Customs MY SHOWROD BUBBLETOP BUILD
Discussion in 'The Hokey Ass Message Board' started by THE KUSTOMIZER, Dec 24, 2017.
  1. COCONUTS
    COCONUTS
    Yea, run the engine in the rear with the timing chain facing the rear (mount the engine backwards) hook the motor to a trans then to a heavy duty truck transfer case, with the driveshaft running back to the rear-end. You will have the entire front of the vehicle to do as you please. Sounds easy, too easy, now where is the bubble top going?
    Stogy, loudbang, kiwijeff and 2 others like this.
  2. lippy
    lippy
    from Ks
    Is that roof the same as a 59 chevy? Lippy
    Stogy and loudbang like this.
  3. THE KUSTOMIZER
    THE KUSTOMIZER
    from south nj
    Its harder than it sounds..LOL!! I know where the bubble is going I dont know where the driver and p***enger are going to sit..LOL!!
  4. THE KUSTOMIZER
    THE KUSTOMIZER
    from south nj
    yes
  5. Rick Coast
    Rick Coast
    its going to be awesome ,great body to start with. cool design from original .
  6. bigdog
    bigdog
    Nice. I need a pair of those quarter panels for the boxsides on my '53 Chevy.
    Stogy, THE KUSTOMIZER and loudbang like this.
  7. tb33anda3rd
    tb33anda3rd
  8. THE KUSTOMIZER
    THE KUSTOMIZER
    from south nj
    Thanks
    Stogy, loudbang and chryslerfan55 like this.
  9. THE KUSTOMIZER
    THE KUSTOMIZER
    from south nj
    As it is dec 25(as I have done for years) I figured I would post some shots of what I am up to on the car.I have been working on what was the trunk now the engine compartment I removed the trunk gutter area and what I would call a metal waterfall as the metal rolls over the side.If you look close you will see I have also been working on the top area for the bubble you will see more on that later as I prepare to blow the bubble.Hehe!!! 20201213_150221.jpg 20201213_150235.jpg
  10. THE KUSTOMIZER
    THE KUSTOMIZER
    from south nj
    I just realized Ihavent updated in a while I added 5 1/2 inches to the rear fins.more coming... 20200901_134819.jpg
  11. gimpyshotrods
    gimpyshotrods
    An Olds Toronado or Cadillac Eldorado transaxle (with an adapter to the engine of your choice) looks.
    I have a Wilcap adapter on mine, that attaches a Chrysler Hemi.
    A Nailhead adapter can likely be had, or made.
    The tie rods can be locked-out.
    Despite outward appearances, they TH425 is mostly a TH400 inside.
    For what it is worth, the track (tread) with on that Olds is 63.5", as is the Cadillac.
    Coilovers can replace the torsion bars, to reduce the size of the ***embly.
  12. gimpyshotrods
    gimpyshotrods
    If you are utterly irresponsible, and are up for a ridiculous amount of fabrication, you can go mid-engine.
  13. THE KUSTOMIZER
    THE KUSTOMIZER
    from south nj
    I was thinking of going this way but I allready have a trans and transfer case from a blazer I know I like to do things b*** ackwards.Lol!!!
    rodncustomdreams, Stogy and loudbang like this.
  14. gimpyshotrods
    gimpyshotrods
    Which transfer case?
    chryslerfan55, Stogy and loudbang like this.
  15. THE KUSTOMIZER
    THE KUSTOMIZER
    from south nj
    np205
  16. gimpyshotrods
    gimpyshotrods
    Excellent choice!
  17. THE KUSTOMIZER
    THE KUSTOMIZER
    from south nj
    Thanks its the strongest one I know of..
  18. gimpyshotrods
    gimpyshotrods
    Yup, Strongest OEM unit from anything smaller than a 2-1/2-ton truck!
  19. THE KUSTOMIZER
    THE KUSTOMIZER
    from south nj
    Well the bubble is blown!!!here it is set up on the base that I made.After seeing the what bad chad did on his tv show I thought that may be the easiest option for me I dont have pics of the blow up because I was there by myself and only had a short time to do it I started by calling the local powder coaters to see if I could rent there oven on a non busy day I found one that agreed to give me a call when he had down time.I used to 3/4 inch plywood cut my hole in one used a bedsheet in between with slices cut into it add an air fitting and ball valve and gauge and i am ready to go.Using 1/4 acrylic sheet.I got the call to come over after alittle trial and error I wont bore you with ..I got it where I wanted it..Heres a pic enjoy!!! 20210311_140034.jpg
  20. aircap
    aircap
    Well, there won't be another like it first time you go to the Sonic.
  21. blowby
    blowby
    from Nicasio Ca
    Wow great job! Car is going to be *****in'.
    loudbang, Stogy and THE KUSTOMIZER like this.
  22. Peanut 1959
    Peanut 1959
    Looking good! Congratulations on the successful effort.
  23. THE KUSTOMIZER
    THE KUSTOMIZER
    from south nj
    Thanks!!!
  24. THE KUSTOMIZER
    THE KUSTOMIZER
    from south nj
    Thanks!!
  25. Stogy
    Stogy
    Milestones are awesome...congrats on this and the others however minor @THE KUSTOMIZER
    It's interesting the extended fins which are radical and very fitting don't have that same effect in the Bubble shot but all Hotrod/Customs have their angles that set off their many features...
    I was also thinking about you replacing the vintage front suspension. It actually adds something out of this world to the shot from the front in a good way in my opinion...might be nice to leave it as ballast for the rear engine. How does that knee action perform...maybe you can get it to raise and lower hydraulically.
    I actually saw an old Hotrod A pickup not so long ago here that was swapped onto a Chev Ch***is and it had that suspension...I was looking at it scratching my head thinking how unusual it looked...
  26. chevy57dude
    chevy57dude
    This is completely off the hook!
    These dudes think you need more tailfin.^
  27. THE KUSTOMIZER
    THE KUSTOMIZER
    from south nj
    Thanks Stogy I think the fins are fine its the angle that the pic was taken.As far as the front suspension your right it adds ballast and looks cool and the gas tank will up there also.Its funny you mension hydraulics..I have already figured out how to do an airbag setup on it..
  28. THE KUSTOMIZER
    THE KUSTOMIZER
    from south nj
    Thanks
  29. Stogy
    Stogy
    KUSTOM I read you were working on an air setup...is that actually in unison with the vintage knee action or in place of? That is why I mentioned modding the original front suspension hydraulically.
    I recall the Mechanic working on that A pickup on the early chevy frame saying the suspension may have been adjustable...The owner or that truck ditched the old and I completely lost interest in it...I figure it was a 50s 60s Hotrod prior to the new iteration underway...happens a lot...:oops:
    It's funny, I have done a fair bit of searching in google patent and there may have been a genius that had drummed up something along the lines of what you've proposed...sometimes our news ideas are actually very very old news, and there's truly nothing wrong with that either...
  30. THE KUSTOMIZER
    THE KUSTOMIZER
    from south nj
    The air bags will work with the knee action I have removed the springs from inside the cylinders and the shock valving and oil that was in there.So the air bags will adjust the ride height..
