Technical Building a new Winfield...
Discussion in 'The Hokey Ass Message Board' started by Kevin Pharis, Nov 1, 2020.
  1. Kevin Pharis
    Kevin Pharis
    from Califunny
    Got these from the metal spinner today...
    We are reallllly close! Just a couple minor tweaks... and I’m ready to solder!
    Stogy, Carter, TFoch and 10 others like this.
  2. Kevin Pharis
    Kevin Pharis
    from Califunny
    As of last nite... float tweaks have been made, and a batch of S and SR floats are on order from the metal spinner. Should be soldering in no time!
    Also was able to get the float bowl cover finished up...
    BD3ED11F-0604-438A-930A-F27B99BC637B.jpeg CD8D1837-FD9A-46B0-BA56-F106A33D218C.jpeg
    The float bowl cover is slightly different than an original, as it was designed to incorporate a modern fuel valve with viton tipped needle. I was also able to retain interchangeability with all the original float hardware and fuel inlet block, so this float bowl cover can be directly interchanged with an original.
    E4BAD903-B669-489F-93E6-E5A9255AF98E.jpeg 10069F70-F9C8-4F33-BEAC-51B40C912A40.jpeg DB95F0B2-C95D-4975-B9EF-81C8E2842C94.jpeg
    Now just have to build a tool for crimping the cover to retain the detent balls. Already have the stainless springs and balls to install.
    Stogy, TFoch, badshifter and 11 others like this.
  3. Kevin Pharis
    Kevin Pharis
    from Califunny
    Now on to the throttle barrel!
    BA31FD47-5767-4EA3-AA7F-D2483359337F.jpeg 34020369-CEE0-468E-9358-C8DCBADDC05B.jpeg A5F54709-789A-4547-8508-5379A60AC269.jpeg
    Outback, Lil'Alb, Stogy and 19 others like this.
  4. loudbang
    Simply amazing. :eek:
    Stogy and fauj like this.
  5. alchemy
    alchemy
    Long live fillister heads!
    Stogy, Carter, fourspd2quad and 5 others like this.
  6. GordonC
    GordonC
    WOW! Amazing talent!
    Stogy, loudbang and fauj like this.
  7. 41 GMC K-18
    41 GMC K-18
    This should be on display at Tiffany's or Cartier as Superior Automotive Jewelry !
    Magnificent craftsmanship!
    Stogy and loudbang like this.
  8. waxhead
    waxhead
    from West Oz
    The Winfield carb looks amazing, outstanding work.
  9. BigRRR
    BigRRR
    As already stated, you work is beyond impressive - keep posting and inspiring the rest of us. Look forward to seeing them up and running!!!
  10. Kevin Pharis
    Kevin Pharis
    from Califunny
    Thanks for the kind words fellas! I will continue to post progress rain or shine;)
    My hope is to make some good progress on the throttle barrel thru the holiday... if only there were fewer holiday obligations! What good is a day off of work if you can’t spend it out in the shop...?!:rolleyes:
  11. fourd
    fourd
    from Colorado
    Simply amazing work!! I love the tumbled look but the polished looks even better.
    I recall reading (years ago) that down the street from Winfield's shop there was a place that plated a lot of bronze items like trophies and baby shoes and that that was the source of the "copper" plating. From this and the hint of plating left on my carbs I always ***umed they were bronze plated.
    https://caswellplating.com/electroplating-anodizing/bronze-plating-kits.html
    Stogy, Carter, loudbang and 1 other person like this.
  12. It seems that you have an abundance of talent, and use it wisely.
    Stogy likes this.
  13. Kevin Pharis
    Kevin Pharis
    from Califunny
    Well now... there’s a word rarely used to describe my actions...! ;):p
    Outback, Stogy and loudbang like this.
  14. Dean Lowe
    Dean Lowe
    I cannot remember when a piece of work impressed me as much as this Winfield has. That finished float bowl is stunning!
    Outback, Stogy, badshifter and 5 others like this.
  15. Kevin Pharis
    Kevin Pharis
    from Califunny
    It took a bit longer than expected... but I’m finally ready to make some real progress on the Winfield S-B throttle barrel! After probably 150 hours of design and programming, I hope to finally start cutting on a block of aluminum tonite.:eek:
    To be continued...
    Stogy, Carter, loudbang and 2 others like this.
  16. Looking forward to watching you work, Kevin!!!
  17. Kevin Pharis
    Kevin Pharis
    from Califunny
    Was able to spend the day in the shop today, and made some good progress on the first operation of the throttle barrel. This one won’t be perfect as there were a few small “oops” moments along the way... but should finish out good enough to test with if I can avoid any major mistakes before finishing. This is as far as I could go with the tools on hand, and won’t be able to finish the center bore till I order a few special tools next week
  18. I am really enjoying being along for the ride on this one! Great work!
  19. Dean Lowe
    Dean Lowe
    Like I said, stunning!!
    Stogy, fauj and loudbang like this.
  20. continentaljohn
    continentaljohn
    Wicked cool
  21. loudbang
    Mind blowing
    Stogy, TFoch and fauj like this.
  22. cfmvw
    cfmvw
    That's a work of art!
  23. nrgwizard
    nrgwizard
    from Minn. uSA
    Jeez, Kevin;
    When you start marketing these, you may as well call the company; "Just Because I Can!" , because, well, you can. & very well I might add. :D .
    Marcus...
  24. This is too bad***!! You should make a small run of them!
  25. WOW!!!! Crazy how awesome this is. Do you think you may start selling them?
    Stogy, kidcampbell71 and loudbang like this.
  26. Kevin Pharis
    Kevin Pharis
    from Califunny
    The original plan was only to make a few of the small parts... but you can see how well I am sticking to that plan?!
    The current plan is to produce the S-B downdraft carburetor in its entirety. I should be able to finish 5 complete carbs... then I’ll figure out if there is enough interest to make more... or maybe even other sizes...?
    Outback, Stogy, kidcampbell71 and 2 others like this.
  27. If you need any product shots / marketing help, thats what I went to school for!
  28. Kevin Pharis
    Kevin Pharis
    from Califunny
    I’m not exactly close to making this decision, but...
    Should I polish...?
    Or copper plate...?
    I’m thinkin copper plate!:D
    Outback, Lil'Alb, 41 GMC K-18 and 9 others like this.
  29. TFoch
    TFoch
    Very nice either way! Impressive work!
    Outback, 41 GMC K-18, Stogy and 3 others like this.
