Technical ***December 2020 Banger Meet Thread - Lil Saint Nick!***
Discussion in 'Traditional Hot Rods' started by Jiminy, Dec 2, 2020.
  1. Genes12320
    Genes12320
    Great I appreciate it.
  2. Genes12320
    Genes12320
    I am emailing with Jim now also. Thanks
  3. stillrunners
    stillrunners
    from dallas
    Wishing all the best in the New Year !
    Jet96, poshdbs and Old Dawg like this.
  4. V4F
    V4F
    from middle ca.
    thank god , 2020 is over . bad for the whole planet .............
    poshdbs likes this.
  5. Bearing Burner
    Bearing Burner
    from W. MA
    it ain't over till the fat lady sings.
  6. Savage Coupe
    Savage Coupe
    from Washington
    6043327B-2F95-45C5-AFBF-5F2D13E6E3F3.png I saw the other day that H&H is selling a stock looking aluminum head. Does anyone have experience with this head or has anyone ran it? I’m ***uming it’s something new that they are offering? What are your guy’s thoughts?
    winduptoy and Jet96 like this.
  7. poshdbs
    poshdbs
    Could be one of Tod ****ermore's new ones.
  8. I am pretty sure it is not a Tod ****ermore head.
    That chamber looks like the old Silberstein chamber. Pretty good from what I can gather.
    John
  9. railcarmover
    railcarmover
    ^^^ Briggs and Stratton thought so^^^...a couple of heads came out at the same time with the same design..one guy poses the design with a stock top, the other beefs up his aluminum for cooling and support.
  10. Stovebolt
    Stovebolt
    Hi guys.
    Well it's official. I am a banger owner!
    I bought a B powered early A coupe out of the late Harold Johansen's estate.
    This is it as it arrived in the country and released from quarantine 24 hours ago.
    I have to give a big word of thanks, and express my gra***ude, to Dan @Crazydaddyo for all his ***istance with the inspection and my relentless question about this car and bangers in general. Couldn't and wouldn't have done it without your support.
    It was drained of oil, and needs the brake linings put back on as they were removed to appease the Australian government Authorities, and a few other tidy up jobs in order to get it roadworthy to drive out here.
    Anyway, one small question - you can rock the harmonic balancer a few degrees by using the fan belt. Bad or tolerable.
    All the best to you guys (and gals), HNY and stay safe.
    Stovebolt - damn, what do I call myself now?
  11. V4F
    V4F
    from middle ca.
  12. Good on Ya!, That is a nice Coupe.
    I remember seeing it and the rest of the collection before Harolds p***ing and then when they started to go.
    It is a good car, make sure to drive it within the limits of the construction and take care of it.
    As for the balancer, you are probably moving the crank as well, if not fix it. more than likely the key is ******ed up in the crank. If so, replace it with a alloy key, harder material.
    As far as changing your screen name, it is fine, cocaine or heroin are easier habits to quit than Bangers.
    Happy New Year, John
  13. nutrocker
    nutrocker
    Finally getting my motor back together after several issues. Hopefully all issues now resolved.
    CAC15E19-1B78-449B-9040-D0A89BF8D7F0.jpeg 7846F763-1CD2-489C-A89B-791311A80AA5.jpeg 7049B02D-6E8B-4821-AFDC-A60137AEE1A0.jpeg 262EE2F0-230D-49E4-8172-AA918CAF189B.jpeg 69640058-101A-45D6-B28B-324777A47C40.jpeg B7F20C19-BF9F-4843-9AEB-DEECD90F6D5D.jpeg 421ED350-DE7D-4B15-8918-1FC1B88BB36F.jpeg 093CF969-EE52-4B3A-8C12-9D1D4DA7514A.jpeg
    Happy new year to you all.
    Pete.
    Star 351, rwrj, Binger and 12 others like this.
  14. winduptoy, BeaverMatt and nutrocker like this.
  15. poshdbs
    poshdbs
    Glad to see it coming together (after all the problems) again. Good luck mate!
  16. Jet96
    Jet96
    from WY
    A234BB99-BE3F-406A-8BFF-07753B79E7CE.jpeg Got to take the roadster out on the last evening of 2020! Not often I can do that up here in the frostiness.
    Happy New Year you guys
    Old Dawg, barrnone50 and winduptoy like this.
  17. hardtimesainit
    hardtimesainit
    Hey Stolvebolt,
    Congrats. Your a lucky guy !
    Harolds ‘27 T , with the Riley 4-port and homemade “duval” type windshield...was a favorite of mine. Anyone know what happened to that jewel ? Maybe still around for sale ??
    Old Dawg, winduptoy and Stovebolt like this.
  18. Stovebolt
    Stovebolt
    Here's a picture of my coupe when it was owned by Harold, B motor otherwise stock.
    It has a B diamond block, winfield cam and head, single 97 on a burns intake, 12 volt.
    Car has been lowered using a flattened and reversed eye front spring 33-36 axle, 32 spindles, perch bolts and front brakes. The rear has a T spring. The car runs 18" wires
    I feel humbled to now be the caretaker of this car - the only plans I have for it is to make it a reliable, easy car to drive.
    Here's an article about the man himself.
    https://www.hotrodhotline.com/feature/guestcolumnists/richardscorner/08johansen/
  19. Jiminy
    Jiminy
  20. hardtimesainit
    hardtimesainit
  21. nutrocker
    nutrocker
    it’s an oil pressure warning light. When the tonneau cover is fitted I can’t see the dash lights, so added the extra one on the carb.
    Jet96 and winduptoy like this.
  22. hardtimesainit
    hardtimesainit
    Aaaw !
    What was called an idiot light on american production cars !
    Pressure operated. Hooked into oil galley ?
  23. nutrocker
    nutrocker
    yup, that’s it. I have an adjustable pressure switch on the external oil rail that feeds the cam bearings, rocker shafts and oil mist jets for the valve chests. I have it set for 30psi. The light comes on if the oil pressure drops below that level. I expect the light to flicker a bit when the oil is hot and at idle, but that’s ok.
    Jet96, hotrodfil and winduptoy like this.
