Projects New to H.A.M.B and I need some help
Discussion in 'Traditional Hot Rods' started by harleyd20, Dec 22, 2020.
  1. harleyd20
    harleyd20
    So.......... here’s my problem. I own a ‘37 1/2 ton, except for the paint it is running, solid and original. It is in need of a restoration and my dilemma is how this should be done. I can use a dropped front axle, 235 with a T10, etc, etc. Or I can go with front and rear Corvette suspension, Small block with a automatic, etc,etc. I currently own most of the major parts to do this truck either way. What do you guys think about this soon to start project?
  2. 325w
    325w
    Welcome aboard. Talk beam axle. Vette rear will cause you to be ignored. 235 with T5 seems to be ok.
    scotty t likes this.
  3. Absolutely 6 cylinder, 5 speed!!! Have something a little different!
    Torkwrench likes this.
  4. belair
    belair
    The Corvette running gear is probably off topic here. We lean to the hot rod as opposed to the street rod. Learn the rules and the ethos of this place. The 235 combo will get a lot more f love, EFI, none. A 1st gen SBC will get the love and would work good. I used a 250/th350 in a 48, it was a gas. Again read the rules, don't get your ******* in bunch if/when you get a post or pic deleted, and you will have access to some of the greatest mechanical minds around. And we like pictures. Welcome.
  5. alanp561
    alanp561
    Just a suggestion, read the rules for this forum. This is for cars 65 and back and mainly for traditionally built cars. What 325w said is absolutely correct. All that being said, Welcome. There are a lot of knowledgeable guys on here and they don't mind sharing.
    There you go Arkie, I fixed it.
    Torkwrench and 31hotrodguy like this.
  6. Lloyd's paint & glass
  7. Howdy.
    Screw the vette ****.
    Dropped axle and possibly springs.
    If ya go 235, make sure it’s the full pressure one.
    Post some dang pics
    https://droppedaxles.com/
    mad mikey, Torkwrench, Tman and 4 others like this.
  8. Jibs
    Jibs
    Welcome aboard neighbor, I'm live in Canonsburg. Definitely dropped beam axle, but sbc for power. Pictures & more pictures.
  9. dirt t
    dirt t
    There's no sound like a split 6 exhaust.
  10. jimmy six
    jimmy six
    He doesn’t say what year Corvette. Until he’s is newer than 65 I’ll listen...
  11. gassersteve
    gassersteve
    wow new people still make it to here?
    Boryca likes this.
  12. Lloyd's paint & glass
    That's very true! And better than hearing mustang ii
    mad mikey and Boryca like this.
  13. Lloyd's paint & glass
    I'm gonna throw my vote in for straight axle with a small block/T10 combo.
  14. arkiehotrods
    arkiehotrods
    I wish that HAMBers, especially long-time members, would stop saying this site is for "64 and older" or "pre-64." Ryan sez (and this is from the rules HE wrote) "We cover traditional '65 and older American cars only."
    Did you get that? '65 and older. Not pre-65, not pre-64, not '64 and older.
    Blue One, 41woodie, Hnstray and 10 others like this.
  15. goldmountain
    goldmountain
  16. Welcome, and good luck with the build on your truck. As you start your journey here, you'll quickly realize that the New HAMB will only allow you to do what they want to your truck. Permission will have to be asked for, and then given, for you to proceed on your truck. My advice is to ignore the opinions, but pay close attention to the technical advice. The wealth of information at this place is second to none.
    osage orange, 73RR, Hnstray and 7 others like this.
  17. DDDenny
    Small block Chevy.
    Painted Chevy Orange.
    Dems da rules!
  18. stillrunners
    stillrunners
    from dallas
    Yep - didn't read the year of Vette - guess it's the time of season to pounce first and ask questions later.
  19. Budget36
    Budget36
    I ***ume we’re talking about a ‘37 Chevy PU? V8 isn’t an easy a drop in than the inline, but doable.
    There’s many other good places to visit if you decide on the Vette stuff
  20. brokenspoke
    brokenspoke
    Show us pictures of what you have to work with....
  21. 27 Tall T
    27 Tall T
    from Butler Pa.
    Hi neighbor, just up the road from you Butler pa.. As the others have said no to the corvette ,Mustang 2 etc. inline six will be a good choice. I have a T5 behind a Flathead in my 46 ford coupe and it works well.
  22. alanp561
    alanp561
    Take a look at post 5, Arkie, my bad, I fixed it
    arkiehotrods likes this.
  23. bowie
    bowie
    Welcome aboard, old time rules say if your just going to talk about it by the year; it MUST be a Ford. Other wise you need to say what make. That aside , I figured you meant Chevy since you said 235”. The exception to the above rule is if you say ‘55 or ‘57... In regards to your Chevy , personally I’d go with a 283 “or a 327” with a Muncie or a T10.
    mad mikey and chryslerfan55 like this.
  24. v8flat44
    v8flat44
    Another vote for the 235......split 6 Chevy's sound awesome..."dare to be different"
    Maicobreako likes this.
  25. Roothawg
    Roothawg
    I am ***uming it is Chevy? If it is a Ford, forget the 235, it’s too long.
  26. guthriesmith
    guthriesmith
    I'm going to guess Chevrolet based on the avatar. And, another vote for dropped axle and either a 235 or maybe a 265 or 283 if you want to put late model stuff in it. :D Oh, and be sure to check out www.droppedaxles.com when you decide you need the axle. Sid is a HAMBer and will take care of you.
  27. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    I don't understand the negativity. The OP asked for opinions and got some. He was also told why the Corvette options were less than appealing for the majority of the members here.
    I own a '37 Chevy and I can tell you that putting a SBC or a 235 six are both good choices. I wanted to be different and opted for the later 292 six. That was a lot more work due to the length of the engine. The automatic is MUCH easier in this car than a stick. Mine is a stick.
    Mine has an OT front suspension but I didn't replace a beam axle.
    Welcome aboard!
  28. mr.chevrolet
    mr.chevrolet
    yep, take a ride to Canonsburg. Me & Jibs will show you some stuff. Bring a Dollar, the tour ain't free.
  29. 40FORDPU
    40FORDPU
    Welcome.
    The obvious answer for this crowd/site is to go the dropped axle route.
    Depending on what you want the truck to "give back" to you, is what cons***utes direction of build, considering drivability, amount of intended miles to be driven, comfort (or lack of), any physical limitations, etc.
    Personally, dropped axle, sbc, m/t would be my choice, but I'm not the guy behind the wheel.
    chryslerfan55 and kidcampbell71 like this.
  30. ol-nobull
    ol-nobull
    Hi & welcome. If you want to try to be different just like most everyone else use a dang ho hum V8. If you want to really be different and go to car shows & such and really draw lots of public and interest stay with an inline 6 as there will not be much else there with them. There are still lots of the 235, 261 or 292 engines still out there. Even the newer 270" engines. The 216, 235 & 261 are the same length with the 270 & 292 being a bit longer.
    My Avitar photo on this post shows the 235 I have in m 46 Chevy Coupe. Bored 0.060, Clifford cam, Dual 2 bbl intake & shorty tube headers. Atop the Clifford intake are 2 of the big Weber Carbs and they work great. Just had to engineer some throttle linkage. It has been a great cruiser & even has vintage air. It has been down a bit over a year now as I got rear ended and have put off the rebuild but hopefully I will get that going sometime this year.
    Keep us posted and start a build thread with photo's as work progresses. Jimmie
