Technical early and late 1932 differences,
Discussion in 'Traditional Hot Rods' started by sloppy jalopies, Jan 3, 2021.
  1. sloppy jalopies
    sloppy jalopies
    I happen to have an early and late cowlvent lid...pix...
    anyone have other pix of 1932 differences ? purple one is the late...
    kidcampbell71 and irishsteve like this.
  2. alchemy
    alchemy
    There are probably a hundred design changes during the year, but I don't have pics of them. Everything from body panel bracing to brake pedals to dashboards to drivetrain parts. Most people only know about the 20 and 25 louver hoods.
    I have an early production tudor. It was number 180 off the line at the Des Moines Iowa plant. My brother has an early production five-window. He also has an early truck, soon to be put back together by my nephew. I'm saving an early V8 frame (number 5,000ish) for a roadster project some day.
    triumph 1 likes this.
  3. ratrod0
    ratrod0
    They had V8 firewalls and 4cl firewalls
  4. sloppy jalopies
    sloppy jalopies
  5. big duece
    big duece
    from kansas
    Only difference in the firewalls from 4cy to v8 was a series of holes for an engine snubber(lack of better words) for the 4cy option. The actual stamping is the same, but I have heard there is a early and later stamping with the modification on the drivers side just above where the steering column is.
  6. Fortunateson
    Fortunateson
    I have an early 5W with the early firewall and frame. No reinforcements over the rear axle and there is a difference just above or seide where the steering column is. Forget exactly what the firewall difference is...k
  7. dwollam
    dwollam
    Mine is a '32 4dr sedan, late body and frame. Firewall is an early one, not from this car originally. I had an early V8 frame that had the early pedal mounts.
    Dave
  8. Billylando
    Billylando
    There were two style of dash panels offered and early style and a later style.
  9. clem
    clem
    ^^^^ innie and an outie, is what some call them ? I have one of each. somewhere......
    So what came first, the 20 louvre hood ? And when did they change to 25 ?
  10. triumph 1
    triumph 1
    I read somewhere that 25 louvre hoods were made for west coast cars to help with cooling. Not sure if that’s accurate though.
  11. sloppy jalopies
    sloppy jalopies
    weren't innies truck dashes...
  12. Fordors
    Fordors
    Commercial dash does not interchange with P***enger Car.
  13. Fordors
    Fordors
    The photo shows the concave shelf where the vacuum canister for the proposed vacuum ***isted clutch was to go. Development started and a patent was granted but it never saw production.
  14. sloppy jalopies
    sloppy jalopies
    so tell us why they aren't...
  15. Fordors
    Fordors
    Slightly different width and the contour at the bottom is not the same.
    bowie likes this.
  16. Fordors
    Fordors
    This is a factory photo showing the raised panel louvers that were on the very earliest ‘32’s. A carry over from the A somebody (Edsel?) decided it made the hood too busy so those early stampings went to Europe. When they were used up the European Fords used the typical hood sides.
  17. alchemy
    alchemy
    Any Europeans with an extra pair of raised louver hood sides can contact me for a crazy offer to purchase!
    I collect all early 32 stuff I can afford. Parts in my collection other than the whole car are open louver hood sides, single finger hood hooks, tabbed brake/clutch pedal arms, straight gas pedals, innie dashboards, single rubber bumper rear horn covers, pointy inner handles, center hinge visors, firewalls, and some others I can't remember right now.
  18. Nailhead Jason
    Nailhead Jason
    Rear Axle’s are different, early is more like an A axle and late is more like a 33 34 axle. Early frames do not have the reinforcement plates in the rear of the frame to support the fuel tank. Later ones do.
  19. ironandsteele
    ironandsteele
    I bought an extremely nice grille shell from a guy that was a little unusual. At the bottom there were no punched slots for water and sediment to drain, and the crank hole was perfectly round. Apparently an early design that didn’t make it onto many cars.
    More hot rod content:
    WWW.IRONANDSTEELE.COM
  20. krylon32
    krylon32
    from Nebraska
    For all the information on running changes refer to David Rehor's 2 volume set of books on the 32 Ford. Packed with information.
  21. The holes for the engine snubber were there on all of the firewalls (except for a few early ones). The unused holes were left open and sealed by the firewall insulation. If the holes are missing check the inside as someone probably welded them up. Same for the hole for the bolt to mount the throttle shaft which was different between the 4 and V8. The only differences in the firewalls were minor changes during the production year but they applied to both the 4 and the V8.
    Charlie Stephens
    Hamtown Al and slug like this.
  22. Sun visors were different. Early ones mounted in center and later ones mounted on ends. I believe (but am not positive) that the 3 window used the sun visors that mounted on the ends for the entire year.
    Charlie Stephens
    Hamtown Al likes this.
  23. Kiwi 4d
    Kiwi 4d
    Early 32 had no front “K” legs on the transmission crossmember.
    stillrunners and Hamtown Al like this.
  24. Fortunateson
    Fortunateson
    That's exactly it, thanks.
  25. clem
    clem
    what an opportunity this thread is for you to post some pictures of the unusual or rare stuff that you have......
    j hansen and kidcampbell71 like this.
  26. big duece
    big duece
    from kansas
    Thanks Charlie for the info, not sure which I had seen in the past either the oddball few that weren't drill or possibly a front view of a firewall with holes with insulation behind making it hard to see.
  27. mike in tucson
    mike in tucson
    from Tucson
  28. Fortunateson
    Fortunateson
    I'll see your "i" and raise you a "yiyi"!
    Hamtown Al and j hansen like this.
  29. sloppy jalopies
    sloppy jalopies
    pre-op dr.'s appointment this am...[lt. eye].
    then going to take pix of a buddy's '32 commercial cowl [cut down]... get his prices for its parts...
    can't wait to see if she is the new or old version...
    to big to ship so i will list his ; firewall, dash, throttle, cowl vent lid, '33 to a '32 firewall "mounting rail"
    has good subfloor extensions and good lower cowl panels...
    kidcampbell71 likes this.
  30. clem
    clem
    597FA005-9BA1-4EDB-AB88-6483E80E8010.png As per OP questions, - pictures asked for.
    Here’s an outie dash below, innie above is an ex overseas car, Argentina ? with air vents for windscreen.
    one would have to wonder what the reason was to change it through such a short production run ?
    I have always wondered if the plans for the tooling (sent between the 30 odd factory’s back then) were read wrong at some locations.......
