Projects 26 T Roadster Pick Up build Thread
Discussion in 'The Hokey Ass Message Board' started by Blue One, Mar 27, 2010.
  1. TerrytheK
    TerrytheK
    He made them. See post # 1435 in this thread!
    @Blue One - I think you better go into production on those babies!
    kidcampbell71, loudbang and Blue One like this.
  2. Blue One
    Blue One
    from Alberta
    I could do that, I’m not sure anyone would want to pay the price.
    3/16” steel plate isn’t dirt cheap but it’s really suited to these stands.
    They stack up in a nice compact pile and aren’t really heavy but they are heavy enough to make shipping an issue.
    Some guys who really like them wouldn’t order them unless they could get them for what they would pay for them someplace like Harbor Freight , Northern Tool or Princess Auto. :D
    kidcampbell71 and loudbang like this.
  3. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    My suggestion is for you to sell the plans with a cut list. That'll separate the doers from the tire kickers. If a guy can't make these himself, he could take the plans to a local fabricator, get a quote and have them made. My guess is $100 ea. U.S.
    kidcampbell71, Blue One and loudbang like this.
  4. Six Ball
    Six Ball
    from Nevada
    Willy Nilly is doing a better job than me. :eek:
    brEad, loudbang and Blue One like this.
  5. Blue One
    Blue One
    from Alberta
    Since I have the intake manifold off for refinishing and other stuff I’ll explain later I decided to relocate the vacuum modulators vacuum source.
    I had it hooked in directly across from the PCV sharing the same vacuum source.
    I wasn’t sure it was working properly and I’ve been told that the C4 will work better with the modulator on a separate manifold vacuum source.
    So I did a little relocation of the 1/4” hardline I installed and routed it into the rear vacuum port on the Edelbrock 573.
    Now it’s all hardline except about 3” of vacuum hose at the modulator.
    I had to remove my ignition coil to get a little bit of work room.
    Changing something that you installed before the body went on is a challenge :D
    Stogy, 32Dan, Six Ball and 7 others like this.
  6. Joe Coughlin
    Joe Coughlin
    The truck looks great. I started reading the thread from the beginning and the truck is a true work of art. Do you ever get to any of the car shows around Alberta?
    loudbang and 26 T Ford RPU like this.
  7. Blue One
    Blue One
    from Alberta
    Thanks
    Since I just got it on the road this spring, not this year with pretty much all official scheduled events canceled.
    I did get out to a couple of local informal cruises.
    I also managed to haul it out to Vancouver island to take my father for a ride and while I was there attended a cruise in Nanaimo. :cool:
  8. Joe Coughlin
    Joe Coughlin
    Yeah it’s been a rough year for car shows, hopefully there are a lot more next year. I’m down in Calgary so hopefully I’ll see you at one and be able to see the truck in person
    Stogy, loudbang and Blue One like this.
  9. Blue One
    Blue One
    from Alberta
    You guys might remember my post on valve adjustment and changing over to the lock nut style valve adjusters because some of the valves would quickly get out of adjustment and noisy.
    So in doing the final adjustment on the drivers side I noticed something that caused some concern. :(
    The exhaust valve on #7 was deflecting off to the side approximately 1/4 “ in the up and down travel as I bumped the engine for valve adjustment :eek:
    I immediately called Tim Mcmaster and shot him a quick little video.
    He was as mystified as I was as to the cause with less than 700 miles on the engine.
    He told me to send the heads to him and that he would go through them and get them back to me.
    So I pulled it apart and boxed up the heads to ship to Hanford Auto.
    Once they arrived Tim called me and said that the guide for that exhaust valve was totally worn out to where you could almost get 2 valves in there. :confused: Really strange.
    He went through the heads cleaned them up and replaced the valve guide and faced all the valves and checked everything out and also installed new valve retainers that have a small rotating cap on top that give the rockers better clearance from the top of the spring as they move.
    He then boxed them up and sent them back to me with gaskets for heads and intake.
    All it cost me was the shipping to get them to California.
    Getting them back in better than new condition was really :cool::)
    All I can say is wow. Thanks so much for your help and support Tim.
    Larry
    AA778EEC-466B-49DB-8737-AFAF50A246DF.jpeg 4392E931-29FE-4C03-BEEA-4350D0315E2E.jpeg
    Stogy, kidcampbell71, brEad and 8 others like this.
  10. The 39 guy
    The 39 guy
    Sorry you had problems with the heads soon after getting on the road. Tim must be a stand up guy. Hope that is the end of your engine problems.
    Seems like these project cars provide us with continuous entertainment even after we get them on road. Thanks for sharing all aspects of your build including successes and challenges.
  11. Blue One
    Blue One
    from Alberta
    Thanks, success and challenges is a good way to put it.
    It’s fun too.
    There’s more to report.
  12. 57 Fargo
    57 Fargo
    Well? The suspense is killing me!
  13. Blue One
    Blue One
    from Alberta
    Since I had the heads off it was a good opportunity to address my fuel supply issues.
    As I posted previously that included the fuel shutoff solenoid valve addition and then it was time to address the paint damage on the carbs and the fuel stains on the intake manifold.
    I contacted Clive at Stromberg and sent pictures.
    He knew immediately what the issue was because back when I had ordered the carbs they had just started to offer custom finishing and had been having the paint work done out of house.
    As a result the paint wasn’t a properly done fuel proof finish.
    He said that they would build me a new set of carbs and then I could ship my old ones to Max in Utah for parts.
    Clive took the time to paint some parts and soak them in gasoline to test and prove the process and finish durability.
    During the process of building my new carbs he also installed # 43 jets and #69 power valves to take care of a rich running condition.
    Once I got them I installed them on my manifold which I had stripped and ceramic coated.
    I also welded up the holes for the exhaust crossover before refinishing.
    That also gave me the opportunity to have the fuel log mount and the manifold hold downs powder coated.
    The addition of 1/4” phenolic spacers that I ordered from Max also required me to make new fuel lines from the fuel log to the carbs.
    One more addition was the Stromberg choke lock out pins on the end carbs.
    So, once again outstanding service and support from Clive and uncle Max at Stromberg.
    It’s great to have such good people to deal with.
    Once again the only cost to me was shipping of my old carbs to Max in Utah along with the purchase price of the phenolic spacers, longer studs and the choke lockout pins. :cool:
    77A7149C-C6E3-4825-89DA-9760D54EDA68.jpeg CD9B2392-4AAE-4DAB-93F6-A66D0E86C615.jpeg BF543DDD-2E80-4DA2-A198-8373FD433653.jpeg 63FD2A1F-8107-484E-92B8-366FEB6C0DCF.jpeg 0FEB643C-921B-4121-8948-6872FB66FF90.jpeg 47886609-BE4B-4BE8-9356-AEECA511F2A4.jpeg 146F4D05-1D00-47F9-BEB7-F621DED7924D.jpeg ADCAB068-A6A6-403E-BA6D-C936D8305EC5.jpeg B375C287-F84F-4152-AF30-30C3EB124B16.jpeg F2BE220C-9770-4CB7-A39D-75E4D35AEE28.jpeg C8716873-A402-4E43-B196-5A3A6B684801.jpeg 2C0A0DCF-F07E-442F-A727-55C710616A50.jpeg
    kidcampbell71, brEad, Tim and 7 others like this.
  14. Blue One
    Blue One
    from Alberta
    A few more pictures. :cool:
    I also relocated the fuel pressure gauge to the inlet side of the fuel log.
    BD4B4C74-AB8B-46C7-B227-C41E2D9D854A.jpeg 67B1E128-E01E-4D90-A3CB-A1BBCBCDB60A.jpeg 673DEF56-2518-4393-87B2-16A698D80753.jpeg
  15. The 39 guy
    The 39 guy
  16. Blue One
    Blue One
    from Alberta
    But wait there’s more :D
    Remember that Finned aluminum transmission pan I cut down to stock depth and installed ?
    Well there was always a tiny drop or two of transmission fluid on the bottom of the fins.
    I’d wipe it down and try figuring out where it came from.
    Finally I thought it had to be the pan.
    So I drained it and blasted it clean and then I did what I should have done to begin with :oops:
    When I modified it I neglected to leak test it.
    I thought I welded it with the TIG inside and out, what could go wrong ? :D
    I bolted it to a piece of 3/4” thick plate and pressured it up.
    Sure enough one corner had tiny almost microscopic pinholes through it.
    Grinding into it I discovered a mess of holes and garbage in the original casting that I chased around for a couple of hours before I was able to get it cleaned out to pure clean aluminum so it sealed up.
    In the end the porous corner turned into a big gaping hole that was completely replaced with clean Tig welded aluminum!
    Then a final pressure test up to 30 psi and a snoop liquid leak test and it was good to go :cool:
    Instead of the spray can this time I dropped it off at the powder coating shop and it turned out really nice.
    15A0E560-477D-4DFD-B48A-3E14BB1D9CC7.jpeg 135D1920-E463-4DC8-A309-AC814E463934.jpeg 61673BDA-6D8A-46A8-9E83-4D3A08B57E69.jpeg
  17. Blue One
    Blue One
    from Alberta
    She’s slowly coming back together.
    Taking my time and enjoying the process.
    I made a new fuel line from the fuel pressure regulator to the inlet of the fuel log to fit the change of where the fuel pressure gauge is.
    The chrome valve cover is temporary coverage.
  18. Six Ball
    Six Ball
    from Nevada
    What is the TW to TD ratio? :rolleyes:
    TW= time working
    TD= time driving
    kidcampbell71, Stogy and loudbang like this.
  19. Tim
    Tim
    from KCMO
    Looks great! Can’t believe that intake got that filthy that fast!
  20. Fuel lines look good, your rather handy with your bender. Did you about **** your pants when you discovered the paint bubbling on your carb?
  21. Blue One
    Blue One
    from Alberta
    :D Yes time working vs time driving is pretty lopsided right now.
    However since it’s cold and snowy at the time being it’s good to have a nice warm heated shop.
    As much as I like driving I’ve really enjoyed building and refining it too.
    Yes, a lesson learned from that, first of all is that powder coating isn’t resistant to fuel stains.
    I’m sure that my fuel leak issues will be cured now and the ceramic coating will be more durable.
    Thanks, the years working as an industrial pipe fitter / welder working along with the instrumentation guys really taught me a lot about running tubing.
    When I saw the paint damage I wasn’t happy but I was prepared to get the carbs refinished.
    I was really happy when Clive stepped up and acknowledged the problem and offered to make it right.
  22. Blue One
    Blue One
    from Alberta
    You know what they say make one little change and it adds 10 more :D
    Adding the 1/4” phenolic spacers under the carbs and gaskets for a total of 13/32” required the fuel lines to be made over again and the next change was to the solid 3/16” stainless steel rod connecting to the throttle pedal.
    After a couple of hours of creative bending and polishing everything clears and works smoothly from idle to WOT.
    All that because the carbs sit 13/32” higher :D
    A0854CB7-B29A-4274-82C0-6A3BB2EFFDA3.jpeg 7E530E31-7B06-4577-9B22-A5C875FF01E3.jpeg 497D8288-62C5-4A1B-A95F-C3C080AE68B9.jpeg F8D9A955-4620-4871-8889-FEA85FC7ECDF.jpeg
  23. Six Ball
    Six Ball
    from Nevada
    Looks great! If you had just taken your time and done it right the first time........:rolleyes: :D
  24. Blue One
    Blue One
    from Alberta
    :D Everyone is a comedian :D
    I’ll take some of the responsibility for this but not all of it :p:D
    Stogy, loudbang and Six Ball like this.
  25. atch
    atch
    I love it when you post up pix of your carbs/intake. There might be a more beautiful 3-2 setup out there somewhere but I have yet to see it.
  26. Blue One
    Blue One
    from Alberta
    Thanks
  27. Tim
    Tim
    from KCMO
    wait till you find out that after being a pipe fitter so long he put it together hanging upside down under the house next to the boiler with a torch running because he just couldn’t get comfortable and focus with it just sitting on the bench in a nice climate controlled shop.
    lol ;)
    loudbang, Blue One and Six Ball like this.
  28. What fittings did you use for your lines to carbs? Those are cool
  29. Blue One
    Blue One
    from Alberta
    Thanks, they’re from Stromberg, chrome 1/4” NPT to 5/16” hard line compression fittings for the fuel log and then chrome 5/16” compression hard line nuts to go into the chrome 5/16” Stromberg S jet fuel inlet valves.
    All the fittings are available on the Stromberg 97 website.
    loudbang and Tim like this.
  30. 26 T Ford RPU
    26 T Ford RPU
    Stunning rework, Larry. Would look great parked at the LARS. :cool::cool: Oh.... all the best for 2021. :D JW
    Blue One, loudbang and AndersF like this.
