Technical Sbc exhaust manifold question/help
Discussion in 'The Hokey Ass Message Board' started by Aloria85, Dec 26, 2020.
  1. Aloria85
    Aloria85
    Hey guys I have what I believe is a sbc 305 and just bought a set of tru-ram natural finish cast iron exhaust manifolds from speedway. My question is would you guys just use high temp exhaust silicone as a gasket or would you use a Normal gasket to install? The application is in a 32 pickup. Also would you guys have the manifolds coated or just leave them in their natural finish?
    Deuces likes this.
  2. Natural finish for me.. and back in the day the factory didnt use gaskets.. But I use the FELPRO ones myself.
  3. Also using that red temp silicone on a exhaust manifod, When it squishes out looks down right NASTY !
  4. Aloria85
    Aloria85
    Would you use a light silicone bead to just hold the gasket to the manifold to help keep them in place for install?
  5. 325w
    325w
    Don’t need to hold in place the exhaust manifold gaskets for the iron manifolds will catch on the mounting bolts.
    Deuces, Aloria85 and Truckdoctor Andy like this.
  6. egads
    egads
    No gasket on a small block.
    squirrel likes this.
  7. nope.... no silly stuff
    Kinda self explanation...
    Elcohaulic, 1934coupe, Deuces and 5 others like this.
  8. I have heard that the factory never used gaskets, but the heads and manifolds had better be damn straight to not leak. My luck is never that good. I use the FelPro gaskets mentioned above.
    Deuces, mrharley51, bchctybob and 2 others like this.
  9. Aloria85
    Aloria85
    Awesome thanks for all the help guys, and sorry for the noob questions! Those definitely are different then the ones provided with the manifolds, I’ll have to get some of those. Just to be safe would you have the manifolds machined and made sure they’re flat or run as is right out of box?
    Deuces likes this.
  10. The ONLY Sto0pid question is the same one asked twice !
    Deuces, scotty t and Aloria85 like this.
  11. Put a straight edge across them
  12. mad mikey
    mad mikey
    The Eastwood Company has a real good manifold coating you can spray or brush on. Comes in cast color or silver I believe . And yes, use gaskets.;)
    Deuces and olscrounger like this.
  13. squirrel
    Just bolt them on, and run it. No sealer, no gaskets. But use lock tabs on the bolts at the outer bolt locations, like Chevy did.
    and a thick, small OD flat washer between the lock tab and the manifold, and under the two center bolts also.
    I would probably spray the manifolds with black high temp paint, and watch it bake off over time.
    -Brent- and egads like this.
  14. olscrounger
    olscrounger
    I painted stockers on my 57 Fuely with the Eastwood cast color and put on BBQ--they lasted great for years.
  15. '49 Ford Coupe
    '49 Ford Coupe
    Lock-***e on the bolts if you don't have the tab locks. With gaskets they will loosen, probably.
    Aloria85 likes this.
  16. Paint or coat them now before they rust.
    I used some VHT on mine. Followed the baking instructions. So far so good.
    I have used the orange silicone, doesn’t need much, with no issues.
    I am using the 3 piece (each side) gaskets on my rams horn manifolds. No issues.
    I have also not used anything without issues (on Fords)
    It’s all up to you.
    Glad I could clear it all up
  17. jimmy six
    jimmy six
    When they were new they were straight on both surfaces and didn’t leak.
  18. bobss396
    bobss396
    I used gaskets on mine, they came with the Dart aluminum head set. I sprung for good stainless bolts and washers from Ace Hardware, $36 IIRC.
    I had the manifolds gl*** beaded, chopped off anything I didn't like and smoothed them over. The driver side was from a '65 or '68 Chevy, p***enger side from Dorman, fits a Chevy truck with a 45-degree dump. Painted with POR15 manifold paint and baked in the over per what the can said. The finish is durable coming up on 5 years.
    Deuces and dirty old man like this.
  19. Buy gaskets. They are cheap and work well.
    Do Not go for "header" gaskets but the stock ones with the tin on the outside and the gasket material on the inside.
    Deuces and Truckdoctor Andy like this.
  20. squirrel
    I think Chevy never used gaskets on them, to improve heat transfer from the manifolds, so they wouldn't get too hot.
    But the aftermarket engine gasket sets include gaskets for them. They are not needed.
    427 sleeper, dirty old man and egads like this.
  21. egads
    egads
    Chevrolet doesn't have a part # for a cast iron manifold gasket. Not gonna convince them Jim.:rolleyes:
    427 sleeper and squirrel like this.
  22. 1971BB427
    1971BB427
    from Oregon
    If you have gaskets that are the metallic style shown above, but don't have the same open bottom holes; just use a pair of tin snips to open the holes up. Then you can bolt up the manifolds loosely, and drop the gaskets in place, and tighten them down.
    I'd never run a SBC without exhaust gaskets, whether the factory did or didn't. Never lucky enough to not have them leak.
  23. dirty old man
    dirty old man
    I agree with Jim as long as the head surface and the manifold surface are straight and flat and both are cast iron.
    As Jim says the direct contact aids in keeping manifold temp down by way of increased heat transfer, and the solid contact allows you to put some actual stretch tension on the bolts, which aids in keeping them tight.
    427 sleeper likes this.
  24. 56sedandelivery
    56sedandelivery
    New manifolds won't be warped, so install them without gaskets. IF they do leak, then install some gaskets that come in gasket kits, that most guys don't use on their manifolds, so a shop may just give you some. I am Butch/56sedandelivery.
    Just went to the Speedway site, the manifolds come with the gaskets, so use them!
    Deuces and Aloria85 like this.
  25. Deuces
    Deuces
    I'm another one that uses Fel-Pro exhaust manifold gaskets.... Including with headers with or without the 1 piece header flanges...
  26. rusty rocket
    rusty rocket
    I have the same manifolds. I had them hitemp coated (Before they had Been installed)in a cast iron color. Sort of gives them a stock appearing look.
    Deuces likes this.
  27. larry k
    larry k
    A old timer once told me years ago , never remove a warm or hot manifold from a engine because it will warp when it cools , for what's that's worth ??????
    Deuces and 1934coupe like this.
  28. 1934coupe
    1934coupe
    Butch you are correct new manifolds are not warped but only if they are new GM. These are Speedway made in China hence the gaskets.
    Pat
    Truckdoctor Andy likes this.
