Technical ***December 2020 Banger Meet Thread - Lil Saint Nick!***
Discussion in 'Traditional Hot Rods' started by Jiminy, Dec 2, 2020.
  1. MJW
    MJW
    from NJ
    Annual Grinchmas yard art to piss off the neighbors that only have "White Lights" Grinchmas 2020.jpg
    Jet96, Gruntis, modelacrazy and 5 others like this.
  2. denis4x4
    denis4x4
    from Colorado
    Done for the year...roads are slicker than owl snot on a br*** door knob!
    Jet96, Old Dawg and burl like this.
  3. guitarguy
    guitarguy
    Just in time for Christmas, my engine came back from midway across the country. Conversion of the A crank into the T block is done. Still much more to do, but this was a big step.
    Stipe adjustable cam gear and reproduction "Roof" .310" cam (out of production)
    Jet96, modelacrazy, winduptoy and 9 others like this.
  4. Leon Sandcastle
    Leon Sandcastle
    That's awfully nice looking...
    Sent from my SM-N960U using The H.A.M.B. mobile app
    winduptoy likes this.
  5. PhredH
    PhredH
    Fabber,
    Now I see the error in my geometry, thank you.
    Hotrodfil,
    Good eyes on the missing bolt (wonder how long its been missing?)
    Peace and Merry Christmans
    Phred
    Fabber McGee and rwrj like this.
  6. Fabber McGee
    Fabber McGee
    PhredH, sorry man, I don't like picking at other guys projects and your panhard rod seems to be working on your car so I wouldn't have said anything, but I didn't want V4F building something that wouldn't work for his cross steering car.
    You found a clever way of attaching the panhard to the axle without welding to the perch or drilling the axle. Nice job.
    Jet96 and Old Dawg like this.
  7. Garpo
    Garpo
    Years back, while helping with a Ford 10 HP project, I looked into oil pumps. It seems Ford 10, 100E, model A and flathead V8 oil pumps share the same gear diameters and centre spacing. The difference is in the gear length (and the housing). We simply used 1/4" longer gears and made a body extension plate to suit. . Worked well. I think the gears we used were early V8.
    This interchange information may be of use to someone.
    Barrelnose pickup likes this.
  8. I had Nervous Bob put a 100E oil pump in the B block he's working on at the moment.
    The top of the body is the same diameter but a little shorter so you can see the top collar slightly overhang in the threaded hole. Not enough to block the oilway. The tang still engages with the drive.
    Also - the bottom plate is a direct replacement for the Model A one.
    winduptoy and Barrelnose pickup like this.
  9. winduptoy
    winduptoy
    I've got Sterling, dynamic absorbing, flywheels on hand. All three weights, 22#, 33#, 64#. Drilled for early V8 pressure plate.
    Get yourself a Christmas present you want and can enjoy year around. PM me for details
    Sent from my XT1585 using The H.A.M.B. mobile app
    Jet96, Genes12320, guitarguy and 8 others like this.
  10. Kiwi 4d
    Kiwi 4d
    Ok , we are making progress,finally. The real question is what sort of lube does this water pump require and how often . The present pump is a B pump on a B and has a modern pump with the screw down grease filled cap, so easy to do . This critter looks like it may need a dedicated grease gun ???? Bit of a PIA if its so>
    I know you cant see it in the pics but for some odd reason the distributor drive shaft was maybe 5/8” too long ( yes we did take some off the head to raise theC/R but not that much, so rather than modify what we presume is a hardened shaft we put a 5/8 spacer under the dizzy. Oh yes its Steve Serr miller head and attachments. Hopefully we can more than double the original HP and still have bags of torque . BA2E3FD4-94A9-4495-A9DA-1D360DAF2E3F.jpeg A7430069-9FF0-43FA-916D-F4912D431658.jpeg 49F3A6FA-A458-4F03-9C4D-A57DA35E8B0E.jpeg 790F0119-E45D-41E1-B497-4B06400CCA1D.jpeg 5C43506C-7614-4185-A90C-B893358843B3.jpeg
    Jet96, guitarguy, Dustyp489 and 13 others like this.
  11. The setup looks really good, you will not be disappointed with the power developed.
    Nice Christmas present.
    As for the water pump, you can email Steve to see what lube is preferred.
    I will make one observation, please be careful with using the "B" upper housing as the attachment point to the stand. I have had these fail in the past and you do not want that motor laying on the floor.
    J
  12. winduptoy
    winduptoy
    You ott'a be able to haul *** in one trip with that set up.
    I remember that I've had to 'trim to fit' the dizzy drive shaft. Better to do with one that is to long.
    Yes, check with Steve as if the pump has a modern seal (pack less) the zerk with the cap might be just for looks. No lube other than at ***embly necessary.
    I like Chevron SRI in the front as it is a polyurea based grease and is 'stickier' than the lithium based greases and stays in the bearing better at higher RPM (above 3000) in my experience.
    Jet96 likes this.
  13. Kiwi 4d
    Kiwi 4d
    got a very speedy reply from Steve Serr , top guy. I had to admit to I couldn’t remember it it was his pump .
    barrnone50, Old Dawg and Savage Coupe like this.
  14. railcarmover
    railcarmover
    00ui.jpg ****ed Henry's crossbow tonight..
    Dustyp489, barrnone50, burl and 3 others like this.
  15. Kiwi 4d
    Kiwi 4d
    Nice , looks a little clunky to use unless you can fit a ratchet type ring wrench in there , of course then once its on you cant turn it around. What stops the bar bending ,or it just doesn’t? Yeah i know original ford spreaders are hard to find. So you have done a nice job of improvising .
  16. railcarmover
    railcarmover
    Schedule 80 tubing,1" grade 8 all thread,single s***ch triple p*** 7018.. never tried to find an original.
    BeaverMatt likes this.
  17. V4F
    V4F
    from middle ca.
    leakless water pump . no lube except ..... antifreeze + or water wetter , internal lube
  18. I need one for a reversed eye setup.......any ideas?
    J
  19. Kiwi 4d
    Kiwi 4d
    Generally on reversed eye you have to install the bare main leaf with difficulty then install the rest of the pack .
  20. Leon Sandcastle
    Leon Sandcastle
    I have a chance to get a stuck 1928 chevrolet engine for cheap, I know the cranks and pretty close to T, and I know I would need an adapter. Are there any secrets to the T engine with chevrolet head and crank I should know about?
  21. briphaeton
    briphaeton
    from cal
    Hey John
    Jet96, poshdbs, rwrj and 4 others like this.
  22. PhredH
    PhredH
    BriPhaeton
    Great Idea!
  23. Interesting
    How do you get the axle in place with clamp on?
    I just dis***emble the spring and re***emble
    J
    Dustyp489 and Kiwi 4d like this.
  24. hardtimesainit
    hardtimesainit
    Anyone have a ‘dressing’ or idea to preserve an older top (roadster). Ive got a top that looks like cats used it for a scratch pole. DRY also orig ‘31 ?
  25. briphaeton
    briphaeton
    from cal
    John, This is a speedway Model T low profile spring, I'm trying to use with a Model A axle. The 1 1/2 angle iron clamps were low enough for the spring perches on the Model A axle. I'm going to have to dissemble my spring too, it wouldn't spread enough with the spring bolted to the frame.
  26. barrnone50
    barrnone50
    from texas
    Looking Good! Been Watching your progress great Job! The Motor Rocks..
  27. guitarguy
    guitarguy
    Thanks!
    If you can still get an adapter for the head, then it might be worth it (unless your going to carve your own). It really depends on what it looks like too. Stuck could just be minor or look like it came from the ***antic.
    As far as the crank, I think it's alot closer than the A crank, but just as much work to install. This would be a labor of love project, not a cheap way in, unless you can do most of the machining yourself.
    If you plan on keeping your engine / trans T based, the best improvements are in the intake / carb /exhaust / head areas-----in that order. A **** crankshaft should go without saying for a stock T bottom end. Your building a light car, you wont need much to move it.
  28. railcarmover
    railcarmover
    I'm going to design a clip that slides on the main leaf and works by being bound under load of the spreader..clearance is an issue,offsetting the spreader from under the spring? Going to fool around some...maybe dual spreaders we'll see.
  29. modelAsteve
    modelAsteve
    Be very careful! I have a chipped tooth and a scar on my chin from this very dangerous operation! We have a Nor-Cal FAST spreader available for all paid up members in good standing- Guess that lets you out!!!! Much safer to take the spring apart and just do the main leaf. HAVE FUN!
  30. railcarmover
    railcarmover
    Hey my member is in good standing...all done with the widow maker for now,dropped her down some and put on some bigger meats..and fenders!!!
