Projects turning a sedan into a coupe 1930
Discussion in 'Traditional Hot Rods' started by sigfurniture, Dec 7, 2020.
  1. sigfurniture
    sigfurniture
    hi..I thought I´d post a couple of pics of the job I´m on at the moment. First of all a bit of background. I´m in spain..near Barcelona..Ive been playing with cars for ages now along with the steel furniture but this year especially I´ve been busy with a client who pays the bills and makes building a car easier!!. so after finishing the rot on his patina caddy (1950 convertible), he pestered me to build him a rod. now the raw materials for a decent rod are difficult to find in spain, but after looking at various old citroen in france and other local wrecks we stumbled across a solid sedan shell..it was quickly bought and a chassis and wings were found.(miraculously )last week. now I´m a fan of a good sedan but the client only wants a coupe (dream car etc)..so had to get the grinder out.
    so i realise that there are loads of subtle differences between the sedan and the coupe (window moldings, rear side window shape etc) but we´ll have to live with those at the moment as the major problem i have is creating the rear quarters out of nothing.
    started with a frame work to get the curved looking ok, and then cladding the parts in (where i can) the old henry J steel. at present this is as far as I´ve got, one side is starting to look passable. the engine is going to be a big old caddy v8 (from the other car) so later I´ll be asking all sorts of advice about positioning of it , reinforcement etc. I hope this is not considered too much as "Heracy" ..as literally all i´m trying to do is keep the client happy and the bills low (mostly the importation taxes from the states..which are a big wedge here)..heres some more pix..cheers sig
    IMG-20201201-WA0003.jpg IMG_20201204_174141.jpg IMG-20201205-WA0011.jpeg IMG_20201206_172436.jpg IMG-20201205-WA0011.jpeg IMG_20201205_201956_264.jpg
    lewk, attitudor, Vic Walter and 33 others like this.
  2. sigfurniture
    sigfurniture
  3. sloppy jalopies
    sloppy jalopies
    mikie likes it...
    like the using what is out there...
    my only experience is with USA and Canadian bodies...
    you listed it as a 1930...
    but beware, the cowl looks to be 1929 Murray Ford fordor...
    they looked like '30-'31 fords but were a '29 0nly styling sample...
    they uses a '29 Murray only hood, a '28-'29 grill, lights...
    '28-'29 gastank that mounted from below...
    3 piece firewall...
    dash, garnish, w/s frame or visor may be different...
    i have a couple pair of door garnish if you need them bad enough or just want pix PM me...
    hope it helps
  4. Max Gearhead
    Max Gearhead
    from Wisconsin
  5. 66gmc
    66gmc
    Great job, I like the proportions!
    Stogy, weps, Blues4U and 3 others like this.
  6. I love the make due with what is available and use it as the starting point to build what I want type threads! Keep going!
  7. sigfurniture
    sigfurniture
    thats really interesting as the seller had no info or papers..any more details are well appreciated thanks xx
    Stogy likes this.
  8. 6sally6
    6sally6
    I can't find much of anything I don't like about this build!
    You-got-a- 'big set' chopping up a nice sedan to make a coupe......How do you walk around with those!?!o_O
    Nice work so far!!
    6sally6
    Stogy, weps, j-jock and 2 others like this.
  9. goldmountain
    goldmountain
    That is quite the project. By the way, what kind of car is your avatar?
    Stogy and sigfurniture like this.
  10. sigfurniture
    sigfurniture
    hahahaah !
    Stogy and kidcampbell71 like this.
  11. sigfurniture
    sigfurniture
    peugeot 402..also was a sedan..but there was no rear on it barely so was turned into a coupe with the help of the roof of a beetle..heheh IMG_20201128_114031_135.jpg
    luckylou, Lil'Alb, 48fordnut and 20 others like this.
  12. Blues4U
    Blues4U
    from So Cal
    That's coming out surprisingly well. I'd work a little more on that roof line, try to eliminate that peak that sits between the two sections. Good job man! Keep us posted on your progress please.
  13. sigfurniture
    sigfurniture
    yep its only spotted together as yet..sometimes it helps to sleep on it after a batch of stitching..i noticed it in the fotos too..cheers
    inaford30, Stogy, weps and 2 others like this.
  14. chev34ute
    chev34ute
    I like it. This should be the fate of all four door sedans.
  15. sloppy jalopies
    sloppy jalopies
    The '29 Murrays had a very interesting inner door opener... check one out if you have it...
    on the doors and quarter window the radius where the horizontal [armrest] meets the vertical
    is much sharper on the Murrays than the Fords...
    the B jam on the door is wider in the rear than front...
    Fords were the same...
    Murrays were what i called wooden cars as most of the structural interior was made from wood...
    some were blind [no quarter windows]. if you can find one of those not only would it make a one of a kind 3 window coupe but would be much easier to build... [no garnish] enough of my $0.02.
    inaford30, Stogy, The37Kid and 2 others like this.
  16. Kirky
    Kirky
    Very cool. Keep the pics coming.
  17. Your work looks good to me. Keep going until we can see the finished product.
    The37Kid, Stogy and sigfurniture like this.
  18. sigfurniture
    sigfurniture
    the second choice was a blind 4 foor..down south..but the seller was a bit of a pirate so we decided no to...but i researched them then and it said they were rarer....the one we´ve got has sharper angles on the windows for sure..and wooden structure inside yes..also a big gap at the b pillar ...also the top horizontal at the side windows is slightly arched..does that mean anything to you?..very cool info boss xx
    Stogy likes this.
  19. sigfurniture
    sigfurniture
    todays great discovery is that a beetle roof has an excellent (slightly) compound curve for the arse end of the coupe..its a bit more "bubble butt" than the original i think but i like it IMG_20201208_185000.jpg
  20. sloppy jalopies
    sloppy jalopies
    i see a stock '28-'29 hood...
    the only one that fits is murray, not sure about briggs ?
    Yes Murray's had an arch front to rear top edge of the door... otherwise they would fit a '30 coupe...
    they had a beefy B pillar,
    i have a pair in good condition,
    but i would make mine from rectangular tube steel... if building a Fordor i would use the pillars... otherwise no... pic doesn't show it but both front and rear edges are the same... DSCN6353.JPG DSCN6349.JPG
  21. sigfurniture
    sigfurniture
    this is that blind fordor that i was talking about..from the windows i´m guessing a murray also?..and i assume this is the correct hood?..yes the one thats on at the mo is a left over from the other rod I did Screenshot_20200927-183855_Wallapop.jpg Screenshot_20200927-183904_Wallapop.jpg
  22. sloppy jalopies
    sloppy jalopies
    door tops look flat, might be a briggs body...
    inaford30 likes this.
  23. chev34ute
    chev34ute
    I am not sure how much help this is but I have been making my own deck lid out of sheet steel. There are four sides and a centre. I used MDF as templates to trace around the sheet metal. The idea is to weld the four sides together, flip it upside down over the center section and trace around it, cut it out and weld it in. 17131D3E-B30D-4880-BC6C-847E9BF8D22D.jpeg
  24. sloppy jalopies
    sloppy jalopies
    Can't wait to see more body fix pix ... rear quarters are a bear, even around here...
    Stogy, sigfurniture and kidcampbell71 like this.
  25. dirt car
    dirt car
    from nebraska
    That Peugeot is a super slippery vehicle looking very much like the Mopar airflows, like the front, hood, widow lines etc. I would surmise that rounds up a total like overall even without a rear view, rally on!
    Hnstray, sigfurniture and Jrs50 like this.
  26. ekimneirbo
    ekimneirbo
    from Brooks Ky
    Looks like you are coming along nicely, but I would chop the top some......
    Automotive Stud and sigfurniture like this.
  27. sigfurniture
    sigfurniture
    yep its all in the pipeline got to finish the general structure first..the caddy engine is coming home tomorrow..i´ll show pix
    inaford30 and Stogy like this.
  28. The37Kid
    The37Kid
    Great project! Yes it is a 1929, have to get back to my Steelback. The one you passed on has something different with the rear section and top than mine. Need to get back to it and renew the details. Briggs & Murray do match in some bits but totally different in others. Bob
    inaford30, Stogy and sigfurniture like this.
  29. The37Kid
    The37Kid
    inaford30 and chriseakin like this.
  30. The37Kid
    The37Kid
    My Steelback, note the two beads around the back beltline. Bob
    Stogy, brEad and sigfurniture like this.
