Customs Chased it for 20 + years
Discussion in 'The Hokey Ass Message Board' started by flynstone, Nov 23, 2020.
  1. gotta56forme
    gotta56forme
    from Seattle
    Find anymore kittens or really good treasure?
    Torkwrench, loudbang and Thor1 like this.
  2. BJR
    BJR
    Never expected to see good metal under all that ****. Looking better all the time.
  3. flynstone
    flynstone
    did find one of the ash trays, no rat or cat stuff in the car but the trunk is where they were residing, bottom of spare tire well rusted due to rats.. not bad easy fix.. very lucky on the rust
  4. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
  5. keith27T
    keith27T
    Nice save!
    1959Nomad and loudbang like this.
  6. flynstone
    flynstone
    800 wet dry sand paper, then polishing compound
  7. Jacksmith
    Jacksmith
    from Aridzona
    Buddy, you struck GOLD!!! That's a damn nice find right there! Oil those cylinders with M.M.O. & let 'er soak for a spell... then let's see if it'll start...
    loudbang, Thor1 and bchctybob like this.
  8. flynstone
    flynstone
    did get it to start, no smoke and smooth, small tick from lifter otherwise for the short time i ran it , was real good. water leaks eveywhere. the trans cooler is 2 water lines from the water pump to the trans, pretty weird. carb, water pump and hose next
  9. flynstone
    flynstone
    IMG_2608.JPG almost all graffiti gone unfortunately appears this rear quarter panel has been repainted and it’s coming off with the graffiti
  10. flynstone
    flynstone
    slv63, Stogy, Torkwrench and 4 others like this.
  11. carpok
    carpok
    from Indy
    Nice save I love your approach to the discovery. You know the paint color yet code and name. Keep us updated. Thanks
    Thor1 and loudbang like this.
  12. flynstone
    flynstone
    floor came out nice, still have rear seat well and trunk encaspulated floor.JPG
  13. Greg Rogers
    Greg Rogers
    Excellent!
    Thor1, loudbang and Stogy like this.
  14. What are you using on your floors?
  15. gotta56forme
    gotta56forme
    from Seattle
    For you '54 Buick guys...
  16. flynstone
    flynstone
    floor coating is eastwood rust encapsulator, dig that roadmaster. today i changed the oil and filter, put a new water pump on, new belt and hoses... a little here and there getting closer.. waiting for carb and radiator to get back from shops. the other project has hit a problem my 53 flxable bus had a detriot diesel with a gear drivin air brake compressor i need one for my big block chevy with a pulley. any ideas? cant find a compressor with a pulley. new hose 54.jpg
  17. BamaMav
    BamaMav
    from Berry, AL
    Belt Pulley driven air compressors were used on 50's and 60's gas burning big trucks like F700's and G60's. Any old truck junk yards around? May be something from a school bus? A good truck parts dealer should be able to find something you could use, they weren't that uncommon.
    The Magic Ratchet, Thor1 and loudbang like this.
  18. flynstone
    flynstone
    yes that is what i need a good old junk yard
  19. junkyardjeff
    junkyardjeff
    You might want to reconsider the Detroit,that bus might go from about 7 miles to the gallon with the Detroit to about 7 gallons to the mile with the 454. Been watching the Bus Grease Monkey and those old Detroits look to be a simple engine and sound good.
    Thor1 likes this.
  20. flynstone
    flynstone
    orig motor was a buick straight eight with a 4 speed stick
  21. enjenjo
    enjenjo
    from swanton oh
    I took my driver's license test in a 58 Buick four door Special. I raced my first street race later the same day in the same car and won.
    Thor1, loudbang and fauj like this.
  22. enjenjo
    enjenjo
    from swanton oh
    I just did some wiring on a 1991 65oo Kodiak with a 366 big block and air brakes. Belt driven compressor. https://www.fleet-products.ca/227407x-tf-400-pulley-drive-compressor/
  23. Brand Apart
    Brand Apart
    from Roswell GA
    Nice score! I'd take cats over rats or snakes any day.
    I worked at a junk yard in Ft lauderdale in the 90's we used to have iguanas and other lizards living in cars, one guy there got bit by one he was trying to catch it was pretty funny to the rest of us.
  24. Boneyard51
    Boneyard51
    If you have not finished building your BBC , you might want to install a high volume oil pump. Most belt driven air compressors oil from the engines oil pump. If I remember correctly there were some trucks with the belt driven air compressors on the 427 and 366 big block Chevies.
    Bones
  25. junkyardjeff
    junkyardjeff
    A local junkyard has a school bus with a 366 and can look the next time I am there.
    Thor1 likes this.
  26. flynstone
    flynstone
    got it sorted out, thanks. for the help, now back to the 54 new carpet, waiting on gas tank, sending unit and seats. IMG_2822.JPG IMG_2825.JPG IMG_2820.JPG
  27. JLeather
    JLeather
    That's amazing. A car around here with no gl*** for a couple years would be a flinstone-mobile...
    loudbang, Moondog13 and Thor1 like this.
  28. BigDogSS
    BigDogSS
    from SoCal
    Great find! Questions:
    1) Does the car have both original black California plates?
    2) Did you get the pink slip?
    3) Is there an old registration slip with the car?
    The reason I'm asking is that if you have the pink slip or registration slip tying the original black plate to the VIN, you can use those original plates without paying an extra yearly YOM plate fee.
  29. flynstone
    flynstone
    i have one frt plate, no pink or regis ... prob go with historical plate as on both my 57s
  30. flynstone
    flynstone
    i cant believe a garage came down on it and the body did not get hurt. so lucky
