Features all AV8 picture thread
Discussion in 'The Hokey Ass Message Board' started by Chris, Dec 13, 2009.
  1. fenderless
    fenderless
    from Norway
    Kool thread:) Here is a couple, the green is mine:)
    K
    Taildragger&fenderless
  2. dsiddons
    dsiddons
    from Indiana
    Damn!! Now that is bad***
  3. Model A Mark
    Model A Mark
    from dallas
    thanks dsiddons ...
    fenderless, your sedan is nice, ive got one allmost just like it .
  4. hilltopgaragede
    hilltopgaragede
    from Delaware
    ImageUploadedByH.A.M.B.1391994117.442769.jpg ImageUploadedByH.A.M.B.1391994127.439966.jpg ImageUploadedByH.A.M.B.1391994145.211415.jpg ImageUploadedByH.A.M.B.1391994153.722896.jpg ImageUploadedByH.A.M.B.1391994168.894458.jpg ImageUploadedByH.A.M.B.1391994186.273713.jpg ImageUploadedByH.A.M.B.1391994199.746056.jpg
  5. 4 banger 4 life
    4 banger 4 life
    from ohio
    Man some really nice cars here. Great thread
  6. hotrodderhaag
    hotrodderhaag
    Hilltop
    That's one badddd roadster !
  7. hilltopgaragede
    hilltopgaragede
    from Delaware
    Thanks much, just completed the finishing touches this weekend. Broke in the cam and put about 30 miles on it Saturday. It was in the 30's here, but it was still fun! Can't wait for the snow to stop and spring to get here.
    By the way ..... I have been following your post for some time. We have approached many build issues the same way.
  8. fmascioli2@gmail.com
    from CT
    Hilltop, that's a very cool roadster. What's that alternator mounted fan from?
  9. hilltopgaragede
    hilltopgaragede
    from Delaware
    The bracket is from Speedway, they make them for 59AB or 8BA. Pully is Offy also from Speedway. Fan is early Ford V8 trimmed down to 13" dia. Had to machine a 1" thick hub to adapt the pully to the fan due to different bolt circles. Alternator is GM internally regulated.
    Looks alot like yours, only I made the hub. Love the stance on your Coupe.
  10. hilltopgaragede
    hilltopgaragede
    from Delaware
  11. hilltopgaragede
    hilltopgaragede
    from Delaware
  12. fmascioli2@gmail.com
    from CT
    Thanks for the nice words. I think you've got yours nailed too. Keep 'em coming.
    Btw, are you able to tension the belt ok? We had some height and fan clearance issues and lengthened the vertical slot in the slingshot as far as we dared to lower the whole ***embly. But then had no ability to tension and ended up adding an idler. Is that a narrow belt you're running...maybe it's just the angle of the pic.
  13. hotrodderhaag
    hotrodderhaag
    A few in the snow this month
  14. hilltopgaragede
    hilltopgaragede
    from Delaware
    Bingo! We are all running into the same issues. Made slot a little longer and added stiffener accross old fan mount bolt holes. I trimmed fan to 13" O.D. which gave clearance at top radiator tank. It's a wide belt now (was narrow for mock up), no tensioner. Longest wide belt i could find is 55", but was still too short. An old streched one fits good. Takes 2 people to adjust it, one to pull, other to tighten the nut.
    What belt are you using?
  15. fmascioli2@gmail.com
    from CT
    So you have a surveillance camera in my garage?....ha, ha. Yeah, also made a horizontal stiffener for the sling shot. We originally had a B50 but it was really too tight and now have a B52 with the tensioner, so ours must be lower and/or the alternator pulley must be smaller. Here's what we did:
      501.1 KB
      488.8 KB
      493 KB
      471.9 KB
      475.4 KB
      482 KB
      478.7 KB
  16. hilltopgaragede
    hilltopgaragede
    from Delaware
    I also cut about 1/2" off the top of the manifold boss to clear alternator underside. Thus lowered the whole rig about that amount. Will take and post some more detailed pictures tonight. Provides enough slack to get the belt on, then we just pull up to the belt limit.
    Your device looks well engineered.Thanks for part numbers, didn't know Napa had those belts.
  17. fenderless
    fenderless
    from Norway
    Thanks Mark:) The "A" is now inn for some small changes:) I'm done with yellow:)
    K
  18. Salty 28
    Salty 28
    from Mandurah
    Very cool cars here, mine arrives home on Tuesday, now to find an 8BA
  19. j ripper
    j ripper
    from napa ca.
    Bringing this thread back up. Early 30 standard Roadster.
    clem, hfh, Model A Mark and 2 others like this.
  20. jim galli
    jim galli
  21. 26 T Ford RPU
    26 T Ford RPU
    Some from my camera. JW
    hfh likes this.
  22. 26 T Ford RPU
    26 T Ford RPU
  23. 26 T Ford RPU
    26 T Ford RPU
  24. 26 T Ford RPU
    26 T Ford RPU
  25. 26 T Ford RPU
    26 T Ford RPU
  26. 26 T Ford RPU
    26 T Ford RPU
  27. 26 T Ford RPU
    26 T Ford RPU
  28. 26 T Ford RPU
    26 T Ford RPU
    Stunning ! JW
    hfh likes this.
  29. 26 T Ford RPU
    26 T Ford RPU
  30. 26 T Ford RPU
    26 T Ford RPU
