Technical Wide Five Adapters
Discussion in 'The Hokey Ass Message Board' started by 55willys, Oct 30, 2019.
  1. 55willys
    55willys
    I am looking to gauge interest in wide five adapters. I have sold about 50 sets of them world wide. The last batch took over a year to sell. I'm totally out of stock now and checking to see if it is worthwhile to make more. The cost of materials has increased due to tariffs and aluminum companies jacking the price. I would like to make these available again but it also has to be economicly viable. You can answer here and if you are wanting to buy send me a PM. thanks.
  2. 55willys
    55willys
    Bumping this for the morning crowd. I have been out of stock for about 6 months and have only had about 3 requests for them.
  3. Mr48chev
    A lot of these guys are visual oriented. Photos do a lot.
  4. 55willys
    55willys
    These are the adapters that I have had produced before. One set has 5x5" and 5x5-1/2" lug pattern and the other has 5x4-1/2" and 5x4-3/4" lug pattern. The studs are countersunk on the back side so that you won't have brake drum interference. They are made from 6061-T6 aluminum precision plate.
    One thing to note is that if you are converting early Ford 5x5-1/2" to wide five it will move the wheels out about 1-1/2" per side. So if you are running stock 40 style brakes it is recommended that you find a good set of wide five drums to do this conversion. These are mostly used for converting the modern rear end to accept the wide five.
    Tim likes this.
  5. 55willys
    55willys
    I'm still wanting to see what the market is for these.
  6. 55willys
    55willys
    Could it be true that I have supplied the world with wide five adapters and there is now no need for any more?
  7. Waddell
    Waddell
    I have some interest in wide 5 adapters. Still working details.
    Do you know of any Lincoln Zephyr Bendix brakes that are self adjusting & will they work on my 39? Thought I saw some and now I can Not find them.
    Thanks
  8. 55willys
    55willys
    MT products sells them, They are owned by Bowling Brothers. Just make sure you get the one's with the 1-3/4" shoes if you are using the stock wide five drums.
  9. Ziggster
    Ziggster
    I was thinking about running the wide five rims, but parts availability and cost kinda turned me off, especially for the hubs which seem almost impossible to find. Still not sure how these adapters fit into the equation.
  10. Will one of these adapters work for balancing wide 5 wheels on a modern spin balancer.
  11. 55willys
    55willys
    The wide five hubs are out there 37-39 front and 36-39 rear. They are a bit hard to find but are on eBay all the time. 12.060 is max for turning them. The wide five adapters when paired with the 40-48 style front drums and hubs will push the wheels out about 1-1/2" per side. This will affect the scrub radius and handling a bit. I'm working on a disc brake kit for the early Ford front wide five or 5x5-1/2" bolt pattern that will work with stock wheels.
  12. 55willys
    55willys
    Yes
  13. cosmo51
    cosmo51
    interested in adapters. what is the price ?
  14. 55willys
    55willys
    The price is $245 per pair. They are out of stock at this time. You can see them at highway101ind.com
  15. 55willys
    55willys
    I'm looking at doing a run of these in January of 2021 and am looking for those who want them. You can PM me.
  16. Sell singles?
  17. 55willys
    55willys
    I can, is this for balancing purposes?
  18. rusty valley
    rusty valley
    i would like one for balance too. don't even need the inner stud holes drilled. just the plate with center hole and wide 5 studs
  19. Chainsaw chipper
    Chainsaw chipper
    from Illinois
    Hi,I'm in for a single for balancing purposes,Thanks ken
  20. 59rambler
    59rambler
    Will they work with widened 5 wide wheels? Wheel smith will widen wheels for modern tires (6-8”), and will they work on GM disc brakes, a Speedway kit?
  21. 51504bat
    51504bat
    I'd be interested in one for balancing purposes as well.
  22. AV8R
    AV8R
    count me in for a set. still interested in making a run?
