  1. jimmy six
    jimmy six
    It’s what you did back then.
    loudbang, HEMIDAV and Bleach like this.
  2. stude54ht
    stude54ht
    from Spokane WA
  3. Jimbo17
    Jimbo17
    I also had a starter motor connected with a belt on a hand truck to start my McCulloch engine back in the 60's and early 70's
    Jimbo
  4. George Klass
    George Klass
  5. chevyfordman
    chevyfordman
  6. hotrod1120
    hotrod1120
  7. Born too late
    Born too late
    M&T made most of these little amu*****t ride trains. poster-ad-cover 1951-11-24-the-billboard-p58.jpg
  8. HEMIDAV
    HEMIDAV
    from FL.
    My "HAT" is off to BLEACH ! Good job !
  9. HEMIDAV
    HEMIDAV
    from FL.
  10. Born too late
    Born too late
    nice conduit bumper. if it went faster, the whistling would drive them mad...
  11. Bleach
    Bleach
    HEMIDAV you're no slouch either! I really enjoy your posts. KUDOS to you my friend!
  12. HEMIDAV
    HEMIDAV
    from FL.
  13. HEMIDAV
    HEMIDAV
    from FL.
  14. HEMIDAV
    HEMIDAV
    from FL.
  15. HEMIDAV
    HEMIDAV
    from FL.
  16. HEMIDAV
    HEMIDAV
    from FL.
  17. HEMIDAV
    HEMIDAV
    from FL.
  18. HEMIDAV
    HEMIDAV
    from FL.
  19. HEMIDAV
    HEMIDAV
    from FL.
  20. HEMIDAV
    HEMIDAV
    from FL.
  21. HEMIDAV
    HEMIDAV
    from FL.
  22. HEMIDAV
    HEMIDAV
    from FL.
  23. Bleach
    Bleach
    I never knew MW ever had any catalogs. Then again we were a Sears family since my mom worked for Sears.
    HEMIDAV, loudbang and chryslerfan55 like this.
  24. ned5049
    ned5049
    Only two chains. Way before D.O.T. Inspections. Especially California ! 130920467_10208606287750683_511682150383310534_o.jpg
  25. Born too late
    Born too late
  26. Born too late
    Born too late
    various. last is the b-36 that hauled the nuclear engine aloft. note the nuclear symbol, and hole near the tail that was the exhaust, and air scoops. the plane was not powered by it. B-50 in background. Al***ude test/ how nuts is this test tumblr_nlsjdz969S1tc5lyxo1_500.jpg 4521b44f7639f133d7fef51de5a20303.jpg 3 6 1 2.JPG x211.jpg planes nuclear rocket engine possibly.jpg Usa Air Force Convair Crusader.jpg
  27. 302GMC
    302GMC
    from Idaho
  28. old flopper
    old flopper
    Did you have a throttle plate in the carb? Played with a twin engine McCulloch kart a little in 60’s that was direct chain drive (no clutches), which had to be push started or rolled off a stand after start. It didn’t have throttle plates in carbs of either engine. Gas peddle just contacted a normally closed kill switch hooked to both engines. If pedal was pressed (switch open) both engines were wide open, lifted foot off switch both engines were off but turning because of kart momentum, when you hit switch again like coming out of corner it ran wide open down straight away until foot off switch causing kart to coast into next corner. Only way to pace it on pace lap was rapid tapping of switch.Wild ride for sure!
    61Cruiser, HEMIDAV, RMR&C and 3 others like this.
  29. Born too late
    Born too late
    Miss es***. a remington bernelli rb2. i found a pic of this like ten years ago and had no idea what it was. the body is a lifting body, which allowed it to carry the most weight of the period. (body is wing shaped and adds lift). the pic i saw was this goofy looking thing crashed at logan airport in boston. didn't look too aerodynamic. actually was a beast. Hudson hired it in 1925? to fly an es*** terraplane around the country. no details on crash at boston. was fixed and finished its life flying freight. 1 is the pic by leslie jones that started it. 2 next pic i found of model. was colorful. still no idea why it was named such. 3. car inside. 4. headlights peaking out thru window. 3. another crash view, spare tire is visible thru the window. 5. trials at mitchell field long island. took me a while to figure out the where. 6. the pic that told me the where. in middle left, note the visiting ships lettering. the rest are various , and a U 20 bernelli that ford and sunoco hired to show how cool they were. i'm sure they milked it for high al***ude/cold weather "stuff". they prob hired the guy weighing 10w30 from a few pages back. solid data folks.
    Miss Essex (3).jpg miss essex.jpg miss essex Burnelli rb-2 show room.jpg miss essex Burnelli-RB-2. Note car headlights peeking out window down the wing 1925..jpg car is inside 5 (note spare tire in window).jpg miss Essex in front visiting ships  hanger Mitchel field long island.png Mitchel Field 10-28 aerial view. Note Visiting Ships Hangar seen in larger image of plane.jpg miss essex Burnelli rb-2 show room (3).jpg bernelli u-20 Ford-Sunoco mileage extreme weather test (3).jpg bernelli u-20 Ford-Sunoco mileage extreme weather test (2).jpg bernelli u-20 Ford-Sunoco mileage extreme weather test.png bernelli u-20 Ford-Sunoco mileage extreme weather test.jpg Burnelli u-20 Ford-Sunoco mileage extreme weather test (3).jpg
  30. jimmy six
    jimmy six
    Henry obviously did not believe in an air conditioned environment for his employees.
    fbi9c1, HEMIDAV, loudbang and 2 others like this.
