Hot Rods Red's Headers
Discussion in 'The Hokey Ass Message Board' started by Departed, Dec 28, 2020.
  1. Departed
    Departed
    from Canada
    Anyone here running reds headers on a 1940 ford ? please share some pictures of your headers on both sides.
    Thanks !
  2. 4ty
    4ty
    Can't do pics but my 40 has the Red's headers on a 48 block. Plenty of clearance with the stock steering box,
    Paul in CT
    Departed likes this.
  3. olscrounger
    olscrounger
    I will try to get some pics--have a 40 with orig flathead and Red's headers
  4. Jalopy Joker
    Jalopy Joker
  5. Departed
    Departed
    from Canada
    I just ordered a set with the exhaust extension. I'm wondering if I have enough room to install them without puling the motor out?
    and I'm curious how they look in the engine bay
    thanks guys
  6. Zax
    Zax
    I hope to fire mine up and pull it out of the garage today for it's weekly start up and run. I'll take some pics when I get it outside. The install of the headers was pretty easy. Hardest part was getting the sections between the headers and mufflers positioned correctly and bending the flanges on the Smithy mufflers to the correct position.
  7. Zax
    Zax
  8. Mr48chev
    I lightened Zax's photos up a tad so you can see the details better. I didn't plan on making the first one that much larger though. Zax header (2).JPG Zax  header 2 (2).JPG
    stillrunners and Departed like this.
  9. Zax
    Zax
    Thanks Mr48chev, i've never been much of a photographer.
  10. Mr48chev
    I have to do that a lot on my photos that I take of detail items like that. Those headers do fit well on that car.
  11. Departed
    Departed
    from Canada
    Awesome, thanks guys!
    Looks like you can put the headers on with the engine in place?
  12. Zax
    Zax
    Yes, installation of the headers did not require moving the engine in any way. Just had to jack up the car high enough to have room to work. I think one side I installed from the bottom and the other the top. But I don't remember which.
    I did have to use a Sawzall to make some cuts to the old exhaust sections in order to get it out though. Also in case you didn't know two of the six exhaust bolts are larger than the others on each side. Make sure you keep track of which goes where.
  13. alchemy
    alchemy
    The two big bolts go at the front port on each side.
    Departed and stillrunners like this.
  14. Glenn Thoreson
    Glenn Thoreson
    from SW Wyoming
    I have Reds' headers on my '42 with a '53 Mercury engine. Not hard to install. One thing of note, though, there is very little room for the left side pipe to go through the frame hole under the clutch pedal arm.. Interference with the clutch pedal can be a problem. The 59AB block is just little bit smaller in size than the 8BA/8CM so it may not be an issue for you.
    A little bit of tweaking will do it.
  15. Departed
    Departed
    from Canada
