Projects Belly Tank Build UK
Discussion in 'Traditional Hot Rods' started by JamieUC, Jan 3, 2021.
  1. JamieUC
    JamieUC
    from Swansea UK
    Well after lots and lots of looking for a P38 drop tank I came to the conclusion I'd headed down the road of unobtanium, so out comes the English wheel and a large tub of elbow grease.
    I'm now about eighteen months into this build now so will post pics of progress so far.
    First off a buck was built luckily my business has a CNC wood router so this was the easy bit.
    Followed by lots of hammering and wheeling.
    Lots more hammering..
    Lots more wheeling...
    This is the bottom side so a section was cut out to make flat bottomed.
    Well thats it for part one, part two following soon, soon as I can figure out loading more pictures.
  2. JamieUC
    JamieUC
    from Swansea UK
    Ok got the photo uploading sorted so here's part two.
    Next bit was shaping some aluminum angle to make the exterior lip using a shrinker stretcher and propane torch to anneal. The tight radius at the back took a few attemts and about ten anneal cycles to get right.
    Welding on the lip
    Then TIG welding in the bottom panel, I've not done much aluminium welding till this project but by this stage I'm starting to get the hang of it.
    At this stage I'm starting to get a bit excited, so it was time to don the racing helmet and take a daft photo to entertain friends, wife, kids.
    Well first side took about eight months of my spare time, the second side went much quicker. Fast forward another two months and both sides of the body are done, still some finish panel beating to do on the top half but this will be done after its had the top cowl built and its been sectioned up into removable panels.
    In part three I'll cover the start of the ch***is build...
  3. j hansen
    j hansen
    Interesting,,,,,,,,but we need a photo or two.:D
    I can see them now,,,,,,,,subscribed!
    nunattax, loudbang and Stogy like this.
  4. JamieUC
    JamieUC
    from Swansea UK
    Opps did the photo uploading wrong.:oops: should be OK now:rolleyes:. Let me know if there still not showing up.
  5. das858
    das858
    Fantastic job on the belly tank !
  6. continentaljohn
    continentaljohn
    That’s awesome great job
  7. ChuckleHead_Al
    ChuckleHead_Al
    Amazing job, I'm subscribed. Keep the updates coming.
  8. Amazing metalwork! Definitely subscribing. What’s your plans for engine?
  9. GeeRam
    GeeRam
    Looks great.
    Has it been built to the correct dimensions of 10' 9" long and 21" diameter at widest point...?
  10. modagger
    modagger
    Very nice work! Can’t wait to see more!
  11. rwrj
    rwrj
    from SW Ga
    Holy Smoke. Wow. I'm watching.
  12. JamieUC
    JamieUC
    from Swansea UK
    Hi Retson Plan is fit a Ford flathead out of a Mercury COE with 4/71 blower, will post pics soon.
  13. JamieUC
    JamieUC
    from Swansea UK
    Hi Gee Ram Nice to see posts from this side of the pond as well as the States. Tank is 13'6" by 36" as far as I could resurch there are two sizes the 13' footer that is aluminium and the smaller size you mention wich was made of steel. Its gonna be enough of squeez in this one so i'm glad its not 21" wide.
    chryslerfan55, trikejunkie and Stogy like this.
  14. hotrodjack33
    hotrodjack33
    Holy **** !!! I imagine it's hard enough to just build a Belly Tank racer...without having to actually build the tank itself. That's amazing craftmanship!
  15. kevinrevin
    kevinrevin
    from East Texas
    This looks like a cool project. I'm tagging along for the ride.
  16. Baumi
    Baumi
    "Ho´Lee Chit " said Confuzius when he saw this build:D Crazy stuff , I´ll be watching! Where are you going to drive it once finished? I guess there are just as many salt lakes in the UK as there are in Germany, right? hahaha
  17. Wow, that's a great job you are doing. Being a fan of belly tank racers I'm looking forward to more.
  18. GeeRam
    GeeRam
    Yes, the 315 gal ferry tank was larger, I thought it was 12' 6" long by 36" dia?
    The large ferry tanks were not designed for dropping, hence being used for long distance ferry flights, not combat ops, which is what the droppable smaller 150 gal combat tanks were designed for, and thus much more flimsy in construction as well, as they were in effect disposable items.
  19. caper
    caper
    from Cape Cod
    Very nice build, great craftsmanship.
  20. GeeRam
    GeeRam
    VHRA at Pendine Sands would be my educated guess ;)
  21. stillrunners
    stillrunners
    from dallas
    You would just think they were laying around all those farms from way back then when they were actually dropping them to engage the enemy .
  22. 65standard
    65standard
    Incredible metal shaping skills. Thanks for sharing. Looking forward to the rest of the build.
    chryslerfan55, loudbang and Stogy like this.
  23. the pinstriper
    the pinstriper
    from duxford UK
    Loving this
  24. sailingadventure
    sailingadventure
    Excellent job! I`m subscribed and waiting for more.
  25. hotrodjack33
    hotrodjack33
    Yeah, but can you imagine what a drop tank looks like after it's fallen several hundred feet at 150 mph? I think all the drop tanks used here in the U.S. were probably unused military surplus.
    rpm56, loudbang, Stogy and 2 others like this.
  26. Travis latour
    Travis latour
    from Putnam CT
    you just gave me the itch!
  27. Joe Coughlin
    Joe Coughlin
    Looks really good, and a blown Flathead for power should be awesome. I look forward to seeing more pictures of this build
  28. roddering
    roddering
    from Arizona
    Amazing work!
  29. GeeRam
    GeeRam
    Plus, they were not dropped over the UK anyway, combat tanks would have been dropped over the English Channel/North Sea en-route to Europe, once the tanks were empty, or overland in Europe prior to combat engagement.
    loudbang, Stogy and stillrunners like this.
  30. sloppy jalopies
    sloppy jalopies
    weren't some of those drop tanks made of resin covered paper...
    could have been the mustang drop tanks...
    i have seen that some were paper on the history channel...
    loudbang, Stogy and warbird1 like this.
