Projects 1927 T Roadster Build
Discussion in 'Traditional Hot Rods' started by Joe Coughlin, Dec 16, 2020.
  1. Joe Coughlin
    Joe Coughlin
    Thought I’d post some pics of my 27 T roadster build. I bought the car with the body sort of bolted down to a 30-31 model A frame with drivetrain. I’m going to get it running with the Model A drivetrain for the meantime. I have a Mercury 255, 39 3 speed and V8 rear to go in the car eventually. IMG_1763.JPG IMG_1762.JPG IMG_5194.JPG IMG_5196.JPG
  2. Joe Coughlin
    Joe Coughlin
    Some pics of pulling the 255 merc engine from the junkyard earlier this year
    Squablow, Jeff34, Outback and 12 others like this.
  3. Joe Coughlin
    Joe Coughlin
    Some pics of the frame I bought to get all the trans, rear axle and any other usable parts. The frame was pretty rotted out through the X member and the rails IMG_5271.JPG IMG_6637.JPG IMG_6646.JPG IMG_6644.JPG IMG_6645.JPG
  4. Joe Coughlin
    Joe Coughlin
    I was also able to find a 28-29 model A radiator for it. I think the lower profile of the 28-29 rad better matches the lower profile of the T body
  5. Joe Coughlin
    Joe Coughlin
    I’ve also got a set of 16” Kelsey Hayes bent spokes for the car. Still need blasting and powder coating
  6. patmanta
    patmanta
    from Woburn, MA
    So, what's the plan?!?!? Looks like a great start!
    That looks like dirt to me (though that does hold moisture). I'd bet you can get enough out of that X member to be useful on a T build. Those later frames are a lot bigger than a T, A, or 32 frame so there is a lot of material to choose from.
    The Spring-ahead and spring behind setups can get you down pretty low without frame kicks or dropped axles. I would try to salvage that rear sweep and crossmember. You can graft them onto an A frame if you go that way. You can also swap that crossmember for an A crossmember and run an A spring back there so you don't need a panhard bar.
    Here is my 29 AAV8 on AA rails. It has a late axle (that is dropped) and rear setup like that under it. The front is on a piece of box tube inside the frame rails and the rear is on a crossmember that is similar dimensionally to what you have there with the frame kicked up 6". It put this thing quite low.
    (It's not sitting totally dragass, that's a trick of the perspective mixed with the rear bones not being attached to anything)
  7. Joe Coughlin
    Joe Coughlin
    Your truck looks good, I’ve always liked the model a trucks.
    The frame was a lot worse than it looks on the pictures. I did keep a couple of the frame parts but a good chunk went in the scrap metal bin. I kept all the mechanical parts off it, steering column, pedals, wishbones etc. I’ve also got a 32 Ford K member to put into the car.
    I’m going for a prewar look at the moment. That will have to change if I put the 8ba in it as that’s a 49-53. So I’ll have to either find an earlier motor to keep it prewar or just go for a early 50s look. I’ve done a lot of the work already and the car is about 95% road ready at the moment. I’ve just been going through my photos and decided to post some of them here.
    scott27 and patmanta like this.
  8. Joe Coughlin
    Joe Coughlin
    So these are the front body mounts I put together. I know a lot of people weld something to the top frame rail to mount it. It probably would have a been a lot easier if I had done it that way, but this is the way I did it. They bolt to the inside of the frame rail and the mount comes up and meets the top frame rail to mount the body
    IMG_5514.JPG IMG_5515.JPG IMG_5598.JPG IMG_5599.JPG IMG_5623.JPG IMG_5624.JPG IMG_5510.JPG
  9. Joe Coughlin
    Joe Coughlin
    Once I had the radiator mounted properly I could then set the headlights up. I had a stock model A light bar and some later model headlights (not sure of the year). Played around until I found a height I liked. I cut the ends of the bar and welded them underneath at frame width and blended the ends of the headlight sockets.
    IMG_5426.JPG IMG_5427.JPG IMG_5915.JPG IMG_5916.JPG IMG_5953.JPG IMG_5966.JPG IMG_5967.JPG IMG_5970.JPG IMG_6009.JPG IMG_6028.JPG IMG_6029.JPG IMG_6001.JPG IMG_6002.JPG
  10. getow
    getow
    Awesome start. Good find.
    Joe Coughlin likes this.
  11. patmanta
    patmanta
    from Woburn, MA
    Thanks!
    Well, as far as the 8BA goes, I'm pretty sure you could run 59AB style center spout heads to get the look or just go for the prewar look as if the engine got swapped later on.
    Outback and Joe Coughlin like this.
  12. Joe Coughlin
    Joe Coughlin
    I ditched the factory updraft carb for a single 94 on a Burns downdraft manifold. I had to modify the manifold slightly to fit with the stock Model A exhaust manifold. I rebuilt a 94 carb I had and fitted it. I built new fuel lines for the car because I was ditching the model T cowl gas tank in favour of a oval Model T tank in the trunk. I decided to build a heat shield for the fuel line at the carburetor to hopefully avoid any vapour lock issues. I used the factory Model A throttle linkage mounted on the back of the block and made a pivot and new short throttle rod to hook it all to the carb. I also ended up replacing the exhaust manifold as the one on there was too warped to seal on the block
    IMG_5708.JPG IMG_5907.JPG IMG_6088.JPG IMG_6090.JPG IMG_6682.JPG IMG_6683.JPG IMG_6685.JPG IMG_6687.JPG
  13. 1-SHOT
    1-SHOT
    from Denton
    Gas does not gravity feed up hill. You may need a pump. The early T had to back up a hill some times because gas would not flow to carburator especially below 1/2 a tank
    HemiTCoupe likes this.
  14. Joe Coughlin
    Joe Coughlin
    I’ve got a 6v pump mounted under the chassis at the rear.
  15. 1-SHOT
    1-SHOT
    from Denton
    Love your build, glad to hear about the pump
  16. Joe Coughlin
    Joe Coughlin
    Pedal clearance for the Model A pedals is an issue in the already tight confines of a model T*****pit. I removed the factory floor brace to allow more room for the pedals and the floor. I laid out some templates and tried some designs for the beads in the floor until I found something that worked. I cut the floor out of steel, laid out the bead designs and built a structure for the floor to rest on. The puny Chinese bead roller I have was not going to give the results I wanted in the floor so I had to send the floor to Rods and Restos in Strathmore, Alberta to get the beads done on a pullmax. I was very happy with the results, I had to alter the initial design slightly but came out with a better end product. I welded all the braces into the Model T and installed the floor. The floor panel must have been in and out of that car well over a hundred times during the build.
    You can see how much more room the braces gave over the factory ones
  17. Joe Coughlin
    Joe Coughlin
    Some pictures of making the trans cover and the pedal and steering column surrounds
    IMG_6350.JPG IMG_6330.JPG IMG_6405.JPG IMG_6410.JPG IMG_6497.JPG IMG_6505.JPG IMG_6515.JPG IMG_6515.JPG IMG_6517.JPG IMG_6522.JPG IMG_6411.JPG IMG_6413.JPG
  18. modelacrazy
    modelacrazy
    Floor panels are awesome! Great build. The heat shield on the carb looks spot on as well, I really like where this is headed, Gow man Gow!
  19. Joe Coughlin
    Joe Coughlin
    Thanks man. I’ll still got some more build pics to post
    modelacrazy likes this.
  20. modelacrazy
    modelacrazy
    The 16” bent spokes are gonna be perfect on the car, can’t wait to see them mounted up. The stock A wheels look like they have deep rubber too. I subscribed of course lol
  21. Joe Coughlin
    Joe Coughlin
    Thanks. The tires on the car at the moment are pretty much brand new.
  22. Joe Coughlin
    Joe Coughlin
    IMG_6050.JPG IMG_6314.JPG IMG_6316.JPG IMG_6351.JPG IMG_6352.JPG IMG_6353.JPG IMG_6359.JPG IMG_6366.JPG IMG_6372.JPG IMG_6373.JPG IMG_6375.JPG
    Squablow, Outback, Jeff34 and 11 others like this.
  23. rjgideon
    rjgideon
    Thank you very much for posting those hammer form pics. I need to do the same on my car and while I had the general idea, your pics help me visualize how it will meet up with the original dash panel. Your floors look really great as well!
    HemiTCoupe and Joe Coughlin like this.
  24. Joe Coughlin
    Joe Coughlin
    Thank you
  25. patmanta
    patmanta
    from Woburn, MA
    Wow, I REALLY like what you've done with this floor and interior space in general! Is it all held in with rivnuts and 1/4-20's?
  26. Joe Coughlin
    Joe Coughlin
    Thanks, yeah its all rivnuts and 1/4 x 20 bolts for now. eventually I'm gonna swap them out for stovebolt screws to give it more of a riveted aircraft style look
    Squablow and patmanta like this.
  27. ChuckleHead_Al
    ChuckleHead_Al
    Wow, amazing job on your roadster, you just created a lot more leg room with your new floors. I want to do the same with my T, but I lack your skills. I'm subscribed to get more ideas from your build.
  28. Limey Kid
    Limey Kid
    Great work. Every inch counts in a T roadster if you want to sit "in" it not "on" it.
    Cheers,
    Stewart.
    Squablow and Joe Coughlin like this.
  29. Joe Coughlin
    Joe Coughlin
    Thanks, I really like your T. Yours is one of the ones i was looking at for ideas for mine. I ve had a picture of it saved on my phone for a while.
  30. Joe Coughlin
    Joe Coughlin
    Thanks. that is the struggle, trying to get low enough to look good driving it but high enough to be comfortable. I'm 6'2" as well so i need all the room i can get in it
