speed
    ^^^ Those came out great!
  14. 65pacecar
    65pacecar
    from KY, AZ
  15. Norris McCarty
    Norris McCarty
    Worked out and installed a PCV valve system on my 53 Merc flathead in my coupe.....works great.
    Elcohaulic, 61Cruiser, blowby and 9 others like this.
  16. Mike Miller
    Mike Miller
    Started laying out the instrument panel for the 56 wagon. DSCF5358.JPG DSCF5359.JPG DSCF5358.JPG DSCF5359.JPG DSCF5360.JPG DSCF5362.JPG DSCF5363.JPG
    LAROKE, j hansen, Lil32 and 1 other person like this.
  17. Poverty cap
    Poverty cap
    I installed the valve covers I painted earlier in the week. AC323BDC-AB67-4ADE-89FD-1C9010525A53.jpeg
    LAROKE, Blues4U, Elcohaulic and 9 others like this.
  18. trevorsworth
    trevorsworth
    I really needed to do something, and I'm kind of out of things to do, so I went out and unbolted the connecting pipe on my flathead. Can't wait for real hot rod headers. Reminds me I need to get the water system sorted out so I can really run it.
    Lil32 likes this.
  19. jimmy six
    jimmy six
    I’m a 56 guy but I just don’t think I could get use to looking at diamond plate all the time...
  20. jimmy six
    jimmy six
    Decal sets it off nice... I like a black engine... there’s a thread about guys not liking them but they look good to me especially with an natural aluminum manifold.
  21. gimpyshotrods
    gimpyshotrods
    Finished the wiring in my shop, except connecting the whip to the CNC mill. The calibration service will take care of that.
    bymanr, TrailerTrashToo and Lil32 like this.
  22. bymanr
    bymanr
    FE984EF4-DDD9-4882-94F5-D93344FA6F6C.jpeg Took my better half for a short ride, it was her idea!!! LOL
  23. junkyardjeff
    junkyardjeff
    Took the sunliner out for a test drive trying to determine what is wrong with the used trans I just installed,when I got back to the garage and while adjusting the idle that engine is too noisy and will step up the process to put the Y block back in. The 351-W I have in it was not built with the cam I wanted and most likely just slapped togather with mismatched parts so time to start over.
    Lil32 likes this.
  24. Caprice89
    Caprice89
    I am sorry, but you are what?
    Today, I made a deal with my son, we should do more work on the cars. He motivated me to get our**** in gear and start building again. I love him :)
    Sent from my online shouting device
    stanlow69 and Lil32 like this.
  25. trevorsworth
    trevorsworth
    Out of money would be a better way to put it. :) Got lots to do but I have to let my bank account take a breather.
  26. Caprice89
    Caprice89
    Ah ok. Yeah, that can be a bit of a bummer. Been there.
  27. jimmy six
    jimmy six
    Finished the base under dash panel for my AC. Tomorrow the 1/4” padding and peacock vinyl. Took way more time to fit and cut the holes than I thought it would. FF686233-33BD-4709-BC62-5F877A635787.jpeg
    Blues4U, X-cpe, saltflats and 3 others like this.
  28. mopacltd
    mopacltd
    Took the O/T Plymouth to a Toys for Tots car show in Wickenburg, AZ
    bob b. and Lil32 like this.
  29. Elcohaulic
    Elcohaulic
    I cleaned the garage out and hosed the car down with hot water. Put it in the garage and set the de humidifier on hi 40 for the weekend. Its clean and dry now.. I'm replacing the gas tank and changing the ignition on the 454 to Points/Vertex CD box and installing a mechanical tack. I'm hoping I can mount it on the steering wheel. I'm hoping to find a nice black bench seat so I can take the buckets out. I just love the look of a bench seat with a Hurst floor shifter in a el Camino..
  30. WTF really
    WTF really
    Got the frame stripped and ready to take to the blaster. 20201206_161216.jpg 20201207_125040.jpg
    j hansen likes this.
