Technical PSA for garage guys with electric dryers
Discussion in 'The Hokey Ass Message Board' started by Budget36, Jan 3, 2021.
  1. Budget36
    Budget36
    Yes, related to this site, as many build in their garage
    I put a new dryer in, and pulled the cover to use my original electrical 220 cord. This is what I found...
    what you don’t see is all the lint I removed, this happened because the flexible 4 inch vent had spilt open and filled the cover for the plug connections with lint.
    WhY is this import? Well, many of us use a garage where our washer and dryer are in, this about looked like a great way to burn down everything I had in the garage and the house too. So went with the rigid flex stuff
    Damn, pic won’t load
    Jalopy Joker, pprather and clem like this.
  2. Budget36
    Budget36
    Now it did, mercy. The lint was packed up between a hot leg and the ground (center) leg
    Jalopy Joker likes this.
  3. clem
    clem
    Yep, dryers can be dangerous. I’ve pulled a few to bits to repair and always amazed at how much lint is hidden between the drum and outer casing, just where you can’t see it !
    lothiandon1940 likes this.
  4. jetnow1
    jetnow1
    from CT
    traditional would be to have swmbo hang things to dry, then use the circuit for your welder. Take this advise at your own risk.
    SR100, leon bee, scotty t and 3 others like this.
  5. Elcohaulic
    Elcohaulic
    While working on electric circuits close to that lint, I had it ignite on me a few times by touching the wires together and making a spark.. That stuff is so dangerous! It should be cleaned monthly.. Also never use plastic or that corrugated slinky junk.. Always use 4" steel tubing and zip screw the connections together in case it catches fire..
    pitman and ratrodrodder like this.
  6. flatheadpete
    flatheadpete
    from Burton, MI
    I use dryer lint for fire starter when camping...yes, it’s that flammable.
  7. Cosmo49
    Cosmo49
    For you unmarried and never to be married again folks:
    SWMBO = She Who Must Be Obeyed
  8. goldmountain
    goldmountain
    Clothesline works well.
  9. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Electric or Gas, they all ac***ulate lint in bad area's. Bottom line, PM them because cleaning just the lint screen isn't enough.
    Elcohaulic and ratrodrodder like this.
  10. rusty valley
    rusty valley
    in minnesota we use the garage for a freezer, not the laundry room
    Elcohaulic, wsdad and Flathead Dave like this.
  11. Flathead Dave
    Flathead Dave
    from So. Cal.
    Come on! Who doesn't know this?
    It's part of the home routine.
  12. Flathead Dave
    Flathead Dave
    from So. Cal.
    My wife preferred a clothsline over the dryer. Nothing beats a clothsline for freshness.
  13. 1971BB427
    1971BB427
    from Oregon
    Yes lint is highly flammable, but it's non conductive also, so the terminals could be packed with lint and not short to start a fire.
    54vicky and Fordors like this.
  14. harpo1313
    harpo1313
    from wareham,ma
    Same gos for insulation. flash fires spread quickly.
  15. wsdad
    wsdad
    That's a pretty common problem on dryer power cords. Usually, it's caused by a loose nut or corrosion between the copper wire and the crimp connector. It creates a resisgance, which creats a lot of heat until the copper wires melt. Dryers use a LOT of current.
    Hopefully, you replaced the protective cover after installing the power cord. And you have a good ground. If so, all that heat and electricity is contained inside a steel enclosure.
    It's also a good idea to buy a new power cord instead of reusing your old one, even if it looks ok.
    I see the lint in the picture, but it's been my experience (16 yrs appliance repairman) that that particular problem is caused by using an old cord. If the lint were what was being being burnt, it wouldn't get hot enough or long enough to melt or discolor the copper wire.
    I think it'll work fine and be safe if you replace the cord.
    Good luck with it!
    Sent from my SM-G981U using The H.A.M.B. mobile app
    stillrunners and pitman like this.
  16. pitman
    pitman
    Good advice thanks! ^^^^
  17. 52HardTop
    52HardTop
    The center lug is the Neutral connection. The dryer is bonded to the neutral lug with a strap from the factory. We are no longer allowed to use a 3 wire cord for Clothes Dryers or Electric Ranges. We now must use 4 wire cords as well as receptacles. The neutral has to be separated from the bonding connection on the metal body of the appliance. The bonding connection needs to be to the body of the appliance by a separate conductor.
    warbird1 and Elcohaulic like this.
  18. Elcohaulic
    Elcohaulic
    Always use the four prong plug and cord. You want the neutral (grounded) and (bare or green) grounding to be separate.. This can get real dangerous if the dryer line is coming from an old sub panel that doesn't have separate ground and grounding lines.. When I run into this I send two copper ground rods into the ground and run the wire to the sub panels shared neutral and grounding bar.
  19. Moriarity
    Moriarity
    SUPER MODERATOR
    A dryer discussion on a hot rod forum? lets get back to cars huh fellas?
