Technical ***December 2020 Banger Meet Thread - Lil Saint Nick!***
Discussion in 'Traditional Hot Rods' started by Jiminy, Dec 2, 2020.
  1. waxhead
    waxhead
    from West Oz
    Yep, .040 copper wire. Easy to install and had no problems after installation.
  2. railcarmover
    railcarmover
    Thanks,I don't plan on hard-core racing,that should work.
    waxhead likes this.
  3. rwrj
    rwrj
    from SW Ga
    lowlight and BeaverMatt like this.
  4. Phil Damon
    Phil Damon
    from San Diego
  5. hardtimesainit
    hardtimesainit
    Hey Phil,
    Unless you already bought it, I'd get one of the 59 AB (banger adapted pumps). I haven't seen and/or checked out the pump shown/pictured. Does it come with sump arm/screen ? Is pressure relief located in bottom portion ?
    There are guys ( USA) here who make a great light weight alum with hardened chev gears. I've bought/used adapted 59 AB pumps that and old 4E4 guy used to make. They were excellent ! Bill Stipe is a producer of a great alum A/B pump !
  6. Phil Damon
    Phil Damon
    from San Diego
    I just ran across these pictures online and it got me curious. Maybe some of our British members would know.
  7. I'll ask Nervous Bob tomorrow - he rebuilds both so I'm sure he'll know.
    winduptoy likes this.
  8. burl
    burl
    from Minnesota
    When i was ***embling my motor for my 28 i did a lot research on oil pumps.There wasnt a lot of good factual information.I ended up modifying my stock pump.
    By tightening the clearance between the gears and bottom plate it really helped.It also modified to direct the oil through a filter and then into the upper area.I looked at the stipe pumps but couldnt bring myself to spend close $400 on it.The modified pump puts out around 30 psi cold and then maintains between 10 to 15 psi hot which should be more than enough for a warmed up A engine. oil pump.jpg oil to main.jpg oil filter.jpg
    Jet96, winduptoy and Old Dawg like this.
  9. V4F
    V4F
    from middle ca.
    need a little help . has anyone got pix of a panhard bar on a front axle (straight model a axle) ? thanks .
  10. brjnelson
    brjnelson
    IMG_4630.JPG I read more than just shop manuals I recently finished this book it was a good read.
    Jet96, burl, winduptoy and 3 others like this.
  11. Leon Sandcastle
    Leon Sandcastle
    Thinking of running an accessory magneto (wico) on my T, or a modern distributor from a Honda or another thats driven directly off the cam. Has anyone done either and have pictures?
    Sent from my SM-N960U using The H.A.M.B. mobile app
  12. Steve,
    Some are mounted to the right side radius rod or wishbone, close to the axle.
    The other end to the frame or cross member on drivers side.
    The geometry is not all that critical but there are many examples of the correct way to do this on line.
    I seem to recall seeing it on some of the hot rod sites that sell them.
    In a nut shell, both attachment points want to be the same distance off the ground when sitting level.
    John
  13. Phil,
    interesting piece, never seen one, looks like it has potential.
    John
  14. Phil Damon
    Phil Damon
    from San Diego
    Here's an exploded view of the 100E engine. Other than the cam being on the opposite side, looks like a more modern Banger.
    [​IMG]Ford 100E by nomadpsd, on Flickr
  15. The earlier 10hp and 8hp (tax cl***) engines are a scaled down and flipped four banger. The earlier distributors are a drop in replacement on an A engine - bit too much advance for some setups though. The 100E had an improved 1172cc engine with a block mounted waterpump. They have a cam chain instead of gears so I think the distributor drive skew gears are reversed.
    Popular engine for clubman racing in the 50's and early 60's.
    Leon Sandcastle likes this.
  16. On the left side of the car's frame you can see a horizontal Heim Joint. That is a stationary fixture of the Panhard Bar to the ch***is! It runs PARALLEL to the tie rod and axle over to the right side radius rod. I emphasis parallel because that's what it's got to be in static position. To get the bar horizont, the best way I know is to extend the ch***is side location downward from the frame of the car. E gezzers2019 (2).jpeg ach end of the bar, of course has a flexible joint. And to keep everything working together your spring shackles on each side should be a a 45 degree angle!
    Jet96 and Genes12320 like this.
  17. V4F
    V4F
    from middle ca.
    thanks
    thanks all . im getting the idea ............. steve
  18. Fabber McGee
    Fabber McGee
    facts-about-cross-steer.pdf
  19. Fabber McGee
    Fabber McGee
    Sorry, tried to rotate it... not tech savvy enough.
  20. stubbsrodandcustom
    stubbsrodandcustom
    from Spring tx
    Missing having a Banger but still come here to enjoy...
    Merry Christmas From Texas.......
  21. 4bangerbob
    4bangerbob
    from AB, Canada
    rotated
    Fabber McGee likes this.
  22. hardtimesainit
    hardtimesainit
    Hey Burl,
    Im not sure how durable a model A type pump is, if run hard ? My guess is good ...if great rebuild.
    If you know of Jim Brierley, his first book has the information of details of A pump rebuild.
    There is also an engine rebuilder , Joe Sivils, in Turlock, Ca. Who also CNCs an alum A/B pump with nodern hard steel gears...similar to Stipe pump. Ive used a number of high output oil pumps. Although high priced as you say, I liked Stipe pump as it was bullet proof AND I could adjust pressure from outside side plate.
    Jet96 and burl like this.
  23. railcarmover
    railcarmover
    The biggest issue with the A/B pump is volume,its flow rate is low.Restricted flow is caused by how the oil flows through the pump.you can use an external "stand alone" adjustable relief with any pump.the value of pressure is determined by how much rpm you push out of the engine,if you street drive a few pounds is adequate to keep the bearings fed.The model a was effectively fed by a few inches of gravity. There are those who spin 4k rpm with a stock B oiling system pressure and increased volume. There is no benefit exceeding what you need.
    burl likes this.
  24. PhredH
    PhredH
    V4F,
    Below are photos of a bar I put on banger. The ch***is is lowered by reverse eye springs and leaf removal, so the bar only fit in front of the axle. Drivers side of bar is mounted to ch***is, p***enger side of bar is mounted to spring perch. This modification did make a positve change in handling. Hope this helps. IMG_4994.jpg IMG_4996.jpg IMG_4998.jpg IMG_4999.jpg
    Shutter Speed, Old Dawg, burl and 2 others like this.
  25. winduptoy
    winduptoy
    I agree, my buddy and I have the pressure vs flow argument all the time.
    If you find the early V8 pump gears, they are the same diameter as the Model A/B pump but longer = volume.
    Add a spacer plate and I make the pump a bottom admission...no air leak on a housing or worry about low oil level.
    OHV that has additional oiling and full pressure crank...10 psig hot idle and relief at 35 psig above 2000 rpm where the relief is. The oil pan takes a little m***aging
  26. V4F
    V4F
    from middle ca.
    thank you much . this i can get my head around ........................... thanks ... steve
  27. Fabber McGee
    Fabber McGee
    No PhredH, the p***enger side is not mounted to the spring perch, it's mounted to the shackle. Any time the spring height changes it will push or pull the axle sideways, relative to the ch***is. If this was a cross steering car bump steer would likely be severe. in your case, with your drag link running lengthwise to the frame it may not create bump steer.
  28. You could do with another bolt in that shock absorber link PhredH!
  29. railcarmover
    railcarmover
    That's a nice lash up, no relief oil return issues, and as an added benefit its discharges like a fire sprinkler.
  30. Fabber McGee
    Fabber McGee
    It just dawned on me that your setup would probably work for cross steer cars by simply putting the shackle bolt in the lower hole and the panhard rod in the upper hole. that would change the motion of the axle end of the panhard bar from horizontal to vertical and it would no longer push or pull the axle side to side. Or, at least the side to side movement would likely be negligible.
    Nice job on the construction.
