Technical 54 210 Trunk
Discussion in 'Traditional Customs' started by buzzbrother, Dec 23, 2020.
  1. buzzbrother
    buzzbrother
    Starting to refinish trunk and body panels. What is all this gummy black ****! It is 1/2 inch thick in some spots. Pain in the rear to get it off. Any suggestions??
  2. 49ratfink
    49ratfink
    sounds like a job for a heat gun.. like a hairdryer but on steroids
    buzzbrother likes this.
  3. 5window
    5window
    Yep, and pictures, too. I have had good luck with the HF guns, not to start a Harbor Freight discusssion. But, they're like $10 and you can buy several..
  4. buzzbrother
    buzzbrother
  5. 5window
    5window
    I don't know. Factory coating or maybe someone went crazy with bed liner spray as a rust prevention?
  6. 5window
    5window
    If you got it cold enough, would it harden so you could media blast if off?
  7. fastcar1953
    fastcar1953
    factory uncoating. some may break off. most won't
  8. Mr48chev
    Under coating that is tar based, paint on bedliner hadn't been invented when that was put on. it was originally put on those fenderwells to dull the thud of rocks hitting the undersides of the wheel wells plus maybe seal the seams.
  9. 325w
    325w
    Factory stuff.
