Hot Rods A New England Channeled Roadster
Discussion in 'The Hokey Ass Message Board' started by 51box, Aug 28, 2020.
  1. TFoch
    TFoch
    Very cool project!
    loudbang and 51box like this.
  2. Jeff Pandora
    Jeff Pandora
    from Mojave
    Like the look you are going for will be fallowing the progress
  3. 51box
    51box
    from MA
    Had some issues with the nailhead in my coupe so the roadster project has been on hold. 91BC023A-E6CF-48A9-B3C6-DE655371F45F.jpeg
    The car is running again now so roadster progress will be coming. Engine and trans is mounted, setting up the rear suspension next.
    1521A46C-519D-4358-8C34-0BE37AA3D287.jpeg 853ACB2F-9E3F-4C92-9FBB-7D7BC7E65DFB.jpeg 8377C6E8-69D5-4B85-945E-4FA1AA09D150.jpeg
    WC145, chryslerfan55, Tim and 14 others like this.
  4. adam401
    adam401
    Oh yeah this is gonna be good
    continentaljohn, Stogy and loudbang like this.
  5. vtwhead
    vtwhead
  6. 51box
    51box
    from MA
    @vtwhead I did not see that, sent her a message worth a shot. Thank you
  7. vtwhead
    vtwhead
    Good luck with that. Hope you can score.
  8. 32 hudson
    32 hudson
    Subscribed and following I like the east coast channeled look being a New Englander. Butcher away as far as I am concerned to make it work for you. Great workmanship and looks good. Thanks for sharing with us.
  9. Travis latour
    Travis latour
    from Putnam CT
    woah. im in for this..
    kidcampbell71 and loudbang like this.
  10. The37Kid
    The37Kid
    Nice! Didn't Brizio restore one that was built along these lines? Bob
  11. 51box
    51box
    from MA
    I’ve been working on getting the rear suspension setup the last couple weeks and finally got it figured out. First step was to secure the rear axle at ride height and then sweep the rear of the ch***is up for axle clearance.
    I picked a suspension setup that was very compact to keep from getting into the cabin area of the floor. This is all new to me so I asked many peoples advice and did as much research as I could on lengths, angles etc. There are some sacrifices due to space but it has excellent articulation. I used a Johnny joint on the axle and regular heavy bushing on the frame side for vibration. F3E59648-317B-4814-A258-BAEAB3ADB718.jpeg
    Next up was to build a K member off the trans mount with some pre bent tubing I picked up. AFB188F1-A0A3-4E33-936E-AC7F2D908DCB.jpeg
    Then moved on to the front end, I had this old dropped axle for a while and used it with a nice original spring and shackles. Offy headlight stands with nice set of king bees I picked up off the HAMB. 346673D1-9D55-4AA9-8CDF-A8C8C63BA4FA.jpeg
    Had to do a mock up for a good stare session today.
    That’s where she stands as of now, I need to make some sub rails and get the body mounted securely soon.
  12. Shadow Creek
    Shadow Creek
    Fantastic work:cool:
    Stogy, 51box and loudbang like this.
  13. brianf31
    brianf31
    Lookin' good!
  14. vtwhead
    vtwhead
    Really like your progress. Looks great.
    Did you ever hear from that Cad lead ?
  15. waxhead
    waxhead
    from West Oz
    Love the stance.
  16. joew513
    joew513
    from Boston
    Sweet build
  17. 51box
    51box
    from MA
    Thanks guys I am very happy with how it’s looking, makes me smile every time I walk in the garage. @vtwhead i never heard back on that marketplace listing, someone got a great deal.
  18. wheeldog57
    wheeldog57
    Jeez Joe, that sits perfect!
  19. rod1
    rod1
    Sweet.
  20. satts
    satts
    Really like the rear set up. Used that similar set up on circle car setup. Really hooked up
    rod1, Stogy, 51box and 1 other person like this.
  21. wheeltramp brian
    wheeltramp brian
    Those caps are the best
  22. 51box
    51box
    from MA
    I decided to try and make my own driveshaft after talking with a friend of mine that has done it a few times. Ordered up some ****er weld yokes and a piece of 2” .120 DOM. First it is critical to have the yokes in line so I clamped them down to this heavy box tube and put one tack weld on each end. ABF7EB64-73BC-49E7-B8BF-DBB3D0AD421F.jpeg
    Next up installed the u-joints and bolted it in. I got both ends to within .002 with 4 tack welds on each. Then welded it all the way around in one p***, allowing to cool on its own. I was out a little bit after welding and did a couple heat shrinks with the torch to bring it back down to .001-.002 . We’ll see how it feels but I don’t think getting it balanced will be necessary.
    Moving on to getting the firewall chopped up to fit, there are many more hours of work ahead to finish it but at least I have some direction now.
  23. 51box
    51box
    from MA
    Firewall was a bit of a challenge, after sectioning it 6”s I had to fix a bunch of cracks, fill holes and transition the beads into the lower portion. 232B0D6B-2984-40C9-9CEB-22E40066F6EB.jpeg
    Once it started to take shape, I swapped the firewall feet side to side. Now the bolts are on the inside because it just lined up better with the narrowed frame.
    I had contemplated making the firewall bolt in to save some h***le, but really wanted it to come together with the body like it was supposed to. Came up with these simple mounts on the ch***is to utilize the original style mounting.
    Made up these basic but pretty stout rear shock mounts out of some old wishbone pieces and aftermarket shock studs. A51EAB8E-C143-49AF-8182-D80FDEE02A8F.jpeg
    Working on sub rails and building the floor next.
  24. TFoch
    TFoch
    Looking good!
  25. AHotRod
    AHotRod
    Beautiful craftsmanship .... & creativity
  26. 51box
    51box
    from MA
    I’m looking for a 35-6 roadster/ Pheaton glovebox door if anyone has one or knows of one for sale I’d appreciate it. CC05D7BA-DF29-4223-9269-4FEC86581903.png
  27. 51box
    51box
    from MA
    I was able to make some new sub rails by bending some 18ga over the edge of my table into a Z and then using the shrinker / stretcher to match the shape of the ch***is. Also started on floor bracing and tunnel work out of 18ga to see if it was strong enough and it seems like it will work good. 1EB5DEBA-9052-46C0-8756-05D98FEC9595.jpeg
    continentaljohn, WC145, brEad and 8 others like this.
  28. TFoch
    TFoch
    Nice work!
  29. Jeff Norwell
    Jeff Norwell
    MODERATOR
  30. gonzo
    gonzo
    Yep really excellent work. That rear suspension set up is trick.
    Should we start a gofundme so that firewall can take a trip to the chrome shop?
    chryslerfan55, 51box and loudbang like this.
