I have a 30-31 B'ville roadster body. Nothing in the catalog to help. Also sent pictures to B'ville 2 weeks ago and got no reply. I have two pieces that I'm not sure where they go. Pretty sure 1st picture is correct but have no idea where the other part shown in the second picture goes. Are these to support the seat back? Thanks
Thanks for the hit. Yeah it looks like it sits up from the bottom. Any thoughts on the other piece in the lower photo?
The piece laying in the clamp goes on the bottom of the piece that is clamped. It is for adjusting the seat back. That is the reason for the double holes.
Take it from some one who knows if you can afford to leave that tiny package tray out you may gain 2 more inches in the **** pit. A good trade off. Mine had that tray behind the seat and I didn't remove it. I am 6 ft. tall and just fit in the car now as is. The 2 inches would have helped.
Thanks. Might take a cue from Gordon and leave both off. I'm thinking some sq. steel tube to reinforce the area.
Thanks! The wife and I whipped it up at home! First time trying it. Good idea to use some tube under there to brace it up. Also give you something to attach a bulkhead to.
called a package tray... better be a small yet heavy package or it could be bouncing down the road behind you...
On a coupe it would be called a package tray, on a roadster it is called a seat adjuster. Ford advertised there roadsters as having an adjustable seat. The piece in the second picture is part of the wood seat frame. If you decide to not use it you should think about replacing it with something else. It adds quite a bit of rigidity to the body.
