Projects The Little Green Roadster that got me here
Discussion in 'Traditional Hot Rods' started by BDUB77, Dec 30, 2020.
  1. BDUB77
    BDUB77
    After a little nudge from @Stogy and @AmishMike, I have decided to create a post on my 27 Chrysler Roadster. I have been a little hesitant to show my work because I am an amateur and have been very humbled by the quality that I see on The HAMB. It is a 27 Chrysler on a 27 frame with a 48 ford front axle, parallel leaves, ford juice brakes, 48 Ford rear end with a model T spring, 354 Hemi, and push-****on cast iron torqueflite. The history of the car is that it was supposedly a dry lakes car in the 50’s that ran a flathead, (I would love to validate that). At some point it became a rat rod, then the next owner attempted to rebuild it into a hot rod.
    I had never heard of the HAMB when I bought this car. I thought I was buying a complete hot rod and had no idea of the amount of work and learning that would be involved. After I got it home, I attempted to pull it out of the trailer and it wouldn’t go into reverse. So I pushed it in the garage and it puked Transmission fluid all over. That certainly set the tone on what would end up being a couple of years of hands-on education for me.
    Since that day I have done the following:
    • Rebuilt the Transmission including replacing the case because it had been cracked and welded.
    • Replaced the rear spring removing 4 inches of spacers (The suspension was still sitting on the bottomed out shocks)
    • Fabricated ladder bars out of ford radius rods along with a crossmember to mount them. (It only had 2 bottom links with heim joints bolted to a single tab with one bolt) The rear end would flop around uncontrollably.
    • Replaced the motor mounts and front crossmember ( The engine was actually angled down towards the front of the car with the intake manifold backwards) The motor was mounted solid only using two of the ears on the block. Thank goodness it wasn’t broken.
    • I went through the motor.
    • Replaced both carburetors with a matched pair of Chrysler dual carbs I found. (One of the previous actually had a homemade Air-fuel screw out of a nail!)
    • Built solid throttle linkage (It was a cable that only had ¼ throttle)
    • Built front headlight and shock mounts
    • Replaced the homemade fuel tank (it had the pet**** on the bottom and a baffle that was broken inside so if you took a corner it could cover the hole) I also did the lines and a better fuel pump.
    • Cut out and replaced the floors and trunk. Did a removable Trans Tunnel (They were s**** metal spot brazed together and covered with about a gallon of resin and a little fibergl***)
    • Moved the seat down and back so I could actually drive the car
    • Replaced the dashboard with a modified Chrysler dash and added early Chevy gauges
    • Rewired the Car to keep it from bursting into flames
    • Built the exhaust
    • Made a custom Transmission dipstick to remove it from the inside of the car.
    • Made some changes in the frame to get everything to fit
    • Replaced the master cylinder and brake pedal / lines/ Drums (The previous MC was in backwards and the pedal was on the left side of the column. As a bonus, the rod only went into the MC about ¼ inch and could loosen up and fall out)
    • New tires and wheels
    I have leaned so much from this car and everyone on the HAMB. My only regret is that I paid too much for the car initially, but it’s cheaper than college.
    Here are some pics of the progress so far in chronological order . The first 2 are from before I owned it.
    I previous.jpg roadster frame.jpg IMG_2332.JPG IMG_2333.JPG IMG_2336.JPG IMG_2338.JPG IMG_3014.JPG IMG_3141.JPG IMG_3313.JPG IMG_3281.JPG IMG_3285.JPG IMG_3451.JPG IMG_3991.JPG IMG_4013.JPG IMG_4022.JPG IMG_4050.JPG IMG_4110.JPG IMG_4127.JPG IMG_4148.JPG IMG_3690.JPG IMG_4262.JPG IMG_4215.JPG IMG_4217.JPG IMG_4222.JPG IMG_4224.JPG IMG_4225.JPG IMG_4228.JPG IMG_4232.JPG IMG_4234.JPG
    Charlie K, Outback, boozoo and 73 others like this.
  2. Tim
    Tim
    from KCMO
    Holy cow! Looks fantastic
  3. sloppy jalopies
    sloppy jalopies
    cool...
    no need to bow your head... work looks great...
    i liked seeing the sharpie marks crossing out a bead....
    i have done that so many times... i wear out the sharpies...
  4. stillrunners
    stillrunners
    from dallas
    Nice.....real nice - you do great work !
  5. continentaljohn
    continentaljohn
  6. Deuces
    Deuces
    Yep! and we love the HEMI.... :D
  7. lothiandon1940
    lothiandon1940
    Very cool Roadster. Looks great.
  8. Stogy
    Stogy
    @BDUB77, thanks for doing a thorough build thread and sharing the history as best as you have found...You really nailed it...
    Truly an interesting Hotrod...and how about those Hemis eh...behemoth powerhouses they are and so fitting a drivetrain choice...that thing must have plenty of get go...
    I look forward to seeing it around here and hearing anything more on it's history as it appears...
  9. winduptoy
    winduptoy
    Sweeeeeet....what is it like not to have a belly ****on?
    Jet96, AmishMike, Frankie47 and 8 others like this.
  10. Chicster
    Chicster
    Very Nice.
    loudbang, Deuces and Stogy like this.
  11. Jalopy Joker
    Jalopy Joker
    a ride to be proud of
    loudbang, Stogy and Deuces like this.
  12. BDUB77
    BDUB77
    Funny,
    I didn't even know I was missing one until a saw one. Now that I have, I have mixed feelings.
  13. warhorseracing
    warhorseracing
    from cameron wv
  14. j hansen
    j hansen
    You did a great job.
    loudbang and Stogy like this.
  15. seadog
    seadog
    Shows what perseverance and determination will do. Well done...a ride to be proud of!
  16. Stogy
    Stogy
    partssaloon, chryslerfan55 and Deuces like this.
  17. harpo1313
    harpo1313
    from wareham,ma
    What a cool looking roadster, You did good.
  18. AHotRod
    AHotRod
    you have a sweet hot rod .... well done.
  19. alanp561
    alanp561
    Well done! How very well done! Do you happen to know what the windshield frame is? I really like it.
  20. alanp561
    alanp561
    What steering box did you use? I can't see it clearly.
    Stogy, loudbang, Deuces and 1 other person like this.
  21. Mikko_
    Mikko_
    from Sweden
    I like it, nicely done.
    Stogy, loudbang and Deuces like this.
  22. Bandit Billy
    Bandit Billy
  23. Okie Pete
    Okie Pete
    Looks great . You removed the ugly .
  24. 57 Fargo
    57 Fargo
    I love it.
  25. BDUB77
    BDUB77
    The windshield frame is handmade from round tube and flat steel.
    Stogy, loudbang, Okie Pete and 5 others like this.
  26. neds29
    neds29
    Really nice job. It's now a good looking hot rod. Congratulations. Ned
  27. Tim
    Tim
    from KCMO
    looks like a 40’s Ford cross steer box that’s tipped further back and then uses a joint to get the steering column pointing back up.
    go back threw the photos it’s in the photo with the new front cross member
  28. brEad
    brEad
    You did great! Nice, unusual roadster - probably be the only one where ever you go.
    Stogy and loudbang like this.
  29. 34Larry
    34Larry
    Extremely cool ride, wow! I have become very fond of things different, just cookie cutter does not do it any more for me. One might offer up, that my ride is cookie cutter, but it is different enough that its picture can not be here on the HAMB. And yours has a HEMI also.:D:cool:
  30. cfmvw
    cfmvw
    Very nice! You have done a great job on it! The car has nice lines and proportions, and I like the color combination of the exterior and interior.
    hotrodjack33, Stogy, loudbang and 2 others like this.
