Hot Rods Scored a 50 Pontiac coupe this afternoon
Discussion in 'The Hokey Ass Message Board' started by Rocky, Dec 5, 2020.
  1. Rocky
    Rocky
    Classified Editor
    Yesterday I gave the car a sponge bath and cleaned the windows. Holy ****! The gl*** in this car is phenomenal!!! Windshields have no cracks, delamination or wiper burns. I put the battery in it {previous owner bought a new $140 six volt battery for the car 3 days before I bought the car} and spun the engine over. Had to hot wire the starter to get it to work. Compression is pretty low with #8 having no compression. I poured some penetrating oil down all 8 cylinders and rechecked....now have compression on all 8. After it got dark I went out to try some lights. I see I have an issue with the neutral safety switch. The back up lights stay illuminated in all gears. That's prolly why the starter ****on doesn't work.
    You guys should see this thing.....all the rubber weather strip is still soft! Even the windshield gasket and the little gaskets around the door handles, tail lights and emblems. The dome light comes on when doors are opened....the glove box still has a functioning light when opened. I need to replace/repair a broken hood release cable. Had to use an adjustable, spring loaded shower curtain rod to keep pressure on the Indian head ornament while I took a looong screw driver/bar under the car to reach up and trip the latch. The spring loaded curtain rod popped the hood up on the safety catch. That was no fun and I got some black, greasy sand in my eye for the trouble. Had to stand in the shower running water in my eye . It's ok now.
    To be contuined............
  2. Budget36
    Budget36
    [QUOTE="Rocky, post: 13852370, member:
    .[/QUOTE]
    Well you have the car and a camera;)
    clem, vtwhead, BJR and 1 other person like this.
  3. Great score Rocky! I belong to the camp that say's "keep that flattie and drive the **** out of it"! I often regret selling my '50 Catalina, it still had the straight 8 and Hydramatic... EbayPictures008.jpg EbayPictures005.jpg
  4. Sounds like a great score Rock! We are long overdue for a visit
  5. Rocky
    Rocky
    Classified Editor
    If the straight 8 is in good condition, I'll drive the car with it this summer. If not, I'll build a Pontiac v/8 for it. I can see the car with dove gray paint and the top painted the same dark metallic gray as the dash and garnish moldings.
    It's been pretty cold here and my cheezy little propane heater worked great in my old 1 car garage but it struggles trying to heat my high-ceiling 3 car garage. I managed to get the engine running a bit on dribbled gas until the fuel pump [it actually works!] picked up 40 year old gas in the tank and filled the carb with it. The engine won't run on that ****. I already knew that so why the hell did I leave the fuel line hooked up? I suppose to see if the fuel pump worked. 50pontiacilluminatedhoodornamant.jpg [/ATTACH] 50pont12_2020.jpg 50pontiachoodornament.jpg 50pontiachoodornaments.jpg
    So I spent some quality time on line and scored a KILLER illuminated Indian head hood ornament. The original is a pretty nice all chrome one but we all know a Pontiac HAS to have the light-up ornament sitting out there.
    I ******ed the locking gas cap off the fuel filler and as a nice warm afternoon project I dis***embled the cap, lubed it up and got it working again. I know this is a teeny little job but I
  6. Rocky
    Rocky
    Classified Editor
    This is what I get for staying up so late posting this....missing text, missing photos. screwed it up but too bad. I'm going to bed.
  7. lothiandon1940
    lothiandon1940
    Love that new hood ornament, Rocky....Beautiful!
    vtwhead and loudbang like this.
  8. Rusty Heaps
    Rusty Heaps
    Clean it, make it safe, drive it.... simple! Good looking ride!
    Algoma56, loudbang and 1959Nomad like this.
  9. Rocky
    Rocky
    Classified Editor
    Had some great weather today so I drove to NAPA for some parts and was able to get the ol girl lit off today. Hooked up my 12 volt fuel pump to the 6 volt battery. ****ed out of a 1 gallon gas can and it started for the first time in 42 years. Oh man! It clattered, smoked and missed but it ran. I actually had the presence of mind to jump inside to check the gauges while it was running and I was astounded to see every one of them works! Carries 35 LBS oil pressure while idling, generator charges, has 1/4 tank of "gas" . I did notice the thermostat housing [no upper radiator hose] was pulsing with steam which tells me the engine either has a bad head gasket [crossed fingers] or a busted block. I let the engine get nice and hot before I let it run at high idle and drowned it in Marvel Mystery oil poured down the carb. I'll let it sit a few days and clean the plugs and fire it off again so see if that clatter is gone. Then I'll remove the head to see wtf?
    If the block is busted, I'll take my $100 to my buddy and buy his 400 Pontiac motor and start on the engine swap.
    If all it needs is a gasket, I'll do that and drive the car this summer while I collect parts to swap it over to the 400/350 turbo.
    Right.....the last time I said that I owned a primo 48 Pontiac straight 8/Hydro and never did update it...loved the original drivetrain.
    Oh yeah....while it was running I accidently dropped the trans in drive and it began to move....made me feel good.
    I have video of the car running but have no idea how to put it on the Hamb.
  10. F-ONE
    F-ONE
    from Alabama
    I love it.
  11. F-ONE
    F-ONE
    from Alabama
    You have to set up an account on You Tube post your video there and then link it here through the "response" task bar next to the smileys. The media icon looks like a film strip.
  12. corncobcoupe
    corncobcoupe
    SUPER MODERATOR
    Congrats Buddy !
    Aren't old cars - like old owners ?
    Don't we clatter, fart and miss every morning we get up ?
    After 42 years - hellava sleep - to be expected.
    PS
    I have to do a post like yours - with my new project. ;)
    Not ready to let the cat out of the bag with all the fellas just yet.
  13. Rooster72
    Rooster72
    Love those old Pontiacs
  14. Rocky
    Rocky
    Classified Editor
    Going back through my thread I got to thinking about Pat's post. I actually have a 283 and a set of TRW 4" forged 11 to ones, Oliver small journal rods and a set of 186 heads from a Z28 engine, Lakewood ****ter shield and an extra M20 Muncie. I believe the Pontiac was about 3400-3500 lbs with the giant lump of cast iron engine and iron transmission. They have to represent close to 1000 lbs. The SBC is 530lbs or so and the Muncie is about 85 lbs.
    NAH.....I don't think I could Chevyize my Pontiac but it it would pound pretty good.
  15. 302GMC
    302GMC
    from Idaho
    Rocky
    Before you start tearing things apart, put a hose on it & pressure test the system.
  16. Rocky
    Rocky
    Classified Editor
    Yeah, OK...thanks. It's so easy to get ahead of myself.
  17. fyrffytr1
    fyrffytr1
    I just read this thread in its entirety for the first time. While I do not have the skills you do I am attempting to get my 50 Streamliner back on the road. I did get the motor running and actually drove the car a couple weeks ago for the first time in about 50 years. Your thread will be an inspiration to keep me going on my project. new tires 4 sahara.jpg
    bchctybob, Algoma56, Tman and 6 others like this.
  18. Rocky
    Rocky
    Classified Editor
    That's funny. I was thinking the same about you...loved the video
  19. flamedabone
    flamedabone
    How DARE you??!!
    -Abone.
  20. Rocky
    Rocky
    Classified Editor
    Oh fer Christsakes, Jeff! If anybody should know I'm not really gonna put a chevy motor in my Pontiac it should be you! No, yesterday, after the NASCAR race my ol' Pontiac buddy made me a crazy cheap offer on a 40,000 mile '61, 389 complete motor...or a 400 that's apart with a pretty substantial cylinder ridge. If I can get him to sell me all the stick changeover stuff out of a 63 Pontiac we cannabilized about 20 years ago, I'll go for the 389. Think of it...389/Muncie 4 speed in the old '50 Poncho. I'd even leave the stock rear end in it. I've never broken one yet.
    I'm planning on putting the chevy 301 stuff on the HAMB cl***ifieds to help finance the 389 build. BTW, I also have a pair of 6X heads with 2.11 intakes, screw-in rocker studs, hardened valve seats and pushrod guide plates for the 389. and don't tell me the later heads won't work on the 389...I've already made that swap on the motor in my 34 ford. Works great.
  21. I might be game for that 301 stuff
  22. tommy gun 88
    tommy gun 88
    from chicago
    Wow what a cool find, pontiac had the best looking coupe in 50 in my opinion.
  23. bchctybob
    bchctybob
    Now yer talkin'..... you don't want to risk the wrath of the Pontiac fanatics on this 'site. (Now on the other hand, just between you and me, if you keep threatenin' to put a SBC in it some of the fellows on here may start offering you some cheap Pontiac parts.... just sayin' ) :D
  24. dirt car
    dirt car
    from nebraska
    Hey Rocky ! Great to relive our youth isn't it ? always liked the coupes & fastbacks probably leaned more towards the Olds product line, could never quite decide if the coupe or fastback tripped my trigger the most, then too convertibles, wagons........
  25. BURN OUT BOB
    BURN OUT BOB
    from western AZ
    Nice car rocky. Back around 1952/53 my buddy work in wrecking yard & scored a 50 coupe & olds rocket 88 & ******. That thing was pretty quick but he couldn't keep the fins in the torque converter it would just rip the blades out.
    I had a 50 chevy vert with a bored out 270 jimmy, dual strombergs ,nicson intake , clark headers , mallory dizzy.
    He could keep up with me but never quite p***. I do not remember whatever happened to that car. I had way more coin tied up in my car than he did in the poncho.
