Projects fixing a smashed 31 model A pickup cab.
Discussion in 'The Hokey Ass Message Board' started by tb33anda3rd, Mar 17, 2019.
  1. tb33anda3rd
    tb33anda3rd
    I bead blasted the pockets and put a rust treatment on the back sides. IMG_1523.JPG
    chryslerfan55, dlw1932, brEad and 8 others like this.
  2. tb33anda3rd
    tb33anda3rd
    my sheet metal break is not big enough to bend a 54 long piece so I had to clamp it down and bend it over the work bench. IMG_1525.JPG
  3. tb33anda3rd
    tb33anda3rd
    I sanded the bed sides down and put a weld through primer on the flanges of the pockets and the corresponding faces of the bed sides.
    while that was drying I removed the bolting brackets from the head board. they had broken off when I took it apart and I thought it would be easier to fix it with them off. IMG_1526.JPG
    chryslerfan55, brEad, TFoch and 6 others like this.
  4. tb33anda3rd
    tb33anda3rd
    I ground off the rusty parts of the bolts that protruded through, then welded a nut on the broken side and took the bolts out. once I fixed them both I welded one side back in. IMG_1528.JPG
  5. tb33anda3rd
    tb33anda3rd
  6. tb33anda3rd
    tb33anda3rd
    of course I started cutting it out and half way into it I remembered I had to leave it 3/4" long to make a flange. so I had to weld it up. cut it in the right spots then bent up the flanges IMG_1530.JPG IMG_1531.JPG
  7. tb33anda3rd
    tb33anda3rd
    I welded the bolting bracket back in the shortened side.
    IMG_1533.JPG it sort of looks like a model A bed
  8. The37Kid
    The37Kid
    Chevy wheel?:rolleyes:
    Stogy, TFoch and loudbang like this.
  9. tb33anda3rd
    tb33anda3rd
    I don't know what I took it off of. I did part out a bunch of Chevys
    loudbang and Stogy like this.
  10. Doh!!... good work remembering before finishing the cut.
  11. tb33anda3rd
    tb33anda3rd
    yes it made it easier while it was not cut all the way off. I am sad to say I do things like this more often than I should.
    brEad, loudbang, Stogy and 1 other person like this.
  12. Me too!...and I can't count how many times I've made two left or two right side panels when I really wanted one of each!o_O
  13. TFoch
    TFoch
    Looks great Ted. I like the idea of the wheel on the bead roller. I'll have to try it on mine.
  14. tb33anda3rd
    tb33anda3rd
    Tom it really makes the bead roller so much easier to use. I did those panels by myself and was able to keep the beads straight.
  15. tb33anda3rd
    tb33anda3rd
    if you look at my mockup, I even clamped the head board to the wrong end of the bed....o_O
  16. tb33anda3rd
    tb33anda3rd
    tonight I drilled the holes to bolt the head board on the bed sides. I used the piece I cut off as a template. IMG_1537.JPG I did drill them on the correct end.:)
  17. tb33anda3rd
    tb33anda3rd
    I welded the stake pockets on, I put the shorter ones on the front and used the longer ones on the rear so I can extend below the bed to make a support across the rear. IMG_1538.JPG
    chryslerfan55, 40LUV, TFoch and 11 others like this.
  18. tb33anda3rd
    tb33anda3rd
    worked on the other side, welded the pockets on and cleaned the welds up. IMG_1548.JPG IMG_1549.JPG
  19. tb33anda3rd
    tb33anda3rd
  20. tb33anda3rd
    tb33anda3rd
  21. tb33anda3rd
    tb33anda3rd
  22. Stogy
    Stogy
    Runnin shine, OFT, loudbang and 2 others like this.
  23. tb33anda3rd
    tb33anda3rd
    thanks, I think I created the "illusion" of a model A wide bed...without spending any money.;)
    slv63, chryslerfan55, brEad and 5 others like this.
  24. tb33anda3rd
    tb33anda3rd
    this is the photo I have been using for inspiration. post-104573-143142842187_thumb.jpg
    chryslerfan55, brEad, OFT and 5 others like this.
  25. Ted, you just keep doing good work.
  26. Just Gary
    Just Gary
    Awesome build thread!
    Rescuing the cab was inspiring but I really like how you're adapting the bed as well.
    Thanks for sharing all the pics & commentary. :)
    Stogy, greaser, nunattax and 3 others like this.
  27. tb33anda3rd
    tb33anda3rd
    I fit the head board to the sides, drilled for the bolts and marked for the stiffening bead. IMG_1558.JPG IMG_1559.JPG
  28. tb33anda3rd
    tb33anda3rd
    I ran a bead above the bend line of the bottom of the head board. then put it in the brake and bent at the bottom of the bead. IMG_1560.JPG
  29. tb33anda3rd
    tb33anda3rd
    I then trimmed the flange and made cut outs for the fuel tank supports. Charlie had give me the measurements for them. I cleaned up the cuts and sanded it down. IMG_1562.JPG
  30. tb33anda3rd
    tb33anda3rd
    I wanted to use carriage bolts so it would look like rivets so I filed the holes square for them. IMG_1565.JPG
