Technical Holley 650 CFM Fueling Issue
Discussion in 'Traditional Hot Rods' started by gonzo, Dec 19, 2020.
  1. gonzo
    gonzo
    E893F73C-6597-4797-BE47-C1E59AEBCEBD.jpeg 5BAE5767-B761-448C-9CC2-5C8FC17AE435.jpeg
    I have an oddball problem with the Holley on my 283. Motor has a mild cam and pulls about 15 in of vacuum at idle. Every time I try to run the motor it floods right away, and by flood I mean fills the intake with gas and fouls the plugs. I've changed the power valve and the power valve gasket and fuel is still somehow getting into the back of the metering block and leaking down the power valve check valve port. Anyone else ever run into this issue? I figured I'd ask before ordering another power valve and a new metering block. Here's a few pictures of the carb for reference. Thanks in advance.
    Edit: It's a 600 cfm carb not a 650, if that makes any difference.
  2. 2OLD2FAST
    2OLD2FAST
    from illinois
    Check the flat carb body surface with a gauge block or good straight edge ..that surface almost looks like someone used a rol-loc disc on it...
    gonzo likes this.
  3. gonzo
    gonzo
    I think your seeing casting marks on the carb but I'll check it again.
    Thanks.
  4. gimpyshotrods
    gimpyshotrods
    Any particular reason why you have chosen a carburetor that is over 170% of what this engine is likely to need?
    There is only so much adjustability that can be taken advantage of here.
    porknbeaner, 19Eddy30 and Truck64 like this.
  5. gonzo
    gonzo
    I was told a Holley 650 with vacuum secondaries should be fine with this motor but that shouldn't be relevant to the issue at hand anyways, which is gas getting behind the metering block into the power valve cavity.
  6. gimpyshotrods
    gimpyshotrods
    Not sure who would have told you that. If you fix the issue at-hand, you might be right up against a tuning issue.
    Proper fuel atomization is dependent on the proper velocity of air moving over the venturis. If that velocity is not correct, you will not have proper atomization. This cannot be corrected with tuning.
    19Eddy30 likes this.
  7. gonzo
    gonzo
    I just realized I wrote multiple times that it's a 650 CFM carb, it's actually a 600. Still probably a little big for this application but if it doesn't work out I'll find another home for it.
  8. saltflats
    saltflats
    from Missouri
    What does the gasket look like that you are using?
    Tickety Boo, Tim_with_a_T and gonzo like this.
  9. gonzo
    gonzo
    Do you mean the power valve gasket or the metering block gasket? The PV gasket came with the new PV and the metering gasket is the blue Holley one. There were no obvious tears or issues with it but I have not replaced it yet. I'll do that next but I was curious if it was possible for the metering block itself to fail.
  10. scofflaw
    scofflaw
    from Ohio
    Had a similar problem a few years ago. I changed gaskets, metering blocks, float, etc. Turned out to be a hole in the fuel p***age for the needle and seat. Even though the float would lift and shut off the fuel flow, fuel would p*** right through the hole in the p***age, over flow the carb and pool in the intake.
  11. gonzo
    gonzo
    No kidding, that is an oddball problem. Did you have to replace the carb to fix it?
    I'll definitely check that out. Thanks.
  12. X38
    X38
    So the fuel pressure is correct and float level correct? In that order.
    midroad, gonzo and Tickety Boo like this.
  13. gonzo
    gonzo
    Yes. Im running off a mechanical pump but I tested it off a hanging auxiliary bottle to byp*** the pump.
    The fuel is dripping right out of the power valve check ball / vacuum port, not the venturis.
  14. X38
    X38
  15. Tim_with_a_T
    Tim_with_a_T
    X2 for wondering what the gasket looks like between metering block and main body. I was called about a similar problem a few years ago- just dumping fuel down the intake. Turned out to be the guy installed the wrong metering block gasket, which was causing the power valve p***age to leak directly down into the intake.
    gonzo likes this.
  16. gonzo
    gonzo
  17. gonzo
    gonzo
    I'll triple check that today.
    Thanks!
  18. egads
    egads
    Thats your issue-- wrong gasket. See the U shaped cutout above the power valve-That gasket is for a metering block that uses a transfer tube to the main body.
  19. 2OLD2FAST
    2OLD2FAST
    from illinois
    Beat me to it !!
    Deuces, gonzo and mad mikey like this.
  20. Tim_with_a_T
    Tim_with_a_T
    ^^^ What they said. This is the same problem I described above. Swap out that gasket for one that just has a hole for that p***ageway (no horseshoe) and you will be good to go.
    Deuces, X38, gonzo and 2 others like this.
  21. 2OLD2FAST
    2OLD2FAST
    from illinois
    Gonzo. You'll find your accelerator pump is gonna actually work now ....
    Deuces and gonzo like this.
  22. egads
    egads
    Use this one--[​IMG]
    fredeuce, Deuces, gonzo and 1 other person like this.
  23. onetrickpony
    onetrickpony
    from Texas
    What they said. Wrong metering block gasket. That gasket is for the carbs that use the o-ringed transfer tube.
  24. gonzo
    gonzo
    Hell yeah. Thank you guys.
    Deuces and egads like this.
  25. scofflaw
    scofflaw
    from Ohio
    Yes. I sent pictures of the issue to Holley thinking they might send a new carb body at a discount. They ended up offering me a new carburetor if I returned the defective unit to them. Pretty cool since my carb was way out of warranty.
    I guess in the early 2000’s they had a defective batch, prone to zink pest problems in the fuel bowl,(super dangerous) and they wanted them back and out of service.
  26. Deuces
    Deuces
    Did you have that new gasket on hand???... Did you get it fixed????.... How does it run????...
    Inquiring minds like mine want to know!.o_O:rolleyes:
    gonzo and egads like this.
  27. gonzo
    gonzo
    I've ordered the gaskets and they're supposed to arrive at the parts store tomorrow. I will update the thread as soon as I get it put back together.
  28. Deuces
    Deuces
  29. gonzo
    gonzo
    Put the carb back together tonight and things are 90 percent fixed. No more flooding the intake or fouling plugs. I've still got an intermittent hanging idle and a midrange popping issue that I need to resolve but I have a feeling the last guy who had this apart may have messed with the choke mechanism so I'll play with that and see if I can get it perfect but as of now it's pretty dang good.
    Thanks a million guys, who knows if I would've ever figured that out on my own!
    Oilguy, Deuces, triumph 1 and 5 others like this.
  30. 2OLD2FAST
    2OLD2FAST
    from illinois
    Do a bit of looking at various dual throttle return springs & the way they're generally installed , might help your idle hang up . what I see currently is pretty rough . Once the choke is open , it has nothing to do with how the engine runs ,many times an intermittent miss can be traced to an ignition issue ...
    gonzo and Deuces like this.
