Projects My 1929 Project
Discussion in 'Traditional Hot Rods' started by Ken Crone, Dec 8, 2020.
  1. Ken Crone
    Ken Crone
    IMG_2864.JPG IMG_2866.JPG I have had this car for 1 year already and it has been a steep learning curve. It is a build from the late 50s I think. I have it running pretty well on the 3 97s with a progressive linkage. I have been a bystander for many years on the H.A.M.B. and decided I need to step up!
    48fordnut, Tman, 51 mercules and 23 others like this.
  2. 66gmc
    66gmc
    Wow, nice roadster! Do you have any more pictures of it?... it looks like it's got all the right parts and a great stance!
    Stogy likes this.
  3. typo41
    typo41
    And a quickchange!!
    Stogy likes this.
  4. 38Chevy454
    38Chevy454
    Stogy likes this.
  5. Kirky
    Kirky
    Looks great so far
    Stogy likes this.
  6. 2935ford
    2935ford
    '29 roadsters make great Hot Rods!
    Have fun! :)
    Stogy, Hemiwoody, 66gmc and 1 other person like this.
  7. Model A Gomez
    Model A Gomez
    Great looking project looks like it could be on the street, a lot more fun when you're driving them!
    Stogy and 31hotrodguy like this.
  8. Ken Crone
    Ken Crone
    Here is a picture from a few days ago. Had to limp it home something is haywire with the motor. More after I do some trouble shooting. Timing seems to be way off???
  9. 36and63
    36and63
    from Wisconsin
    That's a nice looking roadster, I to was a bystander too but not anymore:)
    Stogy likes this.
  10. AHotRod
    AHotRod
    That is a sweet roadster Ken... more pictures please.
    Let us know what you find with the engine.
    Stogy, 31hotrodguy and Packrat like this.
  11. ROADSTER1927
    ROADSTER1927
    Looks great and let us know if we can help!
    Stogy likes this.
  12. Just.dale
    Just.dale
    Nice!!!!
    Stogy likes this.
  13. 63tango
    63tango
    Model As with Flathead V8s are soo cool!!! I miss my 29 pickup with a V8-60.
  14. Ken Crone
    Ken Crone
    Here is what I have determined so far. I had the car running well on 3x2s with a progressive linkage. It was not burning much oil and did not get hot with a new Walker radiator. I was putting short trips on it because I knew the motor was old. On my last trip it started running ruff and would not idle. Limping home I started troubleshooting. Fuel pump ok, coil ok, changed condenser, still will not idle below 1400-1500 rpm. Pulled distributer reset points and checked overall mechanics, seemed fine. Still will not idle and run smooth for a minute or so with the choke out, that holds idle at above 1400,then it shutters for a bit and smoothies out again. I think something has changed and the distributer is advancing the time enough to keep it running.
    I have done several compression tests and the compression is good maybe too good. At 125-135 maybe the cam is flat and it is not releasing enough pressure between strokes?
    This is all I know for now. I am waiting for a e fire distributer if that does not help [ I am not holding much hope] the motor is coming out.
  15. Mikko_
    Mikko_
    from Sweden
    Looks really good I must say.
    Stogy likes this.
  16. brady1929
    brady1929
    Cool roadster.
    Stogy likes this.
  17. Ken Crone
    Ken Crone
    First Stromberg E-Fire did not fire waiting for exchange[emoji31]
    Stogy likes this.
  18. Ken Crone
    Ken Crone
    [​IMG]Here are some pictures from working on my bushed paint job. I really wanted to try to keep what I do to the car similar to how they would have done in their garage back in the 50s
    48fordnut, Stogy, brEad and 1 other person like this.
  19. Jeff34
    Jeff34
    Great looking ride! Double check the coil. Mine had the same symptoms when it warmed up. Rebuilt the coil and now it’s much better. Just my $0.02
    Stogy likes this.
  20. spit6
    spit6
    Lots of inspiration here. I know there is a thread on here about brush painting
    Stogy likes this.
  21. Ken Crone
    Ken Crone
    Still not right but yesterday as I was running the motor and looking for clues I found a crack in the cap. The fan is very close to the cap and about every 20 or so (I did not count) they sink up and a spark jumps across. Time for a new cap.
    48fordnut, Stogy and 31hotrodguy like this.
  22. neds29
    neds29
    Great looking A. Why not leave on the fenders? The dropped headlight bar and big and littles look cl***ic. Are you sure it's not a '28? Hard to see but it looks like the single taillight is mounted on the left rear of the body?
    Ned
    chop job and Stogy like this.
  23. 4bangerbob
    4bangerbob
    from AB, Canada
    Yes Ned is right, all model A had single rear light on right side. early 28's had the mount on the body, then later they moved over to fender mount.
  24. Ken Crone
    Ken Crone
    Here is a pic of the mounting bracket. I am not sure what it is off of but someone recognized it. I can not remember what they said.
  25. lamaison
    lamaison
    from Canada
    That's how the tail light was mounted on the early 1928 bodies. Looks like the bracket has been modified (shortened) somewhat. By '29 they were mounted on the fender. No outside door handles was another '28 feature.
    Stogy likes this.
  26. Slick111
    Slick111
    Your tail light is a very early 1928 AR model
  27. Stovebolt
    Stovebolt
    Here's one in its "natural habitat"
  28. neds29
    neds29
    Not to belabor the point, but my January '29 roadster had a single body mounted taillight and it had outside door handles. I think they stopped making those body mounted taillights just a little later in early '29.
  29. Ken Crone
    Ken Crone
    New cap and points. Still running poorly. I have the timing advanced as far as i can, it runs but still has no low end. I put a vacuum gauge on it and at idle it only has 5-8-5-9-4 psi. The needle is all over the place. At 2000 RPM it stabilizes but is still only up around 14 psi. I think my valve guides are gone. Is there a way to check this? I should probably pull the intake and see, one may have failed while I was driving. This would explained why it started to act up. The compression is good but as i think about it bad guides would not show on a compression test would it?
  30. jhexide
    jhexide
