Projects 26 T Roadster Pick Up build Thread
Discussion in 'The Hokey Ass Message Board' started by Blue One, Mar 27, 2010.
  1. Blue One
    Blue One
    from Alberta
    Thanks JW hope 2021 will be better for you and also better for all of us.
    loudbang, Stogy and 26 T Ford RPU like this.
  2. Thanks for the detailed info on those fittings. I appreciate it
    loudbang and Blue One like this.
  3. Blue One
    Blue One
    from Alberta
    So I spent a little bit of time in the garage again today and installed the radiator support rods and wouldn’t you know it :D again because the carbs now sit 13/32” of an inch higher I’m going to have to bend up another fuel line in a different configuration for the front carb.
    The fuel line which had adequate clearance before now comes to within an eighth of an inch of the rod where it bends to go to the carb inlet.
    Sitting there under the support rod that closely allows no room for engine movement at all.
    Another one of those 10 plus things to change from the original change. :D
    Stogy, RICH B, loudbang and 4 others like this.
  4. Blue One
    Blue One
    from Alberta
    The front carbs fuel line is redone and revised.
    It now drops down slightly to clear the support rod and then it’s a straight run and down to the fuel log. :cool:
    Before
    After
  5. Six Ball
    Six Ball
    from Nevada
    Beautiful! And you matched the number of bends in each one, simple yet perforce design.
  6. 26 T Ford RPU
    26 T Ford RPU
    We have grown to expect nothing less, Larry....way cool. JW
    Stogy, Blue One and loudbang like this.
  7. Blue One
    Blue One
    from Alberta
    In the department of more efficient breathing I’m going to ditch the small 4x2 air cleaners that I believe were limiting the power output of my engine and contributing to the rich running issue too.
    I contacted Dennis at O’Brien Truckers and ordered up a set of Edmunds 4 1/2” air cleaners that have the surface area and the elements are taller so they will breathe a lot better. :cool:
    2C372588-3DCF-44D0-947F-8D72345ED432.jpeg 010A3464-3AED-4CA9-8EED-005864B956D4.jpeg
  8. 26 T Ford RPU
    26 T Ford RPU
    They are very cool ! JW
  9. Blue One
    Blue One
    from Alberta
    Well here we are almost ready to get back on the road :D c’mon spring :D
    I have everything back together now.
    Transmission pan back on and new fluid in.
    Radiator filled up. Fresh oil and filter.
    And as you may recall I had the headers stripped and recoated with ceramic along with the intake manifold.
    All installed :cool:
    Now I’m just waiting for the delivery of my new air cleaners from O’Brien.
    Next on the list is to pull out the sewing machine and get after the rest of the upholstery on the panels.
    Pictures for your enjoyment :D
    DF3D754D-6260-4AF5-BBB0-B9419BE9EA02.jpeg 686FD62D-E9C9-4220-A7D9-3936629111D8.jpeg FA886213-D039-46D0-8EEB-6AE78B0CD42A.jpeg 65A18DDD-EDC5-4A9C-B2DE-F30CCFC921B1.jpeg ED10B751-BCD0-4E3E-B031-A1C4B80C6C17.jpeg A8BF02DA-C96A-4946-92B5-5C61B53E8CC7.jpeg 5B421BF2-0A25-4913-A143-903C0E47E47F.jpeg 8B336DDF-89FB-42CB-8E56-69828E240BDA.jpeg
    Remflex, best exhaust gaskets ever, no leaks.
  10. Six Ball
    Six Ball
    from Nevada
    The quality and detail is just amazing. I hope you get to drive it a lot this year.
    Stogy, loudbang and Blue One like this.
  11. Blue One
    Blue One
    from Alberta
    Thanks
    I’m sure planning on it. It’s a blast to drive.
    Stogy and loudbang like this.
  12. How's the upholstery going? I've been curious.
  13. Jay McDonald
    Jay McDonald
    I am a big fan of '26-'27 RPU's and this one is the gold standard in my book. Been following the build since day one, thank you for taking the time to do***ent it so well.
  14. Tim
    Tim
    from KCMO
    I mean the trucks cool but I keep thinking dang, that shops well lit! Haha.
  15. Blue One
    Blue One
    from Alberta
    Let’s just say it’s not going. It’s been delayed, life gets in the way sometimes.
    But I’m fine with that. I can still drive it this summer.
    That’s because I converted the fluorescent fixtures to LED tubes eliminating the ballasts.
    Instant on no waiting for ballast warm up.
    Sure makes shop time enjoyable being able to see.
    Stogy, Six Ball, Tim and 4 others like this.
  16. Tim
    Tim
    from KCMO
    Every time I replace another fixture with LED I think “holy **** was I working in a cave before??”
    Stogy, Crazybillybob, brEad and 4 others like this.
  17. I just started reading this from the beginning, only 89 pages to go...
  18. Blue One
    Blue One
    from Alberta
    It’s definitely a saga covering 10 years or so. :D
  19. I realize it has been a long time, but can you elaborate?
    loudbang and Stogy like this.
  20. Blue One
    Blue One
    from Alberta
    If you read further on in the thread you will find the answer.
    The way I had it set up to begin with would have resulted in the whole rear axle acting as a big sway bar, giving a non working rear suspension.
    26 T Ford RPU and loudbang like this.
  21. Blue One
    Blue One
    from Alberta
    Well, life has progressed to almost spring and the roads will be swept from the winter sand and gravel soon.
    No upholstery happened because of other family commitments.
    But that's okay as I'm thinking on the direction I want to go with that, finish it myself or p*** it over to a pro.
    I was thinking of attempting my own top fabrication but don't regret having taken it to Rod Tops.
    Anxious to get on the road and put some more smiles (miles :)) on it.
    I received my Obrien Truckers Edmunds air cleaners and they are nice looking but in my typical fashion I don't like the way they are put together and the screen the filters are wrapped with.
    They're wrapped with 2 layers of different screen and they are awkward to take apart and put back together which will happen when you want to clean the washable filters.
    So, I picked up some materials and will create something that will work much better. Details to follow :cool:
    26 T Ford RPU, AndersF, Tim and 2 others like this.
  22. goldmountain
    goldmountain
    It looks like those air cleaners won't clear the hood you don't have.
  23. Tim
    Tim
    from KCMO
    Looking forward to the details on the filters! You always have great ideas
  24. Blue One
    Blue One
    from Alberta
    You mean the hood I’ll never have :D
    So it’s a non issue.
    The short air cleaners wouldn’t have cleared a hood either.
  25. RodStRace
    RodStRace
    Waiting to see how you will improve the air cleaners and car!
    I'm a fan of the lightest, simplest solution for car challenges, and the heavy cast air filter housings kind of bug me, so I am hoping you have something elegant in store.
  26. Blue One
    Blue One
    from Alberta
    The castings are actually very nicely done and being aluminum they’re quite light as the thickness isn’t excessive.
    What really bothers me is the double screen wrapped filter elements.
    I have a plan to fix that :cool:
    bymanr, loudbang, OFT and 2 others like this.
  27. Blue One
    Blue One
    from Alberta
    Well as usual things always take longer than you think they will but I finally sorted out the air cleaner screen situation.
    As you may be aware I have woven stainless steel mesh in my grille as an insert and I also have stainless mesh in my Boling bros Lincoln front brake backing plate vents.
    So I picked up some woven #8 stainless steel mesh and proceeded to cut it and weld it into sleeves to cover the air filters allowing easy ***embly and cleaning the filters when needed.
    Anyone ever try to weld .023 wire diameter stainless steel mesh with a TIG machine?
    Are we having fun yet :D
    In any case setting the machine up for a low temperature pulse of about 15-20 amps at a very small duration pulse and a full arc off cycle between pulses every 3 seconds did the trick.
    And I do mean trick :D
    Almost like magic because do the wrong thing and there’s no mesh anymore :D
    Another thing about woven mesh is that after you cut it you can unravel it without too much trouble as the strands at the edges aren’t well secured.
    So if you look close you will see that each vertical wire mesh strand has been welded to the top and bottom wire of the sleeve making sure they won’t come unraveled.
    There are 109 vertical strands on each sleeve :eek::D
    I’m pleased with the results, here are pictures for your viewing pleasure. :cool::D
    29797710-B0CF-4A8E-9EE8-59071B95DBAA.jpeg 05956B1A-A3A1-46B9-B14D-51B9B152528C.jpeg DA40BE50-5FB7-47E6-AF71-E04100D5180C.jpeg 348967D0-41C3-48BD-AB78-E9F4F39EB84C.jpeg BAB86531-B41F-42E1-AD87-6480930EFF31.jpeg 1AAA8C37-BF76-4084-B38B-342997BD1578.jpeg 962905A6-4212-4009-969C-67EE81FCBFE6.jpeg D4E1CA86-D850-49F1-9767-8BF56A7100A2.jpeg
  28. 57 Fargo
    57 Fargo
    Well Larry, that looks killer. Nice work as usual. I can’t imagine welding all of that fine material.
  29. 26 T Ford RPU
    26 T Ford RPU
    Top job but that,s what you have done from the start.:cool::cool: JW
  30. Tim
    Tim
    from KCMO
    I’d have expected no less. Looks great
