Projects Southeast Gassers 65 Comet Super Stock Wagon
Discussion in 'Traditional Hot Rods' started by southcross2631, Oct 28, 2020.
  1. 51504bat
    51504bat
    X2
    loudbang and mad mikey like this.
  2. mad mikey
    mad mikey
    Glad you and your wife are ok. Happy New Year. If I lived close to you, I would drive your machine to the winners circle .:)
  3. brEad
    brEad
    Glad to hear the negative test result. Good luck and stay safe.
    Thor1, mad mikey and loudbang like this.
  4. southcross2631
    southcross2631
    My wife bought me a winch for our trailer yesterday. Will make loading much easier.
    Going to Alabama on Tuesday to get the heads done.
  5. glrbird
    glrbird
    A winch is really handy when something breaks, you don’t have to go find 6 guys to push in on the trailer.
  6. southcross2631
    southcross2631
    I guess she tired of trying to guide me up on the trailer.
  7. 51504bat
    51504bat
    Let me get this straight, She wet sands the wagon and helps you pull the motor and also whoops you at golf but has a problem of guiding you onto the trailer?:cool:
  8. southcross2631
    southcross2631
    No she just gets tired of me *****ing when she gets me too close to the rail.
    I can be hard to to work for or with. Just a hard *** sometimes, but I am trying to mellow in my old age.
  9. Lloyd's paint & glass
    Say what? o_O
  10. southcross2631
    southcross2631
    Getting loaded up to go to Alabama this morning to get the heads updated by Pro Ma** .
    That's service from a cylinder head manufacturer . Bring them the heads and they sell you the parts cheaper than Summit by a lot and stop what they are doing to work a customer in to upgrade their heads. Then only charge a hundred bucks to break down the heads set the ***embled height and re***emble the heads with ***anium retainers while we wait. Pretty cool !
  11. southcross2631
    southcross2631
    Built a cover for the fuel cell yesterday
    Couldn't find a suit case to fit. So a metal cover will have to work
    Sent from my SM-A505U using The H.A.M.B. mobile app
  12. southcross2631
    southcross2631
    Got my heads back. Ended up needing to swap the valves for
    .100 longer valves to get the ***embled height without cutting the spring pockets deeper.
    Will make a good deal on some almost new valves and springs.
    PM me if you need some solid roller springs or some 2.08in. 1.60 ex valves. 20210105_170506.jpeg
  13. southcross2631
    southcross2631
    Still waiting on the good old USPS to deliver my parts. Compe***ion Products shipped them through the post office.
    Had they used UPS or FEDEX the motor would be done.
    Found a deal on a set of Moroso front tires. They listed for $155 each and I got them for $ 215 for the pair including shipping. Anybody need a set of 185-80 R 15 tires with about 3 miles on them ?
    Make good tires for your street G***er or anything that does not require a bias ply tire like the SEGA does.
  14. southcross2631
    southcross2631
    My parts finally showed up this afternoon. Watched the tracking and it sat for 3 days before being forwarded. No wonder the post office is going broke.
    egads, Thor1, 55 Ford Gasser and 2 others like this.
  15. southcross2631
    southcross2631
    Got the heads back on today. Checked the push rod length and got the rockets on.
    Will bolt the intake on tomorrow and get it ready to go back in. 20210111_180909.jpeg 20210111_180920.jpeg
  16. saltflats
    saltflats
    from Missouri
    Looks good, using all the slot in them rockers. :cool:
    Randall, Thor1 and loudbang like this.
  17. southcross2631
    southcross2631
    I had to really check for clearance on the retainers it is close but no rubbing . That's what a .680 lift cam will do in a SBF. I hope to save up enough to change to shaft rockers soon.
    Will be ordering a stud girdle as soon as funds allow. I am concerned about rocker stud breakage or flex with my new valve springs as I now have 265 lbs. of seat pressure and 750 lbs. over the nose.
    chryslerfan55, Thor1, AHotRod and 5 others like this.
  18. glrbird
    glrbird
    Cheep aluminum stud girdles on eBay, help get you by till you get shaft rockers.
  19. southcross2631
    southcross2631
    Yes I have been looking at them
    Cheap usually means that . Got my intake bolted on
    I am going to build some valve cover baffles before I bolt them on. With my vacuupan hooked up
    I don't want to have oil ****ed out into the collector's. 20210112_113657.jpeg
  20. Super Duty
    Super Duty
    That thing looks awesome
  21. southcross2631
    southcross2631
    Got the motor and trans ready to stab back in the car. Now I need a day of a little bit warmer weather.
    It has been cold and windy for days here.
  22. southcross2631
    southcross2631
  23. southcross2631
    southcross2631
    Well I finally got a decent day and got it stabbed in the car thanks to help from my wife.
    AHotRod, 427 sleeper, Thor1 and 4 others like this.
  24. southcross2631
    southcross2631
    What is blue and gives an old man a woody? A high compression small block Ford with a nasty solid roller cam and open headers 20210121_171906.jpeg
  25. 51504bat
    51504bat
    Since your wife is so involved with this project as well, does a high compression small block Ford with a nasty solid roller cam and open headers give her a woodet? Just kidding. Engine looks good can't wait to hear about its shak down run.
  26. 6sally6
    6sally6
    Get your pardner(wife) video that 'puppy' as you check-it-out on one of those Tenn. back roads..I know they got plenty!!!
    6sally6
    Thor1 likes this.
  27. 51504bat
    51504bat
    Do you have to paint the distributor cap black?
    "SEGA requires red MSD caps get painted black. Go ahead and paint away."
    chryslerfan55, Thor1 and loudbang like this.
  28. saltflats
    saltflats
    from Missouri
    MSD sells black caps also.
  29. southcross2631
    southcross2631
    It is not an MSD distributor. It is a Jegs brand knock off. It works with a MSD 6al box. The cap is not as red as it appears in the picture. It is actually more of a maroon and so far they haven't said anything about me needing to paint it.
    If they say something then I will it's no big deal. The dist. actually works really good. I'm sure it is a Chinese made dist. Probably from Speedmaster , but it seems well made a has a nice advance curve that is adjustable or can be locked out. I like to have an advance so I don't have to get it spinning over before I turn on the ignition, it also keeps the plugs cleaner idling around the pits and on the return road.
    Learned that from my round track days of loading up the plugs under caution with a locked advance.
  30. southcross2631
    southcross2631
    Should be making noise by tomorrow. Then it's on the trailer and heading to Lloyd's place for some much needed beautification.
