Projects 1917/1928/1938 American Lafrance Plymouth V12 Speedster
Discussion in 'The Hokey Ass Message Board' started by animal8324, Nov 17, 2020.
  1. 1-SHOT
    1-SHOT
    from Denton
    This is going to be good.
  2. ratrodrodder
    ratrodrodder
    from Boston
    Aha! Thanks!
    Stogy and loudbang like this.
  3. RodStRace
    RodStRace
    Animal, have you found a good source for the chain/sprockets?
    I'd look for something that is understressed (overkill) to prevent any issues, even if it meant loosing a few HP in drivetrain friction.
    Found this sizing chart...
    https://www.usarollerchain.com/roller-chain-size-chart-s/4869.htm
    That #160-1 is 6.3 pounds per foot! :eek: I couldn't bring myself to look at the pricing!
    I wonder how often they get calls from guys wanting to outfit a chain drive vehicle?
    VANDENPLAS, williebill, Stogy and 4 others like this.
  4. animal8324
    animal8324
    from nj
    I have some #120 chain from an original American Lafrance Chain Drive. No sprockets.
  5. RodStRace
    RodStRace
    looks like they have a selection for those too!
    https://www.usarollerchain.com/roller-chain-sprockets-s/2432.htm
    I have no connection with that company or experience with them.
    However, I'd suggest calling and picking their brains for what solutions they can offer.
    Remember, the torque is multiplied through the trans and diff, so it's BIG!
  6. animal8324
    animal8324
    from nj
    Rolled it outside today
    20201204_143831.jpg 20201204_140759.jpg 20201204_140833.jpg 20201204_140853.jpg 20201204_140916.jpg
    VANDENPLAS, SS327, 48fordnut and 18 others like this.
  7. Hate to say it, but you may want to consider adding 12-16 inches to that wheelbase- with the size/width of that radiator, your body is gonna look pretty stubby- almost like a caricature?
  8. animal8324
    animal8324
    from nj
    I don't mind them short and thick
  9. animal8324
    animal8324
    from nj
    Got my master mounted. Next up mounting rear brakes and figuring out sprockets
  10. jimmy six
    jimmy six
    I was thinking 24-36”...
  11. animal8324
    animal8324
    from nj
    Surprisingly 1928 Plymouth Brakes arn't exactly bolt on for the rear axle on my speedster.
    No bother have lathe, can weld
    Jrs50, VANDENPLAS, SS327 and 16 others like this.
  12. Drmalacarne
    Drmalacarne
    Great job!
    Enviado do meu iPhone usando H.A.M.B.
  13. chiro
    chiro
    Looks great. The jack stands are an improvement over the concrete blocks and bits of wood but larger stands would be better. Those are maxed out. Be safe bro and be careful. And...I'm sure we would all love to see some video of the engine running:D
    Andy
  14. animal8324
    animal8324
    from nj
    Here's it's test fire from a few months ago Chiro
    bobbytnm, lemondana, jaracer and 16 others like this.
  15. chiro
    chiro
    ^^^Awesome. Love it!!!
    Andy
    loudbang, Thor1 and 41 GMC K-18 like this.
  16. animal8324
    animal8324
    from nj
    Thanks. When I started the project I swore I wouldnt try starting the engine until final mockup was complete because if there was anything wrong with it it would take the wind out of my sails. ...........
    Obviously I have no self control and am lucky that the engine was in damn good shape.
  17. animal8324
    animal8324
    from nj
    Got one side of the rear brakes tacked together. Tommorow i'll knock out the other side and burn the mounts in with some 7018 stick welds.
    Note the trimmed backing plates. This is so I can mount the sprockets to the drums. 20201207_173721.jpg 20201207_173736.jpg 20201207_173957.jpg
  18. 62pan
    62pan
    Any plans for a body or just a hood and cowl?
  19. Marcosmadness
    Marcosmadness
    Awesome! You won't see another when you finally get it drivable.
    loudbang and Thor1 like this.
  20. animal8324
    animal8324
    from nj
    No way i'm covering up that V12. No cowl no hood no body
    VANDENPLAS, SS327, Ziggster and 8 others like this.
  21. animal8324
    animal8324
    from nj
  22. animal8324
    animal8324
    from nj
    Started my tank design.
    It's gonna hang around 2 inches over the mounts on each side. Have leather traps holding it to the mounts with beads rolled on either sides of the straps. The end caps will be inset about half an inch with a soldered seam
    I'm debating between copper or steel.
  23. Wow, very cool!!
  24. animal8324
    animal8324
    from nj
    Thank you
    1947knuck and loudbang like this.
  25. atch
    atch
    I don't know about structural integrity but polished copper sure would be beautiful.
  26. oldtymehiboy
    oldtymehiboy
    from Indiana
    Super Nice Young Man - Bad *** Machine
  27. ThisOneGoesTo11
    ThisOneGoesTo11
    from Oxford, PA
    I must ask: why the drive chain ?
    ....u joint technology was not there in 1917
    .....slack chain allows for vibration dampening
    .....some other reasoning
    VANDENPLAS and chryslerfan55 like this.
  28. animal8324
    animal8324
    from nj
    Great question.
    I went with chain drive because it's cool as all get out, and to run the short wheelbase I wanted a normal drive shaft configuration would be super short and have super extreme angles to the point that i'd have to limit the rear axle travel.
  29. animal8324
    animal8324
    from nj
    I decided to get sprockets 3d printed for mock up because i couldnt find any affordable steel ones that might work and think i'll have to get them custom made. 20201216_154925.jpg
    I think I have the rear figured out and am starting on the differential sprockets.
