Projects United Pacific 5W Deuce Build
Discussion in 'The Hokey Ass Message Board' started by Groovy, Feb 18, 2017.
  1. Fortunateson
    Fortunateson
    I'm betting on the locomotive. Is Endura a Canadian company? Now what I'm really interested in is your painting in sub zero temps (zero Celsius is 32* Farhenheight for those not on the Metric/Celsius systems). What type of paint is it? Any special prep? Made especially for cold weather painting? Cost per s really intrigues me...
  2. Fortunateson
    Fortunateson
    I went to Endura's web site and they state that painting temps should be betweeen 20-25* Celsius so how do you manage to paint in such a cold temp?
    Blue One and loudbang like this.
  3. Groovy
    Groovy
    Yes 30tudor I built Factory 5 Shelby Cobra replica.
  4. Groovy
    Groovy
    Fortunateson... Painting at 0 degree temperatures is no problem. I pull the item outside just before I start painting. I put 3 coats on waiting about 10 minutes between coats. The parts get cold but I like the fact that Endura lays on so nice in these temperatures and with the proper technique there is less chance of orange peel but have to be careful not to lay it on too thick and get runs. When I am done I bring it back in the shop which is usually at 70 degrees and within 5 minutes the parts are warm and the drying begins.
    ENDURA is geared more to be an industrial coating and you wouldn't find conventional bodyshops using it. It is mixed 1 to 1 then spray. I've found some colors like white need some thinner to get it to flow better. For some reason it can be too thick and have a tendency to orange peel.
    It is a very hard finish and holds up extremely well in adverse conditions. Whenever possible parts that I want painted, if I don't have to do any body work to them all I do is sand blast and paint directly to the metal. It does not chip off easily.
    The red on the frame cost $100.00 per quart for the color and $50.00 per quart for hardener.
    I see there is an Endura Manufacturing in Surrey 604-513-1456
  5. Fortunateson
    Fortunateson
    Ok now I understand though the "painting in sub-zero temps" was a tad misleading as it implied the curing/drying as well. I couldn't figure out how the chemistry would work at such low temps. Thanks for tip about Endura in Surrey. I'll investigate further.
  6. goldmountain
    goldmountain
    Really intrigued by the painting out in the cold idea. No bugs, no stupid cotton from the trees, no leaves falling, good lighting. Just have to figure out how to move the OT car out of the driveway with its spin on the ice summer tires. The joy of building cars in Canada.
    rod1 and loudbang like this.
  7. Groovy
    Groovy
    Firewall is painted... IMG_3876.JPG IMG_3875.JPG IMG_3877.JPG IMG_3872.JPG IMG_3874.JPG IMG_3871.JPG
    Just Gary, alfin32, brEad and 8 others like this.
  8. goldmountain
    goldmountain
    Di you paint that outdoors too? Looks great.
  9. Groovy
    Groovy
    Yes was painted outdoors yesterday in below zero temperature IMG_3888.JPG IMG_3889.JPG IMG_3890.JPG IMG_3886.JPG IMG_3887.JPG . I'm not happy with the finish. Of all the parts painted to date this looks the worst but it's going to have to do.
    More progress with fuel filler installed and mocking up heater byp*** hose...
    alfin32, kidcampbell71 and loudbang like this.
  10. hotrodA
    hotrodA
    That firewall is beautiful. That really flowed out smooth.
    brEad and loudbang like this.
  11. the flatlander
    the flatlander
    If you ever get to my friend Roy Brizio's, look up on the shelf or in the shop. He has no quams about building 'gl*** cars. And his customers can surely afford what they want. I mfg. 'gl*** bodies & cars for years and most, like Subarus , are still on the road somewhere. Just build what u can & DON'T put it off. See ya on the road....someday. Answers still free here.....
    loudbang and Just Gary like this.
  12. brEad
    brEad
    I thought the firewall looked good, too!
  13. Groovy
    Groovy
    My 16 x 5 1/2" IMG_3935.JPG IMG_3937.JPG IMG_3938.JPG American Racing Salt Flat Special wheels arrived.
    Panel has nutserts installed to attach fuse panel...
  14. rustymetal
    rustymetal
    love the colours will the paint stand up to the engine temperature and is the same that is on the frame
    thanks
  15. Groovy
    Groovy
    The floor is sanded and masked off to be painted gray. Only had 2 wheels arrive from American Racing so had them mounted to the tires. Mounted the rears on the front to get a feel how it will look.
    Installed the upper rad hose. Just need to trim to fit.
    E brake cables are installed on the diff and working on fabricating a bracket for the other end. IMG_3980.JPG IMG_3981.JPG IMG_3987.JPG IMG_3982.JPG IMG_3984.JPG IMG_3948.JPG IMG_3950.JPG IMG_3975.JPG IMG_3978.JPG IMG_3957.JPG
    The 39 guy, alfin32, brEad and 2 others like this.
  16. lcfman
    lcfman
    from tn
    Looking really good. Are those radiator mount springs available?
  17. Groovy
    Groovy
    They are available and the supplier I used was Vintique Inc. #B-8130-S --- 1928 / 48 Original Black Radiator Mounting Kit ---
  18. Fortunateson
    Fortunateson
    Painted out doors in sub zero weather and dried indoors at appropriate temp... that process really intrigues me. Your paint lays out very well, do you think that is due to the cold temps when applying?
  19. Groovy
    Groovy
    Today the floor was painted.
    Fuse block panel installed.
    Fortunateson The cooler temperatures will always let the paint flow out more but proper mixing procedures also need to be followed for proper viscosity.
    IMG_3998.JPG IMG_3997.JPG IMG_3996.JPG IMG_3988.JPG IMG_3989.JPG IMG_3992.JPG
    brEad, alfin32, flynbrian48 and 3 others like this.
  20. Groovy
    Groovy
  21. lcfman
    lcfman
    from tn
    Looking good can you show a photo of your trunk latch and striker as I am putting together a united pacific 5 window and would like to see a picture.
  22. Groovy
    Groovy
  23. Groovy
    Groovy
    Ch***is webbing is installed.
    Epoxy primed around fuel filler.
    E-brake bracket painted... IMG_4034.JPG IMG_4035.JPG IMG_4036.JPG IMG_4033.JPG IMG_4031.JPG IMG_4039.JPG IMG_4037.JPG
    The 39 guy, alfin32, brEad and 3 others like this.
  24. Groovy
    Groovy
    E-brake cables and brackets are in.
    Body aligning pins are ready and brackets attached to rear of body to attach tiedown straps to hang body from body hoist.
    Next step is drop body onto ch***is and bolt down... IMG_4047.JPG IMG_4048.JPG IMG_4063.JPG IMG_4053.JPG IMG_4049.JPG IMG_4052.JPG
  25. pprather
    pprather
    Will you be able to adjust e-brake cable from below after the body is installed?
  26. Groovy
    Groovy
  27. Groovy
    Groovy
    Body is finally bolted down... IMG_4090.JPG IMG_4087.JPG IMG_4088.JPG IMG_4089.JPG IMG_4091.JPG IMG_4099.JPG IMG_4107.JPG IMG_4108.JPG IMG_4111.JPG IMG_4113.JPG
  28. Groovy
    Groovy
    Only a few things done today...
    Trans boot installed, p IMG_4120.JPG IMG_4121.JPG IMG_4117.JPG IMG_4118.JPG IMG_4119.JPG IMG_4115.JPG edals installed, Clutch linkage bolted in, fuel line hole in floor started.
  29. nobby
    nobby
    nice thread
    nice pics
    nice car.
    something about exhaust scavenging..I only say it as just today I bought a real dhort exhaust header...
  30. Groovy
    Groovy
    IMG_4141.JPG IMG_4139.JPG IMG_4131.JPG IMG_4128.JPG IMG_4136.JPG IMG_4133.JPG IMG_4134.JPG IMG_4132.JPG IMG_4143.JPG IMG_4144.JPG .
    Added an 1156 signal socket to the tail lights to make wiring easier and better visibility. Painted the inside of the housing white to illuminate better.
    Brake and clutch pedal linkage is installed. Changed the orientation of some bolts and subs***uted others. Marked the trunk lid sides for t******* & finally added rad rod support...
    Stogy, alfin32, brEad and 5 others like this.
