Projects 61 Oldsmobile Convertible
Discussion in 'The Hokey Ass Message Board' started by Al T, Oct 14, 2020.
  1. chasmalo
    chasmalo
    Cool car! In terrific condition. Love the color.
    I believe the "Slim Jim" transmissions used a fluid coupling which is not a torque converter.
    Chas
    Elcohaulic likes this.
  2. dan c
    dan c
    beautiful car. that was a very good era for gm, stylewise. do your research on the slimjim trans; they have a troubled past...
  3. You’re right!
    B8B7FE9D-F4B7-4101-B8D2-2EB62472D206.png F4C6DCD5-36B1-4903-B161-4517A22A3BFE.png 257C535B-72F5-4FC4-BE3C-FA3FF8FF3C7B.png
  4. UNSHINED 2
    UNSHINED 2
    She's a beaut, Al!
    Al T likes this.
  5. Would someone be able to advise where I can buy a seat back attaching bolt? The passenger side bolt is snapped off.
    Thanks in advance.
  6. Don,
    Thanks for the great deal on the hubcaps. Made it back north yesterday so had to see what they looked like on the car. They’re a couple years too late for the car, but they look great.
  7. Sorted through the loose parts in the trunk. A bunch of spare parts...... and some parts I thought were missing.
    A240B6CF-85A9-4848-933C-235A8D37BFEC.jpeg 2E8412D1-59AE-44B1-8DC1-FA164093BC74.jpeg 342628E1-E0B4-4C68-AFC2-DCA8AC8285F8.jpeg
    Was really happy to see the condition of the trunk. It’s rock solid. Someone sprayed a thin coat of black over the factory trunk paint. I may try to clean it off.
  8. Squablow
    Squablow
    I thought that seat back had a pin there with a clip, that may be a pin sheared off and not a bolt. Not sure but I've had a lot of that era GM seat apart and never encountered one with a bolt in that position.
  9. I’ll check that. Thanks!
  10. Flatnose
    Flatnose
    Great car,great colour,super condition! Lucky you.
  11. bobss396
    bobss396
    I had a 62 Starfire ragtop and a 64 Dynamic 88. The 64 was a nice car.
  12. Found these when I sorted through the parts in the trunk. Might as well get them out of my way.
    2E1FA288-A69C-4288-9BCE-1D7C8B6DD8FC.jpeg A9F63900-6962-43F3-8906-2842D9DC4F1E.jpeg
    ..... and while I was at it installed the new sill plate.
    8F3DC0C5-B388-4AAD-BAF0-B83FF2AA0A13.jpeg 83F00504-B8A2-4082-9BB6-0E3706841A03.jpeg
    Elcohaulic and Algoma56 like this.
  13. harpo1313
    harpo1313
    from wareham,ma
    A stainless bar would look sweet in place of the broken bits on the grill . Nice car!
    Al T and Elcohaulic like this.
  14. bobss396
    bobss396
    My Starfire was an electrical nightmare and everything it seemed to work on vacuum including the vent windows IIRC.
  15. Elcohaulic
    Elcohaulic
    Wow I never saw one of those hinge covers before..
  16. Elcohaulic
    Elcohaulic
    Thats a great idea!
  17. Me neither!!
    Took me a few minutes to figure out what they were. lol
  18. gotta56forme
    gotta56forme
    from Seattle
    Well played, I think I'd still be circling the car after an hour if I was trying to figure it out!
  19. Elcohaulic
    Elcohaulic
    I wonder if they have another use besides making the interior look better.. I was always into the Pontiacs when these cars were popular. I never knew the Olds was built so well.
    I knew a guy whos family gave him a 62 Starfire convertible. It sm0ked like crazy so he junked it. I often wonder if transmission fluid was being sucked into the engine somewhere or the PVC valve was open and sucking oil..
  20. ClayMart
    ClayMart
  21. I HAD THE SAME CLIPS ON A 1957 98 HOLIDAY SEDAN I HAD IN HIGH SCHOOL. THEY WORK EXTREMELY WELL, THE HUBCAP FITS NICE AND TIGHT.
  22. v8flat44
    v8flat44
    Hopped into my Olds, dropped it down to Super gear
    Trompped it to the floor, burn'n rubber you could hear
    We were mooooov'n...........Had a buddy with a 62 Super 88....this Ford guy LOVED that car.
  23. Need to order a new master cylinder today. The one on the car was seized....... even needed an impact to get the cap off of it.
  24. Elcohaulic
    Elcohaulic
    If your going to use the single master, make sure the emergency brake works well. You can get them to work pretty good if you make sure all the joints are well lubed and the cable is adjusted for best performance. The rear brakes should start to apply once the pedal is pushed in 2". I make applying the emergency brake and stopping on it, part of my routine maintance..
    Al T likes this.
  25. Absolutely!!!
    https://www.jalopyjournal.com/forum/threads/catastrophic-brake-issue.989763/
    Right now I’m leaning towards replacing the single pot with a new single pot, making sure the emergency brake functions and inspect all components.
    Out of curiosity, if I went to a dual reservoir, would I be able to use the stock brake booster? Any suggestions on a kit or the master cylinder to buy? With drums all around, I would not need a proportioning valve, just fittings to isolate the front and rear lines?
    Thanks in advance.
    Allan
