Technical Y block oil priming.
Discussion in 'The Hokey Ass Message Board' started by Boden, Dec 30, 2020.
  1. Boden
    Boden
    Built a 292 the other day and got around to priming it. It will get oil to the p***engers side bank no problem. But nothing to the drivers. I figured the cam bearing was in wrong, so I pulled the cam and sure enough it was, replaced it with a new one and made sure it was aligned correctly. It is, same exact thing happened again. I can’t figure it out. Please give me some ideas. I can even stick a rod through the hole in the deck through the cam bearing.and even if u pump it up with the head off I still don’t get oil to it.
  2. Boneyard51
    Boneyard51
    Does your cam or cam bearing have a groove in that bearing?
    Bones
    Desoto291Hemi likes this.
  3. 51504bat
    51504bat
    Maybe @mctim64 will have a suggestion. He is all things to Y Blocks.
  4. Blue One
    Blue One
    from Alberta
    That’s the best advice.
  5. Blue One
    Blue One
    from Alberta
    There is one thing that you can take a look at, is it possible that you have your rocker shaft rotated slightly on that bank so that the oil flow hole is blocked preventing oil getting into the shaft and then the rockers ?
    Don’t know if that’s possible or not.
    Boden, Fortunateson and Wanderlust like this.
  6. Following. Considering startling a y block build.
    Been reading oiling/cam bearing threads
    Boden likes this.
  7. junkyardjeff
    junkyardjeff
    Try turning the engine over while priming.
    Boden, Truck64 and ClayMart like this.
  8. miker98038
    miker98038
    If you don't get an answer here, post it over at yblocksforever. Ted Eaton had a post this morning, and there's not much he doesn't know about a Yblock.
    There's some evidence that some cam/bearing combinations don't oil right, and some that many cams don't have the groove cut deep enough. The comment about the rocker arm shafts is correct, but if the heads off it's not that.
  9. jimmy six
    jimmy six
    Since your not getting anything at the hole at the head The cam bearing groove needs to be deeper or the block behind the cam bearing needs to have a groove.
    Did the cam bearing have a groove? It is important that the cam bearing surface still get enough oil too.
    The left rocker arm shaft can only correct or upside down.
    If there is no groove at all you need to be rotating the engine when priming. So it will squirt up the block and to the head.
    Also at the bottom of the head the hole should be chamfered to help flow when you get the oil working.
    Boden likes this.
  10. Not to hijack.
    But, before I buy cam bearings, I need to know what brand cam?
  11. FrozenMerc
    FrozenMerc
    No.
    anthony myrick likes this.
  12. FrozenMerc
    FrozenMerc
    Oil Flow takes the path of least resistance. I agree with trying to spin it over and then try re-priming. Or even just block the p***enger side off and see if any comes up to the drivers side.
    Desoto291Hemi and anthony myrick like this.
  13. Dominick Hide
    Dominick Hide
    I suspect you are working with a cross drilled center journal camshaft, as opposed to the later grooved one. If so then turn the engine a few degrees and then try priming again. It may take two or three turns but pretty sure you will see oil out of the driver side before you have gone 90 degrees. (and p***enger side will stop).
  14. Boden
    Boden
    Cam has a grove. Bearings do not
    Boneyard51 likes this.
  15. Boden
    Boden
    I don’t even have the shafts or heads on. Oils not even making it to the head
  16. Boden
    Boden
    Block and bearing is neither groved. The cam does have a grove. But it’s probably no more than .060-.080 thou deep
  17. warhorseracing
    warhorseracing
    from cameron wv
    As Jimmy Six and Frozenmerc said, rotate the engine while priming. This will require two people, one spinning the crank, or a remote starter switch to operate the starter.
    Boden likes this.
  18. lippy
    lippy
    from Ks
    Start it. Lippy
    Boden likes this.
  19. glrbird
    glrbird
    Check the hole in the block that comes from the center bearing. They get clogged, if wasn’t cleaned in the machine shop. A long drill bit and grease Will do the job.
    Boden likes this.
  20. miker98038
    miker98038
    From John Mummert's site.
    Cross drilled cams, grooved bearings, all complicate this. Ted Eaton likes to grove the block.
    Go down to the cam listings.
    "NOTE: All new cam cores for Y-Blocks are manufactured with insufficient oil groove in center journal resulting in reduced oil flow to rocker arms."
    http://www.ford-y-block.com/valvetrain.htm
    warbird1 likes this.
