Technical 1937 Lasalle trans question
Discussion in 'The Hokey Ass Message Board' started by yard man, Dec 28, 2020.
  1. yard man
    yard man
    Afternoon everyone. Had a question or 3 about these transmissions. I’m in the process of dis***embling one, to rebuild for my ‘32 Tudor sedan project. At some stage I’ll do a nice build thread for all of you to tell me what I’m doing wrong,but we’re not quite there yet. Long story short - this trans will go in the Tudor , behind a 331 cad motor with 390 heads, and in front of a ‘57 olds rear end. But more on that later.
    My main question is for the guys who are running or reasonably familiar with the ‘37. I’ve poured thru the old threads beating this dead horse but the primary focus of those has been the sideshift variety. So, I bought this trans, want to take it apart, check everything regasket , reseal repaint and move onto the next . I found a shop manual discussing dis***embly, and seen the steps taken to get the main gear and shaft out, but they don’t really go into detail other than saying there is a special tool that most people haven’t even seen.
    (the actually question) >>>
    How do I get the input shaft out? I pulled the front bearing, pulled the shaft as far forward as I can but it’s not enough to squeeze out past the synchro.
    Once I figure that, do I need to take the shift forks / rails out to get the synchro out, to get the clip off, to get the output shaft out of the main case. I’d hate to come to find that I need this special tool to put. The shift rail mechanism back together . The sideshift trans’ don’t have as much in the way I guess when it comes to pulling the shaft, unless I’m just doing it wrong . 3625E214-CB4F-44FE-BDD3-4E357C63AAC8.jpeg 39CEFF03-DDC8-42E6-A91D-9E109D1419C6.jpeg C553D76C-B0B0-4204-A9FC-8F23698C77BF.jpeg
    Is there any literature on these a rebuild book or a real detailed old magazine article on rebuilding these? There’s so much on early ford 3 speeds but not as much (that I’m aware of) on these, just the ones on converting them for a torque tube .
    Anyone done this recently? Last gentlemen I spoke to on the process mentioned his 37 had been modified to get all that stuff out easier.
    thanks ahead of time.
    kidcampbell71 likes this.
  2. 302GMC
    302GMC
    from Idaho
    Buy a reprint '37 LaSalle shop manual.
  3. yard man
    yard man
    Not sure if I wasn’t clear on this, but I’m trying to do this without the special tool. As I’ve never seen one and they aren’t available for sale.
  4. ROADSTER1927
    ROADSTER1927
    It has been a few years since I had mine apart but I did not need any tools that were not in my tool box. I did make a dummy shaft to put in the counter gear to hold the needle bearings though.
  5. yard man
    yard man
    Great, I’ll dig in
  6. sdluck
    sdluck
    Wooden dowel?
  7. ROADSTER1927
    ROADSTER1927
    That would be fine but mine was plastic just small enough to slide through the case holes.
  8. vtwhead
    vtwhead
  9. Contact Mark Shepard, 1-860-884-6833. Shep has a lot of experience with Cad-Lasalle transmissions.
  10. yard man
    yard man
    Well , I figured I’d share the saga with you all. Managed to
    Get it all dis***embled and cleaned after a lot of head scratching. Didn’t take any pictures out of frustration. After speaking with the guys at northwest transmission parts in Ohio , they sorted me out with new bearings (even the middle bearing that they don’t make anymore), thrust washers seals (ever the one for the shift rail on the front and the shifter) and all the little bits.I could need.
    Got it degreased, fixed a busted ear , painted and re***embled to find a bent mainshaft after getting the tail piece bolted down. So back apart it comes and now I’m hunting for a replacement 24 1/4” shaft if anyone has one kicking around.
    Anyway, here’s some before and after. I’ll try and do***ent a bit better when I take it apart again to replace the shaft when I find one. Need to chrome the shifter arm too.
  11. Beanscoot
    Beanscoot
    Very nice job repairing the ear... is it completely made of braze?
  12. yard man
    yard man
    Tig brazed (silicon bronze)
    Beanscoot and kidcampbell71 like this.
  13. vtwhead
    vtwhead
    I wonder if @Paul might have a main shaft from one of his conversions? At one time I had a 50 Olds main that was bent and found a race shop that straightened it for 25 bucks.
  14. 37 caddy
    37 caddy
    from PEI Canada
    Post over on the Cadillac-Lasalle club forum,im sure someone there might have what you need,its free and easy to sign up,lots of older guys with old parts on there, Harvey
  15. brading
    brading
    I remember years ago reading about guys using the LeSalle box behind there flathead V8 was this because they were a better/ stronger box.
  16. Paul
    Paul
    Editor
    Message sent
  17. yard man
    yard man
    Not “better” but a lot stronger.
  18. brading
    brading
    Thanks for that " yard man "
    yard man likes this.
