Projects 33 Doll Build Page
Discussion in 'Traditional Hot Rods' started by 33Doll, Mar 20, 2020.
  1. 30tudor
    30tudor
    Good stuff throughout, what are the numbers on the engine?
  2. 33Doll
    33Doll
    Don’t really know, it came rebuilt already in a 35 ch***is my Pops scored!
    He stripped it down to inspect it, and make sure it was rebuilt, but didn’t pull the cam out to get the numbers.
    Cleaned it up, painted and dressed it.
    It ran real good in the ch***is before.
    We will see!
  3. 33Doll
    33Doll
    Rear seat Looks good in back!
    And quite comfy as I remember!
    (Except Im older and fatter and squish the springs down more!)
    I decided I’m gonna go with the musclecar style pro car seats, Instead of the mustang seats, they look a little more ergonomic but still sixtyish .
    and dye the rear seat black with RIT! Been
    Looking up bunch of different ways to dye couches and fabric and things. looks pretty straightforward, and that’ll save me a lot of money in upholstery.
    IMG_0728.JPG IMG_0731.JPG IMG_0730.JPG IMG_0733.JPG IMG_0734.JPG IMG_0735.JPG IMG_0736.JPG
    Stogy, kidcampbell71, brEad and 2 others like this.
  4. 33Doll
    33Doll
    So… At some point in the past my Pop put a GM steering tilt column out of an impala, so I found out it was a 67 impala. However the column tube broke, and it spun around! Not the safest way to drive!
    because it was not designed to drive without power steering I think? Has some cheesy mesh instead of a solid tube.
    ....Anyway I dug through all of IDidit pre-made steering columns...and found that a 32 inch GM style would work, however I had a little snafu....my Pops welded the lower half of the rag joint to the F1 hundred steering box. So I had to have IDidit put a 48 1 inch lower shaft to fit a standard GM rag joint, so I think I have fixed the problem! It never had the rag in it as far as I know, andIt always seem to work, but maybe I’ll put one in just so it has a little bit of cushion?
    Seems like The shaft on the F100 box is long enough to probably cut and grind to a double D
    I figure at some point I can always cut the shaft and make it a double D end, and put some regular modern U joints in there?...... but if it’s not broke right now… I ain’t gonna fix it!
  5. alchemy
    alchemy
    The Effie shaft will have a hole through it. Probably not real good to grind the sides flat, and cause weakness. Maybe you could insert a piece of bar into the hole, weld the end, then machine the double D? It would prevent collapsing.
    chryslerfan55, Stogy and 33Doll like this.
  6. 33Doll
    33Doll
    Didn’t know it was hollow. Probably not gonna mess with it then.... unless the U joints get sloppy.... they are still tight.
    And the box has no slop either.
    ..ain’t broke....
  7. alchemy
    alchemy
    Personally, I'd rather cut the junk off that box and install one single U joint. You can weld it to the shaft just as easily as your dad did. Then you wouldn't have a welded joint (that was meant to be a clamped joint) bolted to a rag joint that is missing the rubber.
    And, you have an F-1 steering box, not an F-100.
    chryslerfan55 and RICH B like this.
  8. 33Doll
    33Doll
    I was thinking about it, but it would be more money, and I would have to graft a short section of shaft to make up the difference. It works fine, once the car is back together you’ll never see it. Its a focal point right now. Also, i was told that is a 53-56 box, which is an f100.
    f-1 48-52
  9. 33Doll
    33Doll
    Finally got some car time today in between Costco and the dog groomer! Got my new master cylinder set up Mount all welded and solid!
    And my linkage!
    Even though I beefed up the bracket and cross member so it doesn’t flex, I still think I’m gonna put that lower one back on just act like a skid plate to protect the arm a little bit.
    IMG_0762.JPG IMG_0763.JPG IMG_0765.JPG IMG_0766.JPG IMG_0769.JPG IMG_0770.JPG IMG_0771.JPG IMG_0772.JPG IMG_0773.JPG IMG_0775.JPG IMG_0774.JPG IMG_0773.JPG
  10. dumprat
    dumprat
    from b.c.
    I like the skid plate idea. Murphy's law and all.
  11. 33Doll
    33Doll
    I think I might make a little beefier, and slightly wider skid plate ....Just for ****s and Grins! [emoji16]
    Stogy and loudbang like this.
  12. 33Doll
    33Doll
    I found this...
    Doesn’t really matter what it is, it works good, no slop, and easy to steer for manual steering (yes I agree the joint is ugly.) but its staying... for now [emoji6]
  13. 33Doll
    33Doll
  14. 33Doll
    33Doll
    Cant really see it once its all together.
    I have to stop myself sometimes
    And try to remember this is a homebuilt 60’s style. Time warp.
    I want to preserve some of the stuff My Pops did, and the unique mods, that makes it individual. I really like the Borgenson type u-joints also... but I don’t want to look to “street-roddish”
    I was hesitant about buying Speed way
    Radir rim copies, instead of Real Radir rims... but the price and style is great.
    So... its a tough battle... I like a lot of the individual 60s modifications, but safety comes into play also, but then I don’t want to look too modern street roddish
    and I’m not an absolute traditionalist!
    Either
    I have never colored in the lines!
    I am Just.... Me!
    VANDENPLAS, Stogy, brEad and 3 others like this.
  15. 33Doll
    33Doll
  16. dumprat
    dumprat
    from b.c.
    Colouring outside of the lines is the only way to keep things interesting.
    Rules are stifling.
    loudbang and 33Doll like this.
  17. 33Doll
    33Doll
    Agree!
    I totally get some people being inside the lines....like the TROG Guys trying to keep it period Correct. But that means they have “rules”! Anytime somebody tries to tell me what I can...
    And....can’t do I automatically wanna rebel! It doesn’t matter what it is! Lol!
    That’s why I kind of like some of the rat rod guys....in combination with traditional!
    I’m not talking about “**** rods”
    talking about the guys who are actually kind of artistic and innovative.
    I don’t always agree with some of the stuff they do, specially the real unsafe things but I can appreciate their differences not following the cookie cutter program!
    I need to have a club jacket that says “Lonewolf”!
  18. That mesh is designed to collapse in an accident, idea was that the steering wheel would not kill you if you survived the wreck.
    VANDENPLAS, Stogy, bchctybob and 3 others like this.
  19. 33Doll
    33Doll
    Well now that makes sense! So the tube on the inside of there, must be sleeved or something so it collapses also?
    Being Shanked with a steering column at high speed....
    Gave me an awful vision....
    Can you imagine....if a bunch of 67 Impala‘s, Fords, and Chryslers were still on the road today...instead of the new cars, with the same speed and crazy way people currently drive!
    There would be blood, guts, and bodies everywhere!!
  20. bchctybob
    bchctybob
    Skid plate or not, that master cylinder and linkage hanging completely below the frame like that is a BAD idea. There are any number of ways to get that MC up into the frame where it is protected. I know that you want to keep the original pedals but you need to reconsider that MC location.
  21. 33Doll
    33Doll
    Solved that problem!
    Have to run over a granite bolder to rip it out now’
    Plus you cant really see....but the crossmember protects it, and the wish
    Bone is actually lower. Im satisfied.
    IMG_0792.JPG IMG_0793.JPG IMG_0796.JPG IMG_0794.JPG IMG_0798.JPG IMG_0791.JPG
  22. dumprat
    dumprat
    from b.c.
    Ya your fine.
    Ya wanna know how hard you have to hit something to bend 3/16" steel? Ask an off-road guy.
    33Doll likes this.
  23. alchemy
    alchemy
    On second thought, I think your box IS an F-100. But it looks like someone welded a stub of the old sector to the end of the F-100 sector. Can you see a weld? A stock F-100 box would have a pinch bolt holding the pitman arm on instead of the large nut like you have.
    I'd really be looking that modification over well before using it again.
    chryslerfan55 and 33Doll like this.
  24. 33Doll
    33Doll
    Finally done with all the frame/suspension welding! I can’t believe house much stronger the frame is with those little extensions going to the outer rail, I was on the fence about it but they were already cut out...glad I did it! Time to Blow this ch***is apart clean it up and start painting it! And then rebuild rear end!
    IMG_0799.JPG IMG_0800.JPG IMG_0801.JPG IMG_0802.JPG IMG_0805.JPG IMG_0803.JPG IMG_0804.JPG
  25. 33Doll
    33Doll
    Yup! Its grafted, I just need to find out if my Pops did it, because I know he would do it correctly, being a welder at E**on and a machinist at Mare island
    In the 60’s if someone else?.... dunno.
    It looks solid, and
    Worked for 30 years
    chryslerfan55, Stogy and loudbang like this.
  26. 33Doll
    33Doll
  27. 33Doll
    33Doll
    Well I pulled off the steering box, and got a closer look, cleaned it up better. it looks like the Graft was done really good other than the weld clean up,but I put a straight edge on it and there’s no run out, so I’m pretty sure that it’s probably stubbed and drilled. Not bad for not using a Lathe, but I don’t think you would be able to unless you had a big one, cause of the teeth on the end of the sector shaft. I’m not to worried about it. IMG_0822.JPG IMG_0823.JPG
    chryslerfan55, loudbang and Johnboy34 like this.
  28. 33Doll
    33Doll
    FYI!
    If you’re trying to put Speedway Lincoln brakes on the later square spindles (46-48) you still have to grind a little bit, and round the edges, flatten the top and bottom, I also ground smooth the tooling marks on the backing plates so it will all seat nice!
    Maybe take the edge off the wheel cylinder brake line connector to clear the king pin a little more.... its real close! Speedway does sell the round spindles already ground to fit, but they’re kind of expensive, if you already have your own, especially the square ones. It took about five minutes!
    Enjoy! [emoji16]
    IMG_0826.JPG IMG_0831.JPG IMG_0828.JPG IMG_0829.JPG IMG_0832.JPG IMG_0833.JPG IMG_0834.JPG IMG_0835.JPG IMG_0836.JPG IMG_0837.JPG IMG_0838.JPG
  29. 33Doll
    33Doll
    Well I got one side fitted! Except I’m kind of pissed off, it has a wobble!
    I think the hub is bent a little bit from beating on it to get the studs out on the first one, I was a lot nicer to the second one!
    I’m thinking I could probably mount it on the spindle with a run out gauge and just whack it with a hammer until it is straight! It’s not that far off.
    I’m afraid to heat it up and bend it too much! Or crack it because it’s too cold!
    Unless it’s China bills drums! I’m going to check the other one on the same Hub just to make sure before I drill them for the 4 1/2 pattern!
    chryslerfan55, loudbang and RICH B like this.
  30. dumprat
    dumprat
    from b.c.
    If you can get them close then cut the face in a lathe they will run beauty. Surprisingly most drums don't run very well. That's why the floating bendix brakes are better than the old ones with fixed mounts on both ends.
    33Doll, VANDENPLAS and loudbang like this.
