Technical How do you get to this?
Discussion in 'Traditional Hot Rods' started by koolbeans, Dec 17, 2020.
  1. koolbeans
    koolbeans
    Stance, front axle drop, wheels, 8" rear axle, wheels, juice brakes, of course with 4cyl, and auto. Kool looking. FB_IMG_1607911793503.jpeg
    Sent from my XT1710-02 using The H.A.M.B. mobile app
  2. Bob Lowry
    Bob Lowry
    The first step is to want to get to one...the rest will happen ....
  3. millersgarage
    millersgarage
    zero rear suspension, looks cool, rides bad
    okiedokie, Hnstray, Dino 64 and 2 others like this.
  4. 2OLD2FAST
    2OLD2FAST
    from illinois
    4 cylinder = won't maintain highway cruising speeds .
    I imagine you could just go buy one ....
  5. The37Kid
    The37Kid
    Nice shot, is there a drop off or did you dig a six foot deep hole?
    Bob
    Rehpotsirhcj and Bandit Billy like this.
  6. X38
    X38
    That car looks familiar. I think it lives in my neck of the woods somewhere.
    lothiandon1940 likes this.
  7. X38
    X38
  8. ironandsteele
    ironandsteele
    49ratfink likes this.
  9. swade41
    swade41
    from Buffalo,NY
    This T has the same great stance
  10. X38
    X38
    Couple more black A coupes in my neck of the woods.
    itsmee, tombstone, RustyDogg and 5 others like this.
  11. 56sedandelivery
    56sedandelivery
    Beautiful cars!!! I am Butch/56sedandelivery.
  12. koolbeans
    koolbeans
    Check out the Ford 2.3 eco boost 4 banger crate motor at 320 hp. Don't rekon that'll push that rascal down the super slab?
    Hnstray, upspirate and lothiandon1940 like this.
  13. X38
    X38
    ...which are OT here;)
    upspirate and alanp561 like this.
  14. Mr48chev
    Burning down the highway at or well above posted speeds is fun but isn't everything. There is a lot to be said for cruising along at a more comfortable speed on more interesting roads and enjoying the hell out of yourself.
    On the other hand I have a 1600 CC 130 hp banger with a strong 5 speed to go behind it sitting out here that would run down the road at 80+ all day long and not break a sweat and give you 25 or better mpg but it would be off topic as hell even though it is 28 years old. I could put four side drafts or injectors on it though.
    As far as getting one or building one that takes starting with a plan and sticking to the plan.
    Hnstray, upspirate, Ebbsspeed and 3 others like this.
  15. grumpy65
    grumpy65
    Let's read between the lines here. I think 2OLD2FAST might have been refering to the original 4 cylinder engine.
    Still, way cool. :cool::cool::cool:
    Hnstray and Desoto291Hemi like this.
  16. woodiewagon46
    woodiewagon46
    from New York
    Very cute, is that a '29 Fordor Sedan hood I notice?
    The37Kid likes this.
  17. Kevin Pharis
    Kevin Pharis
    from Califunny
    Not sure what bangers you been hangin round...?! I used to run my flathead T at 80-85 when I was running 3:1 gears in the rear. Kept breaking gears so dropped down to 3.63:1 and now I cruise at a much safer 65-70. I will admit that I don’t want to maintain those speeds for more than an hour or two... but that’s because of the car, not the motor. I would much rather spend my day cruising the back roads at 55-60, and jump on the highway occasionally to burn out the carbon;)
    A model A or B motor will do much better for much longer with much less effort to build than a T. And there is much more speed equipment available for the A and B motors as well.
    Jet96, adam401, jbwthree and 3 others like this.
  18. 2OLD2FAST
    2OLD2FAST
    from illinois
    I have been around numerous , naturally aspirated , 4 cyl vehicles in the last 50 years to understand that at highway speeds , they're working hard , in a vehicle with the aerodynamics of a concrete block , in a slight headwind or on an interstate grade , they struggle mightily to maintain speed .
    koolbeans likes this.
  19. Hitchhiker
    Hitchhiker
    I find this funny, only because I think most A's ride like ****!
    Last time I checked i can drive my A on the freeway.
    HSF, Cliff Ramsdell, -Brent- and 3 others like this.
  20. -Brent-
    -Brent-
    T rear spring would get you close to that rear position along with a reverse eye front and dropped axle.
    4.50 tires in the front and 6.50s in the rear look to be what this car is sporting. It won't feel too bad and get the steering, bones, and alignment right and it will drive decent, too.
    Tman and koolbeans like this.
  21. Run a 5speed stick behind a 4 cyl. and 3:73 - 4:11 rear gears. A 153 Chevy with a good carb,and headers should do fine on most highways.
    upspirate and Chicster like this.
  22. koolbeans
    koolbeans
    Now that's what I was looking for. Thanks. Wheels and brakes would be helpful.
    Going to wherever "there" is, is about the friendship, scenery and yum for the tum. Super slab only for going home to your bed to rest the back.
    Dick Stevens and 61Cruiser like this.
  23. AccurateMike
    AccurateMike
    Tell this guy...
    modified 4-Bangers
    Mike
  24. -Brent-
    -Brent-
    Wheels 16" 35 Ford wires
    Brakes, juice brakes, likely. 1940 and up spindles, backing plates and drums.
  25. koolbeans
    koolbeans
    Thanks. Any such like 15 fronts, 16 rears, wide fives??? I think that could be kool too.
    I figured a maverick/8" rear, buggie spring, reversed eyes, good shocks.?????
    Front spring reversed eye, maybe 2-3" dropped axle, good shocks.????
    Thoughts?
  26. Stan Back
    Stan Back
    Dash2.jpg Dash 1.jpg These look a little scary . . .
  27. koolbeans
    koolbeans
  28. X38
    X38
    Well... you asked about stance and a 4 banger a**** other things. Discussion about 4 bangers ensued. One guy posted a pic of the instruments in what must be a 4 cylinder car doing almost 80. Another member observed that the other gauges are reading almost zero and brought that to our attention.
    I'm surprised there hasn't been more comment about 4 cylinders and autos.:eek:
    This is a forum, not a government survey.;)
    thintin, RICH B and Happydaze like this.
  29. alchemy
    alchemy
    That coupe at the top has 16" '35 Ford wires with probably 4.50 or 5.00 tires. The rears are 18" '32 Ford wires with probably 7.00 tires. They are bias ply and there are no radial alternatives that will give those same proportions.
    Is say the front axle has a deep drop, the spring has reversed eyes, and it's probably been flattened a little too. The rear of the frame might have a little Z, and the spring is probably a T or maybe a flattened A.
    Also, it would take a thick special spacer to fit the stock Ford wheel to an 8" Ford rearend.
  30. Wanderlust
    Wanderlust
    Was going to mention no oil pressure or water temp seems like a farce, but I was beat to the punch
